Oct 5, 2009, 08:34 AM
Personal Sales Rating: ( 9)
Drives: 2008 Evolution X GSR 2004 Evo VIII RS (sold)
E70
Looking for some estimates / best guesses on when E70 will arrive in the Chicago / Wisconsin area, AND whether I will need a retune for this. I would like to do an E85 re-dyno anyway, but am wondering if I should have my tuner make an additional E70 map for the winter. I would rather not, if I could safely avoid it, so that's where I need your opinions.
I haven't been able to source a GM sensor from a local junkyard yet, but I'm goingf to keep looking before I shell out big bucks for aftermarket. At least once that's hooked up I'll have a little more peace of mind about what E content I'm getting. PS this is for my evoX.
Offline
Oct 5, 2009, 01:23 PM
Personal Sales Rating: ( 2)
2005 Mitsubishi Lancer Evolution My Garage
Drives: 96530006
Ethanol "regions" are defined by the U.S. Dept. of Energy. Check the Handbook for Storing and Handling E85; in appendix A, you'll see a listing of Geographical Fuel-Marketing Regions. Northern Illinois gets class 3 E85 in the winter, switching to class 2 in April, and switching to class 1 in June, then back to 2 in September, then back to 3 in October.
Classes are described on page 11. Class 3 is a minimum of 70% ethanol, class 2 is minimum 74%, and class 1 is minimum 79%.
(Notice how the minimum is never actually 85%, no matter where you are in the country? Only in America could we market a product with 70% ethanol content in it as "E-85".)
Offline
Oct 5, 2009, 02:46 PM
So if I retune for minimum 70%, won't I go lean when we get 85% stuff?
If I tune for 85%, then will it knock at WOT with 70%?
Wondering if I need two maps, or just not worry about it.
Offline
Oct 5, 2009, 02:51 PM
Personal Sales Rating: ( 4)
Drives: 2003 AP Evo 8
if you were tuned really really aggressive on "Real" e-85(we have e85 but with a 85-88% ethanol content all year round) like we can get here in sd, then you might be slightly rich going to regular e-70 winter gas. won't harm it, but won't make 1200whp either. You should be ok with out a retune in the winter =)
__________________
2003 Apex Silver Evo VIII ---Manley and Wiseco 2.0l block, Full BC head with 280's, Custom Topmount PTE 74mm turbo, AMS VSR, AEM EMS, FIC Bluemax 1450's, Fullblown double pumper.
Women are like parking spots, All the good ones are taken. The rest are handicapped
Offline
Oct 5, 2009, 03:44 PM
So is it better to tune on the highest E-content, tune on the lowest E content, or just try to go middle of the road?
Offline
Oct 7, 2009, 08:28 PM
Personal Sales Rating: ( 8)
This is why ethanol sensors are used. To be as safe as possible you should at least have a summer and winter map. Based off of what your ethanol content sensor reads... pick the better suited map. The lower the ethanol content, the richer the a/f ratio and lower octane rating will be .
Offline
Oct 7, 2009, 08:32 PM
Yeah, that's what my instinct told me too. Got my used E content sensor on it's way here  . It's still nice to know that it probably won't blow up if i mix up E70 and E85.
Offline
Oct 8, 2009, 11:45 AM
Silver Sponsor
Drives: EVO, STI
Just some data.
About 4-5 months ago the local station had some issue and the E85 ended up only being about E55 or so. Other than the fuel trims getting totally wack, the car ran more than 1 full point richer.
I datalogged a bunch of WOT pulls and there was zero knock, the car was just a bit slower and less responsive because of it being so rich. This was on my personal Evo which I tune a far bit more aggressive then customers.
I'm not saying your car will be ok but I think E85 to E70 is not such a drastic change as some people think, it's still 70% Ethanol. Espically since it's most likely not true 85% to begin with in the summer months.
Offline
Oct 8, 2009, 02:37 PM
So that said, is it even worth it to run an E-content sensor in your opinion?
Offline
Oct 8, 2009, 02:58 PM
Drives: 2006 Evolution IX MR, 1998 Honda Prelude
I put one in mine to just make sure what was flowing through the lines, not just for the summer and winter months, but I have a dual map switch so I make sure the map switch is correct. I used my zeitronix sensor to control a little logic board, if the e content is under 30% than it switches to the 93 oct map, if it is above 70% than it uses the e85 map. I just did it automated so if someone else is driving the car, like my dad, they can fill it up with whatever they want, e85 or 93. BUT you must make sure the tank is almost empty if you are switching from e85 to 93, don't want to end up in that 50% no mans land on the ethanol sensor gauge...
__________________
06 Apex Silver MR
80MM FP Green - Ported 73HTA
HKS 272 Cams
Precision 1200cc Injectors
Walbro 255 lph
Hallman Pro RX MBC @30 psi
ARP Headstuds / Conrod bolts
Injen UICP/LICP
Injen Ram Intake - K&N Cone
APS TV BOV
Greddy Spec-V FMIC
Greddy Turbo Headers
ARC Titanium Catback Exhaust
Megan Radiator
Megan O2 Housing - Ported
DC Sports downpipe/catdelete
Okada Projects Plasma Coils
Excedy Twin HD/ Fly
ROBISPEC/// KW3 Custom Clubsports
E-85 Ethanol
Offline
Oct 14, 2009, 11:04 PM
Personal Sales Rating: ( 33)
Drives: Evo IX MR
Quote:
Originally Posted by GST Motorsports
Just some data.
Yeah, with no retune, I see same power and no knock with E85 and E70.
__________________
Works drop-in :: AMS LICP :: English Racing ported EM and HS :: Titek v2 O2 :: Helix v2 DP :: MIL.SPEC 100 cps cat :: RRE Stealth Stainless :: Walbro :: FIC 1050s :: E85 :: self-tuned :: 26.5 psi :: 340wtq/375whp VDR 5.71 EvoM mode, 77°F
Offline
Oct 15, 2009, 07:35 AM
Quote:
Hmmm.... anyone interested in a GM ethanol content sensor?
Offline
Oct 15, 2009, 07:56 AM
Drives: Evo IX MR
Quote:
You'll probably want to verify for yourself the ability to run the same tune using either E70 or E85.
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
