Dec 13, 2006, 06:18 AM
Personal Sales Rating: ( 9)
Drives: Evolution IX - From home to work to school..
Stupid Question
I am planning to get one of these for xmas, and I wanted to know if I can set it to run zero boost - and is that safe on the engine? or am i better off with just 3-5 lbs
I dont want the car to be boosting while I am cruising or driving around town.
Offline
Dec 24, 2006, 10:45 PM
Personal Sales Rating: ( 14)
Drives: his BBK on 26lbs
this is not a boost controller. the SAFC I/II controls your feul, timing, etc. just drive under say 3k on partial throttle and you should be able to not boost high...
this is a stupid question. why buy an evo if your not gonna boost. boost doesn't make your car less efficient in mileage, i'm assuming your try'n to get at.
Offline
Dec 24, 2006, 11:15 PM
because i had 30K cash to blow!!!!
Offline
Dec 26, 2006, 02:56 AM
Personal Sales Rating: ( 2)
Drives: 2008 STi.
wow. This was a stupid question and that above post makes you a stupid owner. lol
Offline
Dec 26, 2006, 02:57 AM
Personal Sales Rating: ( 3)
if you want zero boost, remove a charge pipe >__>
Offline
Dec 26, 2006, 02:59 AM
Personal Sales Rating: ( 27)
Safc is def not a boost controller.
Offline
Dec 26, 2006, 02:10 PM
ok ok , i realized I posted on the wrong thread... I meant a AVC-R.... give me a break.
Offline
Dec 26, 2006, 02:11 PM
Quote:
im glad ur amused
Offline
Dec 26, 2006, 02:17 PM
Personal Sales Rating: ( 0)
Drives: 03 WW Evo VIII
Yes you can set the AVCR to 0.00, why you would want to I have no idea and I might be wrong but I believe it would still run at wastegate pressure regardless so you would still be running boost, just a very miniscule amount. Lowering your boost will not save you gas milage you will just be running rich as hell
Offline
Dec 26, 2006, 02:18 PM
This is assuming of course that you are doing this for gas milage
Offline
Dec 26, 2006, 02:40 PM
but I could turn it down to something like 8PSI or lower if I let my g/f drive it right?
I guess you would have to tune the car to run at lower boost on a regular basis if you wanted better gas mileage
Offline
Dec 29, 2006, 04:42 PM
just tell her to not drive it too hard or push the pedal too much.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
