Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Apex-i Power FC
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Mar 2, 2008, 11:25 AM   #1
Personal Sales Rating: (1)
Grip's Avatar
Drives: 01 impreza
wideband says car is running 17+ AFR all the time, Power FC
i come from the subaru community for Power FC help, the Power FC isnt a popular tuning option among the subaru guys, so there isnt much help for guys like me over there..hopefully i can get some help here.
thanks for looking...
setup:
V3 STi EJ20
TD05-16G (running wastegate boost only, 9lbs)
STi 550cc injector's
Perrin up-pipe
Perrin 3" catless downpipe (divorced gate)
JIC 3" Ti catback (resonated)
CX-R FMIC
HKS EJ20G intake elbow, MAF adapter with velocity stack
ARC atmospheric BOV
ported and polished throttle body
gasket matched intake manifold runner's
Apex'i Power-FC and Commander
PLX M-300 wideband
with the wideband installed, on the stock Z4 ECU, with the above setup....the wideband says the car is running lean 17+AFR's.
with the wideband installed, on the Power FC, with the above setup, and the adjustments made for the 550cc injectors vs. the stock 440cc injectors (80%IDC, +.03ms) ...the wideband says the car is running lean 17+ AFR's.
heres what info i have about the stock injectors vs. the STi 550cc yellow top/sidefeed's.
440cc= .69ms
550cc= .76ms
heres what i have done in the PFC:
for injector correction in the Power FC:
440/550= .8 aka 80%...so i change the injector setting in the PFC commander to 80% for cylinders 1-4
for injector latency:
(550cc latency minus 440cc latency)
.76-.69= .07
the Power FC only allows latency adjustment's in .2 (or even #'d) increments...so instead of .07...i made it .06
what am i doing wrong?
why is does my wideband AFR stay LEAN? (17+ AFR)
how do i correct this issue?
Offline
Old Mar 3, 2008, 07:22 AM   #2
Grip's Avatar
Drives: 01 impreza
28 views since yesterday and nobody has any tips, or advice?
Offline
Old Mar 3, 2008, 04:05 PM   #3
Personal Sales Rating: (23)
PVD04's Avatar
Drives: 2003 BBY Evo8, 2009 Outback
Send a message via AIM to PVD04
Well, it may be that your wideband is reading incorrectly. This could be due to an issue with the O2 sensor, the controller, or an exhaust leak. If it is reading correctly then the obvious solution would be to add fuel.
Offline
Old Mar 4, 2008, 08:36 PM   #4
Grip's Avatar
Drives: 01 impreza
ive talked to two local tuner's and tech support at PLX devices...everyone agrees that the controller/display is mis-calibrated from the factory...it is being sent back for repair's and a new sensor.
i have used the power FC to add fuel...i add'd fuel until the car stumbled and choked on fuel...wideband still shows lean....even if you lean the car out with the power FC..it shows lean.
hopefully i wont have anymore issues with PLX devices.
Offline
Old Mar 4, 2008, 11:12 PM   #5
Personal Sales Rating: (2)
2003 Mitsubishi Lancer Evolution
EvoVIII808's Avatar
Drives: 03 Evo8
Send a message via AIM to EvoVIII808 Send a message via Yahoo to EvoVIII808
yeah my AEM just took a dive on me. shows 14.8 regardless of what im doing. Sucks now that i have to get a new one.
__________________
Quest for 700hp!! Buschur UICP,4" Intake, RNR GT35R, 3" Exhaust, HKS272/272, Skunk 2 Cam Gears, RC 1000cc inj, 255fp, AMS FPR, JMF Intake Manifold, SuperTech 1mm Valves, BC Valve Springs/Retainers, ETS FMIC, Full Race Head,
Comming soon.. ETS 3.5" Exhaust, Built 2.0
Offline
Old Mar 20, 2008, 05:55 AM   #6
Yorl8's Avatar
Drives: Sideways
I had some problems with my AEM, but it turned to be an exhaust leak.
Offline
Tags
148, aem, afr, suck, wideband
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
