Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Apex-i Power FC
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Feb 12, 2008, 11:06 PM   #1
Personal Sales Rating: (0)
Drives: EVO3
Timing Tuning Infor
Hi, I got a 2.2L kit with PFC Djetro, I am doing the tunning for RUN IN( Eng Just build Up with New Piston, Rod, Crankshaft)... and I load up the standard map and get into a lot of knock(above 60).. have anyone seem the same problem before?. .. is that because of the Timing are too high?
What if I set the timing too low?... that will loss power right?
any suggestion?
Offline
Old Feb 13, 2008, 08:29 AM   #2
ciobing's Avatar
Drives: EVO VIII
you must remap,probably you have too much timing
Offline
Old Feb 17, 2008, 01:04 AM   #3
Drives: Nissan Skyline R33
as the others have said you have too much IGN timing or the fuel you are using is crap
you should get a full tune sorted out ASAP
until then baby it around, use high octane fuel or use the temp ign adujust to back out timing to protect your engine
you can read the powerfc faq and it tells you how to debug knocking and how to use the temp IGN adjust in the PFC to back out timing to prevent knocking
http://paulr33.skylinesaustralia.com...owerfc-faq.htm
Offline
Old Feb 28, 2008, 05:44 PM   #4
Drives: EVO3
About the Temp IGN Adjust, is that modify the whole Timing Map 20X20?. or just a single cell? or
Offline
Old Feb 29, 2008, 02:03 AM   #5
Personal Sales Rating: (2)
2003 Mitsubishi Lancer Evolution
EvoVIII808's Avatar
Drives: 03 Evo8
Send a message via AIM to EvoVIII808 Send a message via Yahoo to EvoVIII808
yeah you have to pull timing. usually 3 counts of knock = 1 degree of timing.
make sure you go in small increments. also you can add fuel to that cell.
Should be able to change 1 cell before/ knock cell/ and 1 cell after.
__________________
Quest for 700hp!! Buschur UICP,4" Intake, RNR GT35R, 3" Exhaust, HKS272/272, Skunk 2 Cam Gears, RC 1000cc inj, 255fp, AMS FPR, JMF Intake Manifold, SuperTech 1mm Valves, BC Valve Springs/Retainers, ETS FMIC, Full Race Head,
Comming soon.. ETS 3.5" Exhaust, Built 2.0
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
