Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Apex-i S-AFC / S-AFC II
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Apr 14, 2006, 05:56 AM   #1
Personal Sales Rating: (9)
WongFu's Avatar
Drives: The Autobahn every day!!!
Send a message via MSN to WongFu Send a message via Yahoo to WongFu
SAFC@ with aem uego
i was woundering has anyone else just took out their rear o2 out and used the wide band there? what numbers do you get? i also have BR settings and my numbers are high till im really on it
Offline
Old Apr 14, 2006, 07:33 AM   #2
Personal Sales Rating: (1)
Dnealy's Avatar
Drives: Bottle fed z06
Just curious but wouldnt removing the rear o2 throw a CEL? I would just order a new bung for a few dollars and weld it in about 24 inches from the turbo and run the wideband in there. Thats where i have had the most reliable results at in the past.
Dustin
Offline
Old Apr 14, 2006, 09:03 AM   #3
Personal Sales Rating: (0)
bongtastic's Avatar
Drives: Talon
I would agree, I'd think you'd want the sensor as close to the exhaust port as possible to get the most accurate and quickest readings but not so close as to be biased to a particular port's exhaust .
Offline
Old Apr 18, 2006, 05:20 PM   #4
Personal Sales Rating: (12)
r.m.s.'s Avatar
Drives: 2005 WW RS
Quote:
Good post.
__________________
HAR Racing
Offline
Old Apr 25, 2006, 11:42 AM   #5
emolution's Avatar
Drives: 03 Evo
Send a message via AIM to emolution
i have mine in the rear bung and it seems to work quite well. i did throw a cel, but i already did because of my test pipe.
Offline
Old Apr 26, 2006, 12:50 AM   #6
EVSEVO8's Avatar
Drives: SOLD 03 EVO 8 GSR, 2008 PB EVO X MR
If your Cat is in then the wide band will not read correctly. The cat is their to burn out emmision gasses. Probably would get a lean reading.
__________________
Everett (EVSEVO8)
NORTHWEST EVOLUTIONS
Offline
Old May 28, 2006, 04:00 PM   #7
WongFu's Avatar
its fine i run mine the same way. just slower response time. but you will always throw a 0136 and a 0141
Offline
Old May 28, 2006, 04:25 PM   #8
spudlus's Avatar
Drives: One gear @ a time
It wouldn't hurt to just get a bung and weld it in.
__________________
'03 Evolution VIII
HKS 272 Int\Exh + HKS Adj. Cam Gears
AEM Short Ram Intake
PWR IC + Injen Hard IC Piping
Forge BOV + RMR MBC
O2 Housing + 3" TBE
HKS S-AFR
You only need two tools: WD-40 and Duct Tape:
If it doesn't move and should, use the WD-40.
If it shouldn't move and does, use the duct tape.
Offline
Old May 31, 2006, 10:41 PM   #9
djmikeymike's Avatar
Drives: 2003 silver evo 8
it cost me 30$ to get a bung welded on......... if u spend the money for the wideband wouldn't u want the correct reading????
__________________
Injen Intake
Blitz i-D III EBC @ 21.5psi
APS DV
SAFC II
XD-1/LC-1 WideBand
Lancershop SS kit
SS Clutchline
Helix Turboback (Ur HFC)
Walbro 255
ECUflash + EVOScan self tuned
Next Mod: sell SAFCII
Offline
Old Jun 4, 2006, 08:25 PM   #10
Mase's Avatar
Drives: More than one
id put the wideband about 20 inches or so away from the turbo.
that would be ideal.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
