I try to bring up this topic for more understanding of how to tune for Faster Turbo SPOOL. And MORE POWER. Here are some suggestion that i get from some Forums.. If anyone have try any of this please let me know which is best and why...etc
1) Some ppl try to Adjust the Cam Timing( Not ign Timing) which Advance both the Intake and Exhaust Cam so that it will let Hot air out faster to Spool up the Turbo.
2) Lean AFR(13.5~14) RPM range 3000 to 4000.. Which help spin up the turbo faster.
3) Retrade the Ignition timing on range 3000 to 4000rpm. which make burn slower and push more hot air into the Exhaust and spin the turbo.
4) Use a smaller wastegate which make more air for the turbo to spin.
5) Increase the size of the Throttle Body. like 60mm -> 75mm which again increase more air into the engine and produce more air for the turbo to spin..
if there are more suggestion please let suggest and do remember why u use it.
