Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Apex-i Power FC
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jun 7, 2009, 07:47 PM   #1
Personal Sales Rating: (0)
Drives: evolution 4
Question apex i power fc for evo 6 to evo 4
can i use the plug n play apexi power fc for evo 6 for my evo 4?what should i modify to plug the ecu to my evo 4 loom n works well?
Offline
Old Jun 8, 2009, 05:20 PM   #2
Drives: Rally Slag
Yes you can use the apexi ecu in your 4, all you will need to do is rescale the injectors to 110% if you are still running the yellow 510 injectors.
You also might have to snip pin 33 on the ecu wiring if your battery goes flat, or you can put a multi meter across the battery and make sure the battery is charging if it not cut pin 33 if it is leave it connected.
Lee
Offline
Old Sep 22, 2009, 03:01 PM   #3
Drives: EVO,S13Auto,S13Manual,S14a
do you have to switch around any other wiring at all when fitting the EVO6 power FC into EVO 4 or do you need a harness of some kind??
Offline
Tags
evo, fc, help...., poer, power, tuning
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
