Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Apex-i S-AFC / S-AFC II
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Apr 13, 2006, 05:19 PM   #1
Personal Sales Rating: (11)
MitsuEvoIIX's Avatar
Drives: 2005 TB Evo 8
Question Pulling fuel on stock turbo with 680's
Since im running pig rich and need to get a tune is it safe to turn down the fuel at -10% across the highs and lows until i get tuned?
__________________
Megan TBE
HKS 272/272
Hallman MBC
Cone Filter
Precision 680cc
SAFC-II
Tein Flex
20g-9-5
P&P Manifold
Ebay 02 Housing
370whp 380tq ?psi(my gauge was off) 93oct
Offline
Old Apr 13, 2006, 07:11 PM   #2
Personal Sales Rating: (0)
o4whtevors's Avatar
Quote:
no its not. do you have a logger?
__________________
the evo dream is real
Offline
Old Apr 13, 2006, 07:18 PM   #3
EvoRecordSetter's Avatar
Drives: @ Track for who ever wants to see what their car can do ;)
i would just wait until i could get some sort of A/F Readings... anything else is at your own risk. 5% isnt that much of a difference, im not recommending anything but if you want maybe do a little changes. dont do anything drastic without seeing A/F.
Offline
Old Apr 13, 2006, 11:40 PM   #4
Quote:
i know, thats y im asking b/c it says to start out leaning 20% out across the board and then make adjustments. so i figure -10% across the board with no adjustments should be sufficient? I ran the car like this today and it feels A LOT better than it did.
__________________
Megan TBE
HKS 272/272
Hallman MBC
Cone Filter
Precision 680cc
SAFC-II
Tein Flex
20g-9-5
P&P Manifold
Ebay 02 Housing
Offline
Old Jul 3, 2006, 04:58 AM   #5
Personal Sales Rating: (9)
DRFTKNGG's Avatar
Drives: an evo addicted to METH!
Get your self a wideband before even attemping. Just watch a/f's. We want them to be around 11.4-12.0 under wide open throttle. Each car is different in respect to what air fuel ratio it likes, or runs the best at.
Offline
Old Jul 3, 2006, 08:02 PM   #6
Silver Sponsor +1
Personal Sales Rating: (445)
TTP Engineering's Avatar
Drives: 2008 Evolution GSR SSS, 2005 Evolution MR, 2003 Evo GSR, 1995 TsiAWD, 1995 GST, 1995 Tsi 2wd, 1991 GVR4 WW, 1991 GVR4 NBM, 1993 TsiAWD, 1991 Tsi, 1995 RS N20
Send a message via AIM to TTP Engineering
It would be about -17% however, a datalogger monitoring front O2 voltage would be the cheapest route outside of getting on a dyno. With a logger, you can at least monitor ignition timing. AFR at different gears and loads would be different. Lower the gear, the leaner the AFR. Keep that in mind.
__________________
2005 Evolution VIII MR
763whp/595tq HTA86
10.19 & 143.3mph stock ECU
Factory ECU Expert
2008 Evolution X GSR
12.0@113mph Full Wt+
In House Mustang Dyno AWD-500!
www.ttp-engineering.com
(407) 475-0010
AIM=TTPEngineering
MODIFYING THE 4G63 SINCE 1995, YES 14 YEARS!
TUNING EVO V - EVO X & 2009 RALLIART!
TTP's Myspace page!
Offline
Old Jul 4, 2006, 02:35 PM   #7
EiEVO's Avatar
Drives: 03'EVO VIII & 04' Element (toaster)
yea you should get a wb and until you do i wouldnt advise doing a whole lot with messing with the safc. Its for your best interest.
__________________
03' RR VIII
04' HONDA ELEMENT
Offline
Old Aug 20, 2006, 10:56 PM   #8
Personal Sales Rating: (8)
GoneIn420's Avatar
Drives: '05 WW Evo
Like everyone said, get a wideband to check for sure. But you don't want 10% across the board, you want to ramp it up to @15%-17% incramentaly from my experience. Also, I added 2-4% fuel before the turbo spools at @ 2600-3200 rpms to help spool-up. Please do road tests before you accept any fuel trims permanently. Any stumbles, pauses, cracks, creeks, anything that sounds and feels wrong, most likely is. Peace.
__________________
" IF YOU CAN,T SMOKE THE TIRES FROM A 60 MPH ROLLING START YOUR ENGINE NEEDS MORE WORK!!"
Lotz 'o $hiz!
Check out my ride @ CarDomain: http://www.cardomain.com/ride/2149339
Offline
Old Aug 21, 2006, 08:17 AM   #9
Silver Sponsor +1
Quote:
Originally Posted by GoneIn420
Also, I added 2-4% fuel before the turbo spools at @ 2600-3200 rpms to help spool-up. .
Add fuel does not help spoolup. It slows it down...
__________________
763whp/595tq HTA86
Factory ECU Expert
(407) 475-0010
AIM=TTPEngineering
TTP's Myspace page!
Offline
Old Sep 19, 2006, 11:18 AM   #10
turboj's Avatar
Drives: evo V RS
would 780cc still be ok with his setup? I am currently on that route also... but I'm planning to get a bigger turbo sometime next year, but the injectors i'll be ordering by this oct. Should i get the bigger one since it'll be anticipating turbo anyway? Would it run ok with the safc? And how big is the gain by doing this?
Offline
Old Sep 19, 2006, 11:29 AM   #11
Silver Sponsor +1
Don't waste your money on larger injectors until you have the turbo in your hand. THERE IS ZERO PERFORMANCE GAIN OR BENEFIT TO LARGER INJECTORS ON A STOCK TURBO EVO.
You are just throwing money in the wind. Furthermore, count on another $350 to get tuned just so you can run the injectors with no gain in HP over the stock 560's.
__________________
763whp/595tq HTA86
Factory ECU Expert
(407) 475-0010
AIM=TTPEngineering
TTP's Myspace page!
Offline
Old Sep 24, 2006, 08:52 PM   #12
Personal Sales Rating: (1)
tony gibson's Avatar
Drives: 2005 Mitsu Evolution VIII
^^^Agreed....I learned the hard way lol....I have 660cc on the stock 05 turbo with cams and have 22-25% past 5000rpm pulled out on pump gas at 19 psi and I am at 3000ft elevation and this yields an 11.5 afr at wot fyi....BUT I would not suggest using these settings without a wideband but I would start at 17-20% once you have a wideband and fish between 11.0-11.5 on pump gas and see what the car likes. I have had to tune by the wideband and buttometer for a awile because there are no AWD dynos near by. Good luck.
__________________
100mm Eagle 2.3 crank/MAPerformance Ultimate Duty Rods//Weisco Pistons//Mild Head port//HKS 272/272//AEM EMS tuned on E85//FP Red//QM Twin Disc
Offline
Old Sep 24, 2006, 09:00 PM   #13
turboj's Avatar
Drives: evo V RS
So what would be a good injector size for the 20g-9? What effect is there really if I got say 780cc compared to 680cc's? Would the 680cc's be good enough?
Offline
Old Sep 24, 2006, 09:02 PM   #14
Silver Sponsor +1
Quote:
Stock 560cc injectors should be sufficient on 93 octane. If you are limited to 95RON in the Phillipines, you may consider 680's.
__________________
763whp/595tq HTA86
Factory ECU Expert
(407) 475-0010
AIM=TTPEngineering
TTP's Myspace page!
Offline
Old Sep 24, 2006, 09:17 PM   #15
turboj's Avatar
Drives: evo V RS
I see, just trying to find out which injector size i should be aiming for... thanks man!
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
