Oct 2, 2006, 09:57 PM
Personal Sales Rating: ( 15)
Drives: Like a baby back *****
Will my Safc mess up my flash?
I just got a SAFCII to install in my car so that I can be able to swap between my flash map and a high octane map. I am wondering when I put my SAFC in will that change the tune on my car because it is not set on the SAFC.
__________________
09 UCF Formula SAE Race Car
06 EB EVO IX
372whp/356wtq 11.8@116 1.75 60' Stock turbo, cams and 93 octane
UNDER CONSTRUCTION
Online
Oct 3, 2006, 12:49 PM
Personal Sales Rating: ( 1)
Drives: 04 RS
It will not change the tune on your car if you leave all the RPM settings (hi and low) at 0%. At 0% it's making no changes to the airflow signal so it's like the AFC is not even there.
Offline
Oct 3, 2006, 01:12 PM
Personal Sales Rating: ( 21)
Drives: Nothing
Just take out the numbers that I had in... you will be fine!!
Offline
Oct 3, 2006, 01:13 PM
Personal Sales Rating: ( 2)
Drives: 2006 Mitsubishi Lancer Evolution MR
Why waste the money on the S-AFC, when you could just spend 85 dollars on a tactrix cable and use Ecuflash?
__________________
Evo IX MR Wicked White
Arrived:2-27-06
Mods:
-Perrin Shorty
-Debadged
-3" Turboback (Buschur 3" SCCA Cat-back, Buschur 3" DP, UR 3" Test-pipe)
-Buschur LICP
-Walboro 255lph FP
-Dynoflash Custom Tune (beastly)
Planned Mods:
-The Driver Mod
-K&N Drop-In/HKS RS/Works Drop-In (can't decide)
Offline
Oct 3, 2006, 01:18 PM
Personal Sales Rating: ( 10)
Drives: 2006 EVO IX
Quote:
+ 1million
Offline
Oct 3, 2006, 01:25 PM
Drives: 06 GG IX MR. 03 LIGHTNING YELLOW EVO VIII(traded), 95 MUSTANG GT
sure you could do that and flash your car everytime you feel like running race gas. then flash it back when you are done, or you could buy an afc and just lean out the tune a little.
__________________
Quote:
Originally Posted by giangi
I knew that, concerning european evos, power declaration is 276 bhp ( british horse power )
Quote:
Originally Posted by DaWorstPlaya
That's what mid-engines mean ... mid engine = rear engines ... all rear engine cars are called mid-engines, fyi
Offline
Oct 4, 2006, 01:04 AM
Yea but it is much quicker to just change your map on the SAFC. Also it would be cheaper to get an $85 plug but you forgot to add on the price of a laptop.
__________________
06 EB EVO IX
UNDER CONSTRUCTION
Online
Oct 4, 2006, 09:28 AM
Personal Sales Rating: ( 13)
Drives: 04 Evo 11.18 @ 131 with 1.86 60ft
well the thing about that is how you tune your car. If you have and afc its better off to keep it unless you need the money. When the weather changes its a pain to retune nothing big just a pain. So you have two different files that you use. I have heard of it being a problem at high rpm with your timing but im not sure on that.
Offline
Oct 4, 2006, 09:57 AM
Drives: 2005 Mitsu Evolution VIII
From what I have heard, it well help if anything because you can fine tune the flash and put in race gas and lean the car out to the desired afr and gain more power. I always suggest to people that have one to also do the other...If I wasn't going with an AEM thats what I would do.
__________________
100mm Eagle 2.3 crank/MAPerformance Ultimate Duty Rods//Weisco Pistons//Mild Head port//HKS 272/272//AEM EMS tuned on E85//FP Red//QM Twin Disc
Offline
Oct 4, 2006, 10:04 AM
Personal Sales Rating: ( 65)
Drives: TURBO cars only !!!!!
I utilize my AFC only as a monitoring device.
__________________
Oz
2003 Tarmac Black Evo 8 (A.K.A Mr. Clean)
My Evo
Powered by Buschur Racing!
Reese Tuning - Corn Juice coming! - MD 500
ROBISPEC ///
"The boost-induced adrenaline rush that is an aggressively tuned TURBO
car pulling at the reigns in anger is profoundly tempting. Evan Griffey TM"
Offline
Oct 4, 2006, 11:14 AM
I am just using it to switch between both maps.
__________________
06 EB EVO IX
UNDER CONSTRUCTION
Online
Oct 4, 2006, 11:59 AM
Personal Sales Rating: ( 4)
Drives: 2006 EVO IX MR
Doesn't the Ecu recognize high octane and low octane fuels? If so why would you need an S-AFC?
Offline
Oct 4, 2006, 12:04 PM
Quote:
I don't think so. Also I have been tuned by TTP and I am going back to get another flash for 110 octane and about 26-28 lbs of boost. I am using the safc for its ability to swap between multiple maps.
__________________
06 EB EVO IX
UNDER CONSTRUCTION
Online
Oct 4, 2006, 12:28 PM
Is there any difference between the VIIIs and the IXs when it comes to SAFC tuning?
Offline
Oct 4, 2006, 04:00 PM
Quote:
Instead of a flash? I would rather spend the money on the flash since they get to mess with the mivec.
__________________
06 EB EVO IX
UNDER CONSTRUCTION
Online
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
