Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Apex-i Power FC
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jan 24, 2009, 07:36 AM   #1
Personal Sales Rating: (0)
Drives: EVO3
Pfc with New Map sensor(3.5 bar)..
PowerFC with new Map Sensor.(Avcr 3.5bar)
Do we need to reset the Pfc for it to read the Idle with new Map sensor?
I have enter the scale/offset for the map sensor Avcr(3.5bar)( which have the right amount of Boost(psi) with the meter that I am using) but I found out that the engine run a bit rich after I install the new Map sensor is that normal? Do I need to remap the Pfc with the new Map Sensor.
Offline
Old Jan 24, 2009, 11:57 PM   #2
spyke's Avatar
yes you need to rescale
Offline
Old Jan 25, 2009, 06:31 AM   #3
Drives: EVO3
Okie.. Will do that.. Thanks.. Hope this will be a good infor for every one why buy a new Map sensor
Offline
Old Jan 26, 2009, 03:30 AM   #4
8MR
8MR's Avatar
Drives: Evo 8MR
PFC can used 3.5bar map sensor??? What do u mean AVCR 3.5bar? I thought of changing to higher bar map sensor which PFC normally come with 3bar map sersor only and my tuner told me PFC only can used the original map sensor which come along with the set.
Pls enlight me.... Thank you.
Offline
Old Jan 26, 2009, 09:08 PM   #5
Drives: EVO3
Well. I am using the AVCR 3.5bar now, and doing the tunning at the moment. so far I am sure u can use different Map Sensor, where AEM 5bar look like a nice Upgrade.
But u need the calibrate the Offset and scale for the new Map sensor...
Offline
Old Jan 27, 2009, 02:00 AM   #6
8MR
8MR's Avatar
Drives: Evo 8MR
AVCR 3.5bar is the Solenoid valve that come with the AVCR boost controller?
Offline
Old Jan 28, 2009, 05:07 PM   #7
Drives: EVO3
Ya that is what I got. But seem very hard to get the right scale and offset for the 3.5bar...lolz
Offline
Tags
35, apexi, avcr, bar, calibrate, fc, gm, idle, map, pfc, power, problem, recalibrate, scaling, sensor
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
