Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Apex-i S-AFC / S-AFC II
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 3, 2006, 09:56 PM   #1
Personal Sales Rating: (0)
Drives: ATR
SAFC2 tuning question
Hi all, I've had my SAFC2 installed.
The raw reading of the knock sensor is ~80 at idle, ~120 at 3500rpm and I've since calibrated it.
Armed with a APEXi Turbo Timer, Knock Sensor and my butt, i proceed with my butt tuning.
My NE points are:
800rpm, 1200rpm, 1600rpm, 2000rpm, 2600rpm, 3000rpm, 3600rpm, 4000rpm, 4600rpm, 5000rpm, 5600rpm, 6000rpm
Lo Th: 30%
Hi Th: 50%
First, I proceed with -10% at 800rpm, Lo Th and get about 5 to 10knocks and I adjusted it back to -8%.
Secondly, I proceed tuning the 1200rpm to 3000rpm Lo Th range.
Surprisingly, by adjusting to even -13% throttle, I am not getting a lot of knocks !
The max I get is ~70+ knocks if I use the peak reading.
The above varies a lot from the rest of the data I read, which hardly tune anything lower than 3000rpm.
Is the ECU compensating and overwriting my SAFC2 data reading, thus I am not getting any significant knocks in closed loop ?
However, I do find the car a bit perkier now for city-type stop-and-go traffic condition.
Any valuable advise ?
Offline
Old Sep 4, 2006, 12:16 AM   #2
Personal Sales Rating: (1)
Drives: 04 RS
Quote:
Invest in some type of logger. The knock readings off a S-AFCII are not accurate.
http://www.evotuners.net/forums/showthread.php?t=315
Since you have the Apex TT you can do an old school tune off of the O2 voltages, but it is what it is... scroll down to Initial AFC Tuning (Low);
http://www.roadraceengineering.com/newafc.htm
Offline
Old Sep 4, 2006, 12:36 AM   #3
Personal Sales Rating: (2)
SiCKlEyWiKeD's Avatar
Drives: 08 TSX - 09 ZX10
Send a message via AIM to SiCKlEyWiKeD
dude you are out of your freaking mind. put the settings back on zero and do not, I repeat DO NOT tune a freaking safc without a wide band or on a dyno. F'n newbs
__________________
-Manny-
12.0 @111 Stock DP, Helix tp and Catback, MBC, intake, and meth. Tuned by me!
My drag pass:
http://www.youtube.com/watch?v=J4A3RN8YU3s
Latest Photoshoot of my Evo By Vboy301
http://forums.evolutionm.net/evo-show-shine/250688-vboy-sh00t-wickeds-wicked-white-factory-time.html
Offline
Old Sep 4, 2006, 10:24 AM   #4
cpoevo's Avatar
Drives: no more Evo
Dude a v minimum you need to be able to log timimng and O2 voltage. I would never tune my car that way though. I would recommend a minimum of WB O2 and a way to log timing. Bad things can go wrong real fast, bad things go wrong even faster if you have no way of monitoring.
Offline
Old Sep 16, 2006, 09:42 PM   #5
tony gibson's Avatar
Drives: 2005 Mitsu Evolution VIII
These guys are correct^^^ATLEAST a fucntional wideband...the ecu will pull timing long before the motor will blow while using an AFC...unless you are being ungodly stupid with the settings....Get a wideband and tune it for about 11.5 and below on pump gas. The more boost you run, the less timing the ecu will give you...and vice versa. Good luck.
__________________
100mm Eagle 2.3 crank/MAPerformance Ultimate Duty Rods//Weisco Pistons//Mild Head port//HKS 272/272//AEM EMS tuned on E85//FP Red//QM Twin Disc
Offline
Old Sep 18, 2006, 03:45 PM   #6
Drives: 95 Talon TSi,06 EVO IX,04 350Z TT
Arrow safc
FYI,knock reading on the SAFC is not very accurate.Go to a DYNO and tune with a WB.Good luck man!
Offline
Old Sep 18, 2006, 04:20 PM   #7
Personal Sales Rating: (42)
xspsi4's Avatar
Drives: evo 1 gsr/ evo ix mr 5spd
You should be ok with minus 8% although I would not push it any further with out a wb
Offline
Old Oct 4, 2006, 09:30 AM   #8
Personal Sales Rating: (13)
EVOB23's Avatar
Drives: 04 Evo 11.18 @ 131 with 1.86 60ft
After a while it will come natural to tune the car with the afc
Offline
Old Oct 13, 2006, 11:14 AM   #9
Personal Sales Rating: (12)
wickdaddy's Avatar
Drives: Tarmac Black Evo VIII
Send a message via AIM to wickdaddy
i don't have an evo, but i have a turboed oz (no flames please lol) i have been reading up on tuning with my safc. I have a air/fuel guage, but it doesn't have the digital numeric numbers that i have seen on widebands... is this just a not as cool wideband, like do i need to have the numbers to properly tune or can i just go by the meter of rich and lean??
__________________
三菱
tb8 gsr
Stock Turbo @ 24 psi // GSC 264 cams // APR Head Studs
Walbro 255 // 680cc injectors
RSR DP // JIC full Ti Exhaust // ACT Ceramic Single Disk // MR BOV
Defi Amber Boost, Water, EGT + Monitor // PLX Wideband
301awhp: Dynoflash tuned @ Buschur
FS: BNIB FIDANZA FLYWHEELS
green cloth
Offline
Old Oct 27, 2006, 11:28 PM   #10
Drives: 2005 SRT-4
Quote:
No to tune properly you're going to need wideband. Narrowband o2 will not give you anywhere near enough of an accurate reading. Wideband isn't just a pretty gauge... Narrowband will give you Rich/Stoich/Lean and that's it for readings. Wideband will give you a much broder reading and much more accurate. A MUST for tuning without a dyno.
Offline
Old Oct 28, 2006, 10:39 AM   #11
wickdaddy's Avatar
Quote:
icic well I guess that I am just going to have to maybe go out and eventually get a wideband if I am going to get my car tuned up totally. off the top of your head, do you know if the ECUflash program does the wideband readings? if it does than I might just get that cable!
__________________
三菱
tb8 gsr
green cloth
Offline
Old Oct 28, 2006, 11:30 PM   #12
Drives: 2005 SRT-4
No sorry I don't, I'm a srt-4 right now, awaiting the sale of the car so I can get an evo.
Offline
Old Oct 29, 2006, 12:07 PM   #13
wickdaddy's Avatar
oh duh... i probably should have looked at your profile
__________________
三菱
tb8 gsr
green cloth
Offline
Old Nov 16, 2006, 09:17 PM   #14
tuning a FUEL controler without a wideband is a little silly dont ya think?
__________________
FOR SALE - NEW Invidia N1 catback for EVO 8/9 $450 shipped
Offline
Old Nov 17, 2006, 05:19 AM   #15
wickdaddy's Avatar
i'm not sure what the guy was using when he was tuning my car. at that time, i wasn't real sure about tuning and stuff and just needed my car to idle decently... now i would like to get it totally dyno tuned...
__________________
三菱
tb8 gsr
green cloth
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
