Feb 25, 2008, 05:48 PM
Personal Sales Rating: ( 0)
Drives: EVO3
Timing retrad from 2.0 to 2.3L
I need some help with the Timing Map.
I have install a strocker kit from 2.0L to 2.3L, what are the total timing retrad I need from 2.0L to 2.3L? -5 or -10 over the Timing Map, I am using a PowerFC Djetro...
If any one have the Map of 2.3L Timing map..  Thanks in advance...
Offline
Feb 28, 2008, 03:58 PM
Personal Sales Rating: ( 2)
2003 Mitsubishi Lancer Evolution
Drives: 03 Evo8
not sure if anyone has that. i would say start with -5 and go from there.
Small increments is what i do.
__________________
Quest for 700hp!! Buschur UICP,4" Intake, RNR GT35R, 3" Exhaust, HKS272/272, Skunk 2 Cam Gears, RC 1000cc inj, 255fp, AMS FPR, JMF Intake Manifold, SuperTech 1mm Valves, BC Valve Springs/Retainers, ETS FMIC, Full Race Head,
Comming soon.. ETS 3.5" Exhaust, Built 2.0
Offline
Feb 28, 2008, 05:34 PM
Drives: EVO3
IC, so that's mean if we use strocker kit we need to reduce out Timing right?. As the original timing for the 2.0L will be too advance for a 2.3L/2.4L kits....?.
Offline
Feb 29, 2008, 02:00 AM
Drives: 03 Evo8
Yes i do believe this is correct, anyone can back me up on this. I am still very new to this system.
but thinking about it, i think you should be able to run higher timing since there is alot more space for ignition. Dnt quote me on this but it is worth trying to find out.
Maybe post in the AEM section, this will get you in the right direction.
__________________
Offline
Mar 10, 2008, 04:19 PM
Drives: Evo Vi
It will depend on lots of things, i can mail you my map if you like.
__________________
Evo Vi, HKS 272/272, 2.3l, GT35.
Offline
Mar 25, 2008, 08:44 PM
Drives: 2002 RR Evolution VII GSR, 1993.5 Toyota Supra TT
not true.. the base map that comes with the PFC worked fine with me!
__________________
2002 Evolution VII GSR Rally Red
Your Average 2.3 liter PT67R EVO VII!
Offline
Mar 31, 2008, 05:02 AM
Drives: EVO3
Did you stroke your engine?
Quote:
Please explain, the engine map that I have at the moment can start the car but the idle are not stable when I start to give more gas...etc
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
