Nov 2, 2009, 01:23 AM
Personal Sales Rating: ( 0)
would it be possible to have preset maps for e-85 and 91oct for a Cobb AP?
Offline
Nov 2, 2009, 07:02 AM
Drives: 05 Apex VIII
There aren't any E85 pumps between LI and Manhattan, it's just the ones in LI that I'm aware of. You would have to calculate your drives and fill ups since you won't have many places to get E85.
I'm in NYC as well and recently have been seeing a lot of the TLC drivers in Yukon's with Flex Fuel logo's on the back. Next time I see one I'm going to ask where they have been filling up because those guys drive like 20k miles a year they must know some places that I don't. As soon as E85 becomes a bit more common in NYC I am definitely switching over.
Offline
Nov 2, 2009, 07:03 AM
If swapping maps is possible to run both E85 and 93 that would definitely make it easier, but I still think I will wait until more stations start carrying it.
Offline
Nov 2, 2009, 09:37 AM
Personal Sales Rating: ( 1)
Drives: WW Evo X
Quote:
Yes, thats the advantage of the AP, a quick < minute flash and you are on your way. But Cobb does not have OTS maps for E85, so you will have to either create your own or get one made at a tuner. I'm near the Cobb shop in Plano and they have given me a quote for tuned 93 and E85 maps.
Offline
Nov 2, 2009, 09:46 AM
Drives: PB Evo X
What are the chances of Bushur coming out with a switch for the maps, like they did for the 9?
They were reasonable and would be a great solution. What about the final drive gear from Bushur, what happened to that?
__________________
PB Evo X SSS (365 whp/399 wtq at 5,500 ft, 100* F)
-UR TB Exhaust w/O2 DP (resonator)
-Harman Motive Intake (AEM filter)
-Forge Unos MBC (25 psi)and Pro Sport Gauge
-AMS underhood bushings
-Works Shifter and Works base bushings
-Zeitronix Wideband and Boost Sensor
-Perrin 4" Antenna
-Tinted Windows and taillights
-OEM Aero Kit and Mudflaps
Ecuflash by Camtuning
Need Corn!!!
Offline
Nov 2, 2009, 05:48 PM
Drives: 2008 Evo X GSR
Thanks for all the great posts.
I know of the one E85 station near me its like 10 miles away (I think its a BP not sure)
But there is also a station around the corner form me that sells 100 oct race gas. But he only does fill ups with that pump and its about 850 a gallon
I think I would consider it more when they come with a map swap device because I always have my laptop on me
Offline
Nov 2, 2009, 06:36 PM
Drives: Evolution GSR
I want to switch to E85 but the only station is on my way to work. I think i'm going to wait till i have done mods to the car and more stations are available.
Offline
Nov 4, 2009, 08:16 AM
Drives: 08 RR X GSR
I would never map switch between the two. Even some gas left over in tank can really screw your afr's. So your more aggressive map could be fubar when running with part 93 and part E-85. No thanks, it's not really a quick switch scenario. I'd go meth if you want switchable power.
__________________
Buschur Racing Dual Exhaust w/Bullet Muffler
UR Testpipe
Works Short Throw & Works Base Hybrid Bushings & AMS Underhood Bushings
AMS 3" Intake w/ Heat Shield
AMS UICP
Perrin 3-port
ECUFlash TUNE - 354awhp/376awtq @31psi(dyno dynamics 1.0CF)
393awhp/395awtq (MAP's dynojet)
Cosworth MX1 Cams
Deatschwerks 1000cc Injectors w/E85
Perrin 2" Shorty Antenna
Sitting in Boxes at my House: Ported FP Red/AMS Innercooler.
Waiting on: More Fuel and Clutch.
Online
Nov 4, 2009, 08:19 AM
Silver Sponsor +1
Personal Sales Rating: ( 445)
Drives: 2008 Evolution GSR SSS, 2005 Evolution MR, 2003 Evo GSR, 1995 TsiAWD, 1995 GST, 1995 Tsi 2wd, 1991 GVR4 WW, 1991 GVR4 NBM, 1993 TsiAWD, 1991 Tsi, 1995 RS N20
The key is to leave the E85 map on for 5-10 minutes after refueling with gasoline, then switching.
__________________
2005 Evolution VIII MR
763whp/595tq HTA86
10.19 & 143.3mph stock ECU
Factory ECU Expert
2008 Evolution X GSR
12.0@113mph Full Wt+
In House Mustang Dyno AWD-500!
www.ttp-engineering.com
(407) 475-0010
AIM=TTPEngineering
MODIFYING THE 4G63 SINCE 1995, YES 14 YEARS!
TUNING EVO V - EVO X & 2009 RALLIART!
TTP's Myspace page!
Offline
Nov 4, 2009, 09:13 AM
Drives: 08 MR
How many people are actually running e85 and are switching maps periodically? Has anyone run into any problems?
Offline
Nov 4, 2009, 12:24 PM
Personal Sales Rating: ( 14)
2005 Mitsubishi Lancer Evolution
Drives: 2005 Evolution 8, DD 92 Camry
Quote:
Originally Posted by TTP Engineering
You cannot switch back and forth on an Evo X. Only evo 8-9 with JOT altmaps cable.
Plus if I remember it correctly, it takes about two full tanks to convert fully back so it's no use to switch back and forth. It's not good for the long haul.
__________________
Tomei ARMS/HKS 272s/HKS SMF Intake/ARP HStud/Mil.Spec/PTE880/Megan O2/Buschur Mani/3"TBE/Walbro/Hallman/Injen Intake Pipe/3"FMIC/Synchronic BOV/WORKS XC8
EvolNinja
Tuned by 4WS Tuning
Online
Nov 4, 2009, 08:16 PM
Personal Sales Rating: ( 5)
Drives: Lancer
Another question: does e85 kill the life of motor oil? My friend uses e85 and says the oil gets less viscose compared to 93.
Is this true?
Offline
Nov 5, 2009, 12:29 AM
Drives: Evo X GSR
This might seem like a dumb question...
Do the shops that tune for e85 have drums filled with the fuel on location? What's the process of making the actual switch over?
__________________
EVO X GSR
UR 3" single Cat Back Exhaust
UR 02/dp and testpipe/mini muffler
HKS drop in filter
Custom tune by HB Speed
Muellerized JICs
Offline
Nov 5, 2009, 09:30 AM
1991 Nissan Skyline My Garage
Drives: 2008 Lancer Evolution GSR /R32 Skyline GTS-4
good thread
__________________
RR Evo X SSS
Greddy TBE/CobbAP/dog hair
R32 Skyline GTS-4
RWD conversion/HKS intake/Apex-i catback/Ohlins coilovers/A-Tech Finalspeed 17x9/Bridgestone Potenzas/dog hair
Offline
Nov 5, 2009, 11:39 AM
Drives: X
Quote:
Originally Posted by ikt
good thread
+1, I'm curious also about the conversion... I just wish the X came with at least 4 more gallons in tank capacity. Refueling every 150 miles with E85 is just not an option for a lazy guy like me.
__________________
What does the RA forum "guru" think of the Evo's build?
Quote:
Originally Posted by ambystom01
"The build quality of the Evo is really no better than the average Civic, you could logically argue it is actually worse."
"it'll blow their mind that a hater, troll, slowbaru driver like myself would actually defend(?) an Evo."
100% Stock
Ghetto "Carputer" w/ Evoscan:
Nighttime Video
Daytime Video (carmount setup shown)
Car-webcam added
Custom Gauge Layout I
Offline
Tags
100, 85, 93oct, e85, evo, injectors, island, ix, long, long island, manhattan, needed, new york, octane, upgrade, whats  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
