View Poll Results: why do you tune with the s-afc? you can select more than one
I'm comfortable with it and it's easy
12 |
54.55% |
I don't think timing control is that beneficial
0 |
0% |
it's inexpensive
7 |
31.82% |
I don't have a laptop
1 |
4.55% |
I'm making good power
3 |
13.64% |
I didn't know there's free software to tune an evo
0 |
0% |
I'm aware of ecuflash but it's too complicated
3 |
13.64% |
other - please make a post and explain
4 |
18.18% |
May 12, 2007, 07:26 AM
Silver Sponsor
Personal Sales Rating: ( 28)
Drives: 05 EVO & 91 Stealth TT
Why are you using the S-AFC?
I'm curious. Why are you using the S-AFC to tune an Evo? please vote in the poll and make a post to explain your reasons.
let me be clear, this is not an attack on S-afc users, I used one for a long time on my stealth and really liked it, but once I realized that by cheating the ecu on airflow was causing timing to drift out of tune I had to find another solution. I went to the greddy e-manage + e-01 and loved it. Now that I have an EVO I'm using ECUflash since it gives me full control over:
air/fuel
timing
2-step launch rpm
rev limit
boost cut defeat
and more
the best part is that it's free and there's free logging software. all you have to buy is the tactrix usb to odbII cable, no more tapping into the stock ecu wiring etc... and I can move it from car to car in seconds to help out friends. If you don't know how to tune it, there are plenty of people that can make a tune for your car and their is lots of support if you'd like to learn. If you already own a laptop, I think this is the way to go, hands down.
I'd like to hear your reasons for using the s-afc.. thanks
Offline
May 13, 2007, 01:49 PM
Personal Sales Rating: ( 1)
Drives: 04 EVO
I use it to tweak my tune at the track....i know its old tech stuff, but nothing is faster or easier.
Online
Jun 7, 2007, 10:51 PM
Personal Sales Rating: ( 11)
Drives: 04 SSL Apex Silver Evo
Mellon, I am not an expert by any means on current EVO-direct ECU tuning, so what I am going to say next I have learned from my tuner.
He has locked my timing, that way I can play with the S-AFC-II and the timing will stay the same and only the fuel ratio will change.
That can be done, and the days of timing drifing and the tunes going wild are a thing of the past.
I am, an AFC expert, however. So I continue to use it, but very limited. Jester has perfected my tune, and I only touch the AFC to fine tune the A/F's on rare occasions while using different mixes of fuels.
__________________
556~whp 522~wtq FP-Red HTA80MM
JestR Tuning & Pollo Performance
Offline
Jul 10, 2007, 11:00 AM
Silver Sponsor
not much feedback to this thread, bumping to see if I can get more people to vote and leave feedback
Offline
Jul 10, 2007, 01:23 PM
Personal Sales Rating: ( 5)
Drives: Curzio's mom
hmmm, the only way you could "lock the timing" would be block fill the timing map so that all load cells have the same timing value at a given rpm. With the AFC you are adjusting the maf signal, ecu uses the maf to calculate load so if you remove fuel you lower the load, if you add fuel you raise the load and hence you will drift from cell to cell and timing values will change unless adjacent cells have the same timing values.
__________________
Wicked White GSR SSS 93pump - 363 awhp @ DYNO4MANCE Dyno Dynamics with 1.0 C.F. (448 hp shootout) Blouch Dominator 1 | Cosworth MX1's | HKS EVC VI | Ultimate Racing 02 Back | RC 750cc | DYNO4MANCE EcuTek Tune Old Whip: 93pump 21psi - 340 awhp @ DYNO4MANCE Dyno Dynamics with 1.0 C.F. (~392 dynojet) L.Y. VIII | DYNO4MANCE Tuned AEM EMS | HKS 272's | FPGreen | Cusco Twin | Shep Stg2 TC | KW V3's | TE-37's
Offline
Jul 10, 2007, 01:35 PM
Silver Sponsor
Quote:
 dead on
Offline
Jul 21, 2007, 05:22 AM
Silver Sponsor
FYI, I've since updated my website to include some information on how to tune with stock ECU
Offline
Jul 29, 2007, 06:23 PM
Personal Sales Rating: ( 0)
Drives: evo ix gsr
i just bought en evo 9 gsr. already installed basic mod with hks reloaded kit&apexi grounding. if i use afc-neo, how much hp will i achieve?i'm targetting just 290hp.
Offline
Aug 4, 2007, 09:33 AM
Drives: no more Evo
I use dthe AFC until i got Ecuflash. AFC is easy to tune and you can make adjustments on the fly. But with Ecuflash I no longer see a reason to use the AFC. Mine sits in a box in the grage til I out it up for sale.
Offline
Aug 27, 2007, 07:09 AM
Drives: Red Evo 9 MR with 20 g
will the afc allow me to keep a default tune and change it as a go along
__________________
Red EVO9MR
" there is a replacement for displacement, tuuurbooo"
Offline
Sep 21, 2007, 11:04 PM
Personal Sales Rating: ( 8)
Drives: goggles and a speedo
Never used a SAFC and glad I never did but some people were fairly lucky with the unit. Just by altering the MAF signal (what the safc actually does) the timing and AFR values were just right for one individual that after a tank of racegas he managed to run 12.00 flat in a 1/4 with just TBE and MBC.
But still it's just a one dimensional tuning device, you can do the exact same thing by changing the maf values with ecuflash. But I can see some use for using both the safc and ECUFLASH for toying around
Offline
Oct 19, 2007, 07:17 PM
Drives: evo ix gsr
mine just basic modification (hksrs kit, blitz nur spec, nology hotwires, apexi grounding) the rest is stock. i havent use boost controllers. some ppl prefers to use just afc neo to sort it out i mean for safety reason. but yesterday, i spoke to the japanese tuner, he said it's useless if u go for afcneo. so he suggested using hks evc with 1.2 set on low boost and 1.4 bar on high boost. what do u guys think?
Offline
Jun 7, 2008, 09:07 AM
Drives: 2003 Evolution
But if I don't have the cable, nor a laptop, the ECUflash is a considerably more expensive method for tuning.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
