Nov 14, 2008, 05:28 PM
Gold Sponsor
Personal Sales Rating: ( 42)
Drives: 2007 BMW 335i
Inside the CNC cylinder head program at AMS: The EVO X Head
Tim and the guys in the engine shop have been working pretty diligently on an engine program for the EVO X. With the great success we have had with CNC heads on the EVO VIII and IX we knew it was a must to develop a head for the evo X. I wanted to share a bit of the process involved in the CNC porting process
I am going to show you a series of pictures in sequential order of the CNC process. each will be labeled with a corresponding number, 1-4. Below are the descriptions of each stage of porting all the way up to the final product.
1. - As cast by OEM, this the way your stock EVO X cylinder head would look
2. - CNC ported: Note the un-machined areas in both the port and the chamber. These areas will vary from casting to casting. In some castings a port wall or roof may be left un-machined. This is due to the acceptable tolerances for castings, which allows for a greater amount of deviation in port location and shape than the CNC machining process. During CNC machining, an exact copy of the port shape and size is machined into the casting regardless of the variations in the casting.
Of course, you could modify the CNC program to machine the un-machined areas. This approach would result in the CNC "look" in all the ports, on all the surfaces. The drawbacks is the "modified" port would result in a larger than desired port volume and / or a port shape that is not the same as the originally developed port.
With all of the above considerations, it is our approach to cut the developed and tested port shape into a casting along with lightly hand finishing the un-machined areas in. This is not only more aesthetically pleasing, but proven to obtain the exact results our customers expect. The results are verified on our Superflow SF-600 flow bench by comparing each heads flow numbers after machining to the results of the original "master port"
3. - Hand finishing and blending; this step cleans any transition lines left during the machining process and blends in the previously mentioned un-machined areas.
4. - Finished; All surfaces polished along with a valve job and blending
Now onto some pictures showing this.
Lets start with the bowl area on the head.
First is the stock bowl on the EVO X. Again this is what your stock head is like
Here is after the first stage of porting or Step 2 listed above
Here is the bowl after the next stage in porting, step 3 listed above
And finally the finished bowl, this would be step 4 above
Now lets move to the exhaust port on the EVO X head
First is the stock exhaust port, step 1 listed above
Step 2 on the exhaust port
Step 3 on the exhaust port
Finally the finished product WOW!! step 4 listed above
Lastly we move to the intake port on the EVO X head.
What gets me the most about this is the sheer increase in size of the port after we are done.
Step 1 the stock port
Step 2, after the initial CNC work
Step 3, Some more hand finishing
The final product, WOW is that a great deal bigger and smoother!
There you have it! An inside look at the CNC porting program here at AMS for the EVO X
Eric
__________________
Eric Gaudi
-Sales Manager-
Eric@amsperformance.com
AMSperformance.com
Tel. 847-709-0530- World's QUICKEST EVO 8 - 8.42 with a best trap of 171 MPH
- World’s Most Powerful EVO – 1142 awhp
- 2008 AMS Racing – 40 Victories in Road Racing and Hill Climb
Offline
Nov 16, 2008, 09:12 PM
Personal Sales Rating: ( 6)
Drives: 2008 Evo, 1987 turbo Golf
Awesome stuff. Who did the original hand porting that the CNC is based off of? You guys don't have a CNC machine in house yet, do you?!
Are the valve guides installed in step 4? Do they not protrude into the port, even in stock form? If so, that is badass... wish my VW had that instead of the tapered valve guides I did as part of my P&P.
__________________
Nothing's for certain, it could always go wrong.
Come in when it's raining, go on out when it's gone.
Offline
Nov 17, 2008, 09:28 AM
Personal Sales Rating: ( 0)
Drives: srt-4
Looks great, now lets see what kind of numbers this will produce!
__________________
Quote:
Originally Posted by Mike@AwdMotorsports
Buschur Schlong FTW.. {thumbup}
WTF ^^^^^
Offline
Nov 17, 2008, 09:34 AM
Personal Sales Rating: ( 34)
Drives: 2003 Black and Silver Evo 8
This is a pretty big step towards makin some real power on the X. Do you guys have a HP goal you want to hit by spring?
__________________
Friends don't let friends drive Subaru's!
Friends don't let friends drive Honda's either!
A Former Corporal in the Marine Corps and damned proud of it!!
In Memory of my best friend and the finest man I've ever known,
"Jonathan Halase" 5-8-09
Offline
Nov 20, 2008, 11:38 AM
Gold Sponsor
__________________
Eric Gaudi
-Sales Manager-
AMSperformance.com
Offline
Nov 21, 2008, 08:57 AM
Gold Sponsor
__________________
Eric Gaudi
-Sales Manager-
AMSperformance.com
Offline
Apr 6, 2009, 08:53 PM
I must say, well done on reducing below 0.250" lift flow numbers. Not many people realise how little the valve open area is around that duration and that it is were reversion occurs.
__________________
Cyclone DASH 2
Offline
Tags
2005, ams, cnc, cylinder, evo, head, heads, il, illinois, performance, polished, porting, ports, volume, vw, wanted  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
