Oil Analysis on E85
Old Apr 1, 2010, 11:31 AM
donour's Avatar
Oil Analysis on E85
I'd like to share the results of recent oil analysis with folks that might be interested. This is my first oil change after switching to E85. Almost all of the 1500 miles are street tuning, with a few canyon runs and autocrosses thrown in. The heavy use accounts for the higher than normal iron content. Although the fuel type is listed as gasoline, E85 was the fuel listed on the report sheet and they checked for it during testing. Although the oil did smell of ethanol they found no more than trace amounts, certainly not enough to affect the viscosity of the lubricant.
Mods include: intake, cams, exhaust, and fuel system support for E85. Boost is in the 25-28 psi range.
I think things look pretty good for a car with 500+ autocross runs on it and dozens of track hours.
d
Old Apr 1, 2010, 11:40 AM
JEP
JEP's Avatar
Thank you for the info! This is the kind of valuable info that we need, thanks again...
Old Apr 6, 2010, 01:14 PM
bzzbee2's Avatar
I did analysis every 1k miles for the first 8k miles of e85 then every 2-3k miles since then. I will dig them up and re-post them in here.
Old Apr 7, 2010, 04:18 PM
johnnyddn's Avatar
Very good information, how much does it cost to get an oil analysis?
Old Apr 7, 2010, 10:27 PM
bzzbee2's Avatar
blackstone labs is 19.95. they send you the kits for free.
Old Apr 7, 2010, 10:33 PM
dwnfdrknss's Avatar
so just to clarify this was mobil 1 standard yes? not extended performance? either way thats great!!!
Old Apr 7, 2010, 10:49 PM
bzzbee2's Avatar
I usually never use the extended performance. I attached my first 5 reports on e85. I have more, but they are spread out over the next year. I didnt drive the car much as i had a company car. There are analysis of mobil 1, Motul, and Redline.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
STi2EvoX
544
Oct 27, 2015 03:07 AM
tkromer
Jan 31, 2012 07:33 PM
4g94T
Lancer Aftermarket Forced Induction Tech
Oct 18, 2011 11:34 PM
Jim in Tucson
E85 / Ethanol
188
Aug 12, 2011 10:04 AM
jwtodd60
Oct 7, 2004 09:28 AM
Quick Reply: Oil Analysis on E85
