Mar 23, 2006, 05:54 PM
Guest
Personal Sales Rating:
intercooler tune?
I currently have a BR TBE, BR cone filter, BR MAF PIPE w/ Breather filter, BR UICP, BR mini battery, 1g bov, dyno flash, SAFC II w/ Buschur settings, turbo xs MBC.
My question is, I'm planning to install the BR racing intercooler with lower intercooler piping, Will I need to install a 255lph fuel pump or not? I'll be running stock boost. Also, if I don't need the fuel pump, will I need to retune or will it be ok til I get my data logger?
Mar 23, 2006, 10:37 PM
Personal Sales Rating: ( 9)
Drives: 2000 honda si turbo..sold 03' Rally Red BPU+
You pretty much have the same mods I have, and I have the mail in flash. I was still running very rich with those mods, 10.7afr to be exact and I do have a walbro fuel pump. I used the afc to tune to 11.1. Running about 16 degrees @ 7000 rpm 20 psi. You probably wont have to retune, but I am running boost off ecu @20psi flat so not sure. Just borrow a wideband and dial it in.
__________________
Quote:
Originally Posted by DynoFlash
Anyone buying a $30,000 car is a fool if they dont have it custom tuned by a good tuner
www.houston-imports.com
Offline
Mar 23, 2006, 10:45 PM
Guest
My only problem is that I don't have any way to get it tuned when I put the intercooler on. I was thinking that if it would be safe to go ahead and put it on, I could get the fuel pump and take it somewhere that we could see what's going on b/c I'm still in the process of getting a datalogger. I just don't know if I would run too lean once the intercooler's on. The last time that the ecu was flashed was when I put the intake and tbe on.
Mar 23, 2006, 10:51 PM
Personal Sales Rating: ( 7)
Drives: 06 BR350IX#005 apex silver with ssl (sold) 07 BMW 335i coupe 6MT w/sport package
with your mods i,m suprised Al tuned you without a fuel pump, you should get it for sure. and you dont need to be retuned with the ic piping
Offline
Mar 23, 2006, 10:53 PM
the intercooler has nothing to do with the tune
Offline
Mar 23, 2006, 11:19 PM
Guest
Well, he tuned the car when I had just intake and tbe. I'm definitely getting the fuel pump and then getting a new tune. Thanks for the help everyone.
Mar 23, 2006, 11:29 PM
thats why i,m suprised he tuned you without the pump,because of the intake,i could be wrong but he wont tune anyone with that setup anymore without a pump
Offline
Mar 25, 2006, 07:36 AM
Guest
Well, I decided that I'm gonna go ahead and install the ic and piping and change out the crappy turboxs mbc to a forge, order the fuel pump, and then take the car to vip garage and have warrtalon tune the car with everything on it. I had the turboxs bc on the car since I bought it and didn't realize that it was such a piece of $#!T.
Mar 25, 2006, 08:28 AM
Personal Sales Rating: ( 2)
Drives: 06 CT9A / totaled 05
Quote:
I just installed the Buschur race front mount and it did affect my tune. It leaned the car by .3-.4 a/f, the cooler and denser air from the intercooler will lean out the mixture.
Offline
Mar 25, 2006, 08:53 AM
Personal Sales Rating: ( 5)
PM importimage if you're looking for a 255 fuel pump. I got my Walboro w/install kit for $85 shipped 2 weeks ago. That price is hard to beat, and as you said you really do need a fuel pump at this point.
__________________
"Success is never the result of spontaneous combustion. You must learn to set yourself on fire."
Offline
Mar 25, 2006, 09:29 AM
What are you talking about, you have an afc. find someway to log air fuel with a wideband or get a pocketlogger and just try to get your af around 11.1 and you will be fine.
__________________
Offline
Mar 25, 2006, 09:31 AM
Sponsored By EvoM Vendors
Personal Sales Rating: ( 6)
Drives: 05 GG MR
He's taken care of and will get tuned properly for all of his mods on April 8th.
__________________
Sponsors:
Revolutions Performance || Shepherd Racing || Exedy
VIP Garage || Tobz Performance Tuning
11.51 @ 117.7 - IX Turbo, E-85, Cams, Tobz Flash, 5000' elevation
335whp/352wtq - DynoDynamics
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
