Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Apex-i S-AFC / S-AFC II
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jun 28, 2006, 02:09 PM   #1
Personal Sales Rating: (15)
Kilratio's Avatar
Drives: Evolution 8
New Owner needs help!!! SAFC/ECU
Hi all, I just bought my first evo this weekend and I'm already having problems, the idel is a lil ruff and when i let off the clutch it sometimes stalls ( I did notice some posts about possible blowoff valve related problem .. /shrug) and the check engine light came on today after I disconnected the battery to reattach the hks downpipe boot that came off my licp while driving on the highway this morning (scared the heck outta me when it dumped all power in high revs in 4th.) anyways the car has a apexi SAFC and I was told It has a Dynoflashed ecu. I think disconnecting the battery either reset my ecu or the safc , I'm no tuner and have no idea how to fix this problem .. I set up an appointment with Topspeed in Atlanta for next week to look at my car , and retune the safc however is there a way to disconnect the safc till then? also it has a mbc set at 21 psi, Is this throwing a light? oh and the other day i droped a stage 2 clutch and a fidanza lightweight flywheel in ..could the new flywheel be throwing it off? anyway ...Thx for any help You folks can give....what I guess im asking is should i disconnect the safc till i get it looked at, and how do I do it.
mods dynoflashecu, hks dp and bov, mbc,apexi turbotimer, apexi SAFC,stage2 clutch and lightweightflywheel
Offline
Old Jun 28, 2006, 05:15 PM   #2
Personal Sales Rating: (16)
nicksalerno80's Avatar
Drives: 05' EB VIII
First, your stalling problem could very well be your BOV, 03-04 don't handle VTA bov's to good. As for the check engine light, get your car scanned to see what code you threw, that makes it a lot easier to see what the problem is. For disconnecting the SAFC, you need to check and see if the person you got it from either spliced the cables in or used the plug and play harness. If it's spliced in, I would just leave it and you could just set all your corrections on it to zero, so that it is not changing any of your air-fuel. Hope this helps......
Offline
Old Jun 28, 2006, 05:32 PM   #3
Personal Sales Rating: (1)
machron1's Avatar
Drives: 2003 Rally Red EVO
Send a message via ICQ to machron1 Send a message via AIM to machron1 Send a message via MSN to machron1 Send a message via Yahoo to machron1
Dunno why people use SAFC w/ an ECU flash. Friend of mine is planning on doing both :shrugs:. if you have a VTA BOV plumb it where it's supposed to. Also do a boost leak check. One of my hoses popped off after my clutch install because they didn't tighten all the clamps properly. Definitely get it tuned if you don't know what you are doing. For all you know you could be running dangerously lean.
__________________
Quote:
Originally Posted by Grandma's Boy Movie
Kane: "I think that the music was a little loud."
JP: "Are you afraid of it?"
Kane: "No, I...I just don't like techno..."
JP: "You would if you had robot ears." ::rollseyes::
Offline
Old Jul 4, 2006, 02:42 PM   #4
Personal Sales Rating: (9)
EiEVO's Avatar
Drives: 03'EVO VIII & 04' Element (toaster)
Quote:
I run a flash and a safc just because i can fine tune the car and when i do a bolt on here and there i can compensate for it easily. It takes most the time and effort out of the way. I love having the safc to the addition to my flash. I also have the open ecu software and cable to make any major adjustments but like i said its nice to have the safc at hand while driving so i can fine tune. For example i added a manifold, o2 housing and a 10.5 hotside the other day and i got it dialed in perfectly with a few pulls. And btw: i love it now with the additional mods. The car sounds awesome now and pulls much harder.
__________________
03' RR VIII
04' HONDA ELEMENT
Offline
Old Sep 13, 2006, 06:17 PM   #5
Personal Sales Rating: (0)
Drives: 03 Evo VIII
I just installed the safc 2 but having problem setting it up. On the Sensor Type menu I can't choose Karman. Everytime I click Nx or push the center scroll right it just brings me back to the previous menu. All other type of sensor I select is ok. Can anyone help?
Offline
Tags
disconnecting, safc
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
