Oct 10, 2007, 12:09 AM
Personal Sales Rating: ( 0)
Drives: JDM Evo7
Another PFC IGN tuning.
Hey guys, (and PaulR33 :P)
Have a PFC on my 7 which is sweet, pulling 220wkw with good afr's from previous owner.
Just that the map is a bit 'knocky' on 21psi. It usually hovers between 10-30 counts.
Pulled the whole IGN map back 1 deg and did a few more 2nd and 3rd gear pulls and it was alot better with knock hovering around 10 deg and max of 15 deg from 2500-6000rpm, however as soon as the revs go past 6k, it clips 60 counts.
The AFR's are fine, but just a little too much timing is wound in I suspect.
I am halfway through putting my IGN and INJ maps onto a excel spreadsheet to manage better, but atm anyone know what area to look for when the throttle is buried?
__________________
Belting a Sooby a day keeps the doctor away! :D
WW JDM E7 - 212wkw @ 1.55bar
PFC - 8MR turbo - RM01A/Tomei Expreme TBE - Kansai box/RS intake - SBCid3 EBC
Offline
Oct 13, 2007, 09:58 AM
I would log some runs and see at what RPM you are hitting the 60 count and try pulling timing from there. If you pull a few degrees and it doesnt help then its probably some other noises triggering the knock like an exhaust rattle or what not.
Offline
Oct 16, 2007, 10:02 PM
Drives: JDM Evo7
Its 6krpm or a touch over....knock meter is quiet as a mouse with 15-20 counts or less in most cases on 22psi until 6k, then it goes mental.
__________________
Offline
Oct 16, 2007, 10:19 PM
Personal Sales Rating: ( 5)
Location: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
Drives: 08 Blk STi, 03 Blk EVO 8
What is your timing in those cells? I was fine running 18 degrees in the same area.
__________________
For Sale - Stock O2 Housing $50 shipped.
Offline
Oct 25, 2007, 04:33 AM
Drives: Nissan Skyline R33
yeah as the others have said just review the logs and youll find out exactly where its knocking. if you have datalogit then its easy do basic knock watch on the map and away you go. if you dont, get a friend in the car, get them to watch map tracer and you yell out when you see the engine check light flash (knock over 60) and make sure your friend marks what cell it was on in the map tracer screen
Offline
Oct 25, 2007, 10:58 PM
Drives: JDM Evo7
Righto, I had some testing down the freeway last night with 2nd and 3rd gear pulls on 22.5psi, knock hovering around 15 in the upper rev range with a burst of 22 here and there...
Rang the guys that tuned the car and that said anything under 30 counts on full noise is fine and not to worry.
I'll write the ignition table down and post it up to see... Will be easy to edit it that way.
__________________
Offline
Oct 28, 2007, 04:57 AM
20 to 30 isnt a big deal
i wouldnt even worry
Offline
Oct 28, 2007, 05:11 AM
Personal Sales Rating: ( 12)
Drives: '04 White EVO VIII RS
20 or 30 is a big deal dude.... Be carefull with that tune thats some nasty knock....
__________________
Jun 272's ETS 6262 Wilson V2 Stock ecu All The Fixings on E85 Selftune!!
Offline
Nov 8, 2007, 10:35 PM
Drives: JDM Evo7
Not on PFC it isn't...its scaled different to others.
EG: Mates 33 GTR, 4th gear pull on the dyno, with the det cans on there was no audible detonation, however the PFC handset was still ~10-25 counts around 5k+ rpm.
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
