Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Brakes and Suspension
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
View Poll Results: POLL: Front and Rear Spring Rate Ratio
Lighter in front than rear 44 58.67%
Same front and back 5 6.67%
Stronger in front than rear 26 34.67%
Voters: 75. You may not vote on this poll
Old Jun 19, 2006, 05:56 PM   #16
Personal Sales Rating: (1)
Drives: GTi VR6
remember to inculde the rear sway bar stiffness in this. softer rear spring setups usually have a big rear bar, but this makes the rear suspension less independent, causing inside wheel lift etc. just comparing spring rates without including the sway bar really isn't a good comparison.
__________________
Joe - Vishnu Ohlins tuner
Offline
Old Jun 19, 2006, 07:07 PM   #17
Personal Sales Rating: (17)
chmodlf's Avatar
Drives: 03 EVO
Quote:
I hear what you are saying. But I disagree. As a general concept it is a valid question IMHO.
__________________
2003 GSR -- Not the same as shipped
For Sale:
Swift Coilover Springs 16K
Offline
Old Jun 20, 2006, 12:13 AM   #18
Drives: GTi VR6
Quote:
Hope I didn't imply that I was questioning the validity of your poll, it's just that I've seen too many times where people are looking at specific differences between two cars where there are systematic reasons for such differences. I just hope people in this forum see the forest thru the trees...
__________________
Offline
Old Jun 20, 2006, 04:10 PM   #19
Drives: 2005 RS, 2002 S2000, 2003 Mazda Protege5, 1998 Honda VFR800
sway bars: front = stock; rear = 25mm progress bar on the middle setting
camber: -2.5' front, -1.5' rear
toe: zero all around
rear trailing arm bushings and Whiteline anti-bumpsteer kit
I read many threads, books, and other websites relating to spring rates and ultimately decided to go with the Works Stage3 because I like the people there and it's local to me in the SF bay area. I wanted to experiment for myself and actually feel the difference wrought by various changes. Of course learning costs money and this is no different.
After dropping the front rate down I noticed a bit LESS push - since I wasn't near the optimum slip angle at all it was merely a sensation of better balance; the car felt like it was using the front and rear tires together more effectively. Could be my imagination. I'll know more after my July 6th trackday at Thunderhill.
Offline
Old Jul 7, 2006, 12:46 PM   #20
After Thunderhill yesterday I can say that I'm happy with the 500/500 setup and I'll be staying with it.
It's reasonable on the street and the front-end bites better especially on downhill (Thill, 5b) and low speed (Thill, 11) corners. Not only that, I could get on the power sooner without the front end washing out (Thill, 2).
A tiny bit of understeer persists but I prefer that for safety. I don't want to drop the front any more because that will result in more roll and more dive.
The afore mentioned handling differences weren't entirely due to springs. I also lowered the rear 2 turns (Ohlins R&T, haven't measured exactly how much it was) and added a tiny bit of toe-in to the rear. I don't claim this is the fastest setup but for me it's great - predictable, safe, decent on the street, etc.
Once again the RacingBrake BBK was fantastic. No fade at all on a 90deg day using ATE fluid. Even when I locked up everything and got squirrelly I kept it under control and on track.
Offline
Old Sep 11, 2006, 12:37 PM   #21
Personal Sales Rating: (16)
EVOlutionary's Avatar
Drives: '04 EVO VIII, '06 EVO IX RS, '90 1JZ-TT Supra
Stock has higher spring rates in the rear for a reason. Mitsu engineers aren't dumb.
__________________
Many thanks to:
Andy @ Showcase Mitsubishi
Keith @ Pure Tuning
David @ DHP Composites
Jon @ TRE
Wayne @ Paradigm Performance
Evan @Exedy Clutch
for your contributions to the EVOlutionary EVO9 Project:
2008 - one car - 20+ wins
2008 - Solo2 XPL National Champ
2008 - Solo2 SM National Champ
2009 - the sky's the limit!
Offline
Old Sep 11, 2006, 01:49 PM   #22
chmodlf's Avatar
Drives: 03 EVO
Quote:
Yep. Especially if you want the car to turn!!! That is unless you thrive on understeer.
It seems that folks that use higher rates in the front need to use a strong rear sway bar and high tire pressures in the rears for an evo that rotates.
For those who only drive straight (the drag racers) or do not "race" their evos the higher front rates will give the rear a less twitchy feel.
__________________
For Sale:
Offline
Old Sep 13, 2006, 04:12 PM   #23
Drives: Ducati 1198s, Ducati 916, KTM 520mxc and an Apex Silver Evo
just got this months SCC and the RobiSpec car entered in the USCC has 450f/550r springs and no mention of an aftermarket rear sway bar...
it all sounds vaguely familiar (that set-up) can't quite put my finger on it
Offline
Old Oct 20, 2006, 01:43 AM   #24
Silver Vendor
2004 EvoM Shootout Champion
Personal Sales Rating: (23)
robi's Avatar
Drives: evo8
you believe everything you read?....hehehe
__________________
ROBISPEC///
EvolutionM Tuner Champion 2004///EvolutionM Nitto Tire Champion 2006 ///1st Open Touring Challenge T-3 /// 2nd Limited AWD SS time attack /// 1st SCCUSCC Roadrace /// 1st & 2nd NASA TT Unlimited Class 2005 ///2nd TTR NASA Nationals 2006
"BEST turning AWD EVO, I've driven!" - Best Motoring's Keiichi Tsuchiya
Partners:
Buschur Racing /// Mike W /// KW/// Whiteline /// ENKEI /// Nitto Tires///STASIS ALCONS /// APR
robispec.com
"...live a little!"
Offline
Old Oct 20, 2006, 08:22 PM   #25
450/550 - sounds much lighter than what many guys use for autocrossing. Do you find that in general you want softer springs and more compression dampning for slower transitions (road course), and higher spring rates and lower relative compression damning for faster transitions (autocross)?
EVOlutionary
Offline
Old Oct 20, 2006, 09:09 PM   #26
Silver Vendor
robi's Avatar
Drives: evo8
the biggest factor is the total traction avalible....255 ra-1s vs 285/30/18 Hoosier/Kuhmo DOT slicks.....require a whole different set-up......"less expensive" damping stacks also trade precision and travel for "control"....(the last is my opinion) reality is that I can "get away with" 2KG lighter springs with the Double aadjustable KW's and get almost stock wheel travel which leads to a better ride too....
__________________
ROBISPEC///
Partners:
robispec.com
"...live a little!"
Offline
Old Oct 20, 2006, 09:22 PM   #27
Thank you for the info! I can't wait to try my AX setup on the road course next year to see just how good or bad it is compared to a road-race specific setup. As it's set up right now I can get it to power oversteer in almost any corner. With last year's setup it understeered and pushed wide anytime I looked at the gas pedal!
I'm gonna talk with David this winter about getting some REAL downforce for the front end of his time attack car next year. I think I might have the ticket!
EVOlutionary
__________________
Many thanks to:
Keith @ Pure Tuning
Jon @ TRE
Evan @Exedy Clutch
Offline
Old Oct 21, 2006, 06:58 AM   #28
chmodlf's Avatar
Drives: 03 EVO
EVOlutionary
As Mark Daddio once told me (if I remember correctly), r compunds in autox require much higher spring rates than a road course setup (900lb???). But then since many daily drive our evos, the ride would be just a bit stiff--even with mysterious magic super duper valving from the suspension tuner of your choice...Unless your world revolves around those autox runs.
__________________
For Sale:
Offline
Old Oct 21, 2006, 04:03 PM   #29
Interesting . . .
My car "seems" to handle great with the stiff suspension even on lower grip street tires. But then again, there could be a whole other level of grip I can't even imagine just waiting for me somewhere out there! I definitely want to check out some other setups next year when I attend a time attack, road race, or open track day/HPDE. It is cool how even with the same car, there are so many variations out there!
Offline
Old Jul 31, 2007, 06:57 AM   #30
Drives: Evolution 8
Send a message via AIM to point&shoot
So what spring rates are you using, evolutionary, and how did those spring rates work out for you this year, in AutoX? I'm trying to set up my Evo for AutoX, and am having trouble making the car loose enough. I went from the default Stance coilover springs (500F/450R) to (500F/550R) and that didn't seem to help significantly. I also have a 25mm Perrin rear sway bar set to full stiff, but its not enough. (This is on 255 width Kumho V700's, by the way, so I don't have a huge amount of traction.)
We're also having trouble with inside front wheel spin on corner exit. (I've got an '03 with the open front diff.)
I believe that there's becoming a consensus that you want about 1/3rd stiffer spring rates in the rear, than in the front, do you agree? I know at least one top driver is using 12kg front / 16 kg rear, for example.
Thanks.
Offline
Tags
cr, effect, evo, front, higher, husqvarna, increasing, motion, rate, ratio, rear, s2000, set, spring, versus
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
