Jan 30, 2006, 11:41 AM
Personal Sales Rating: ( 18)
Drives: 05 RR RS
SAFC2 for a idle on a sti
i know i know, this is a evo forum. I dont have a account on nosiac. Im trying to help a friend so bear with me please. We have everything ok and set up but the problem is the idle. we just installed 816cc injectors and the lowest NE01 will go on the afc is 800 rpm. his car idles at 500-600 rpm. is their another way with afc to get the idle go work out. anyhelp would be great. thanx
__________________
05 rs. Best 1/4 run 6-26-09 11.289 @ 123 on a stock VIII turbo
Best mph ( 6-26-09 ) 126.19 Stock 8 turbo et was( 11.35 )
2-21-09 Dyno run: 423 whp 384 wtq Stock VIII turbo ( dynojet @ drift office)
5-16-09 Dyno run: 433 whp 381 wtq Stock VIII turbo (dynojet @ ER Racing )
Offline
Jan 30, 2006, 11:57 AM
Personal Sales Rating: ( 23)
Drives: 2003 BBY Evo8, 2009 Outback
Whatever settings you put in for 800 RPM should carry down to 0.
-Paul
Offline
Jan 30, 2006, 12:04 PM
Drives: 05 RR RS
Quote:
-Paul
I not 100% sure on this, but i think the ne01 reads from 800 (or what ever) to the setting on ne02. then the setting for ne02 reads to neo3, and so on. so i have no way to correct for under 800 rpm. I thought maybe i was missing a setting in the afc somewhere where you can set the idle different from the rest of the imputs.
__________________
Offline
Jan 30, 2006, 12:24 PM
Personal Sales Rating: ( 0)
1998 Mitsubishi Eclipse My Garage
Drives: '05 WW CT9A GSR SSL, '98 NW D32A
-Paul
Exactly. That piddly 200-300RPM difference at idle is not going to make much of a differene. It'll use the ne01 setting and the computer will adjust for the rest.
__________________
Skeet
Driven to Thrill
Offline
Jan 30, 2006, 12:41 PM
Drives: 05 RR RS
For reason his is not compensating at idle. it bogs real bad and dies. I know our cars are set karmen and theirs are hotwire. maybe its a setting in their. so we should be able to get idle correction with the ne01 pulled out? ill give it another shot. thanx
__________________
Offline
Jan 30, 2006, 01:02 PM
500-600 sounds too low anyway. He should just adjust whatever his idle is up to like 900 or so. 816cc's might just be too big for an SAFC2. What injectors did the car come stock with?
__________________
Skeet
Driven to Thrill
Offline
Jan 30, 2006, 01:24 PM
The way the SAFC works is for RPMs between the set points it interpolates the two closes numbers. For example, if you had 800 RPM set to -20 and 1200 RPM set to -10, 1000 RPM would be -15. At the ends it just carries whatever setting you have as far as you go beyond it. So if you set 800 to -20, everything below 800 is set to -20. And if your highest point is 7000, everything above 7000 RPM will use that same setting. If lowering the 800 RPM set point does not fix the idle, then the injectors may be too big to be adjusted for with the SAFC-II. Stock ECUs typically do not like idle airflow readings that are too low.
-Paul
Offline
Jan 30, 2006, 01:29 PM
Personal Sales Rating: ( 2)
Drives: IX - sold, purchased X
I would contact Dan from Godspeed, he has helped me in the past with an STI and is pretty well-known on NASIOC.
Good Luck
Offline
Jan 30, 2006, 08:15 PM
Drives: 05 RR RS
Quote:
Good Luck
thank you, i will definatly do that.
__________________
Offline
Jan 30, 2006, 08:18 PM
Drives: 05 RR RS
Quote:
sti's idle that low. hes running a g12 so he needs at least 816's. 2.5l takes it fine.
__________________
Offline
Jan 30, 2006, 08:25 PM
Personal Sales Rating: ( 8)
Drives: Boxer Cup
Does he have a wideband? If so, take as much fuel out as you can at (800rpm) in order to idle around 14.7. Then you can compensate at the next RPM increment. 816cc injectors are really moving some fuel at idle.
Offline
Jan 30, 2006, 08:34 PM
Quote:
Having 2.5L's does not change the fact that an SAFC2 is too blunt an instrument to fine tune for 816's for daily drivability. Having a G12, or whatever big turbo, means nothing when you are trying to pull vacuum and idle. It may scream when he is at WOT, but obviously that's not the problem. Sounds like he needs something to adjust the pulsewidths and deadtime for lower RPM's, something a SAFC2 can not do. A stock STi may idle that low and be fine, but this one isn't.
__________________
Skeet
Driven to Thrill
Offline
Feb 1, 2006, 10:08 AM
Personal Sales Rating: ( 5)
Drives: 2001 Estoril Blue M Coupe & 2003 Weightless White EVO
Is 816 a common injector sizes being used in STi's? It sounds a bit big... the OEM injector driver may not be good enough to get a good pulse. Aftermarket ECU like Autronic and AEM has better injector drivers to work with huge injectors. To compensate for it, raising the idling speed will help.
Offline
Feb 3, 2006, 11:01 PM
Personal Sales Rating: ( 6)
Drives: Red EVO VIII
at part throttle what is his cars afr? is it holding around ~14.7. Maybe your friend has a vacuum leak(not boost leak); tell him to check intake piping between the maf and throttle body. Most ecus should always maintain around 14.7 afr on its on regardless of injector size; but who knows with those ugly looking engines  .
__________________
05 Evo VIII
// ETS 6262 // FIC 1050cc // AMS FMIC //Buschur UICP // Tial BOV // HKS 280s // Speed Density with Stock ECU //
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
