Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Alternative Fuel
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 1, 2009, 04:27 PM   #1
NTEC Club Forum Leader
Personal Sales Rating: (4)
goofygrin's Avatar
Drives: RR EvoX
Real world E85 "issues"
OK so I'm thinking of making the switch, but I have a couple questions about real world scenarios.
Let's say I'm out and about and I'm low on gas, but not near a station. Do I just fill up with 93 and switch maps to the 93 map?
Will the E85 left in the tank mess up this map & performance?
What do I do when I get E85 again? Go back to the E85 map?
There's still 93 in the tank, so that can't be the good, can it?
That's about it... I guess I could carry a 5g jug in the trunk, but that seems... dangerous? It would be sitting above the exhaust, which isn't the coolest of places :0
__________________
Are you in the North Texas area? Check out NTEC!
mmmm corn
Offline
Old Oct 1, 2009, 04:50 PM   #2
Silver Sponsor
Personal Sales Rating: (17)
JohnBradley's Avatar
Drives: 06 Rally Red MR
basically you have the answers to all the questions so let me fill in some of the extra data. It generally takes almost 2 tanks before the car will be back on pump or back on E85. On long trips I generally throw a 5 gallon jug or 2 in the back and secure them. I have been more occupied with worrying about fumes than a crash, but it doesnt boil in the back or anything.
__________________
SparkTech The ignition of EnglishRacing
Extreme Turbo Systems Parts to go fast with
EnglishRacing contact us-sales@englishracing.net
Home of the 522whp stock turbo/no nitrous and 1117whp 2.0L turbo record.
My car- 574whp@29psi stock block, pumpgas, ETS and FP3586...for now.
Retailer of AMR Engineering Coilovers
MAGNUS Motorsport Cast Manifolds in stock, $1000 with ETS Magnus pipe, dual rail available also.
Proud retailer of GSC cams
FIC Master distributor
OmniPower USA Dealer
Offline
Old Oct 1, 2009, 04:55 PM   #3
Personal Sales Rating: (33)
mrfred's Avatar
Drives: Evo IX MR
As long as you have the ability to switch between tunes, its no biggie if your gasoline is diluted with a bit of E85 or if your E85 is diluted with a bit of gasoline. Fuel trims will compensate to make cruise and idle work properly. For WOT, I've found that my E85 tune works fine for ethanol content anywhere from 65-80% actual ethanol content. A pump gas tune run on gasoline with a bit of ethanol is safe for WOT too. The only time I think you might have some trouble is if you find yourself in a 40-50% ethanol no-man's land. You'll still be able to drive the car (probably on the gasoline tune), but idle will be rough, and spooling up the turbo probably should be avoided.
__________________
Works drop-in :: AMS LICP :: English Racing ported EM and HS :: Titek v2 O2 :: Helix v2 DP :: MIL.SPEC 100 cps cat :: RRE Stealth Stainless :: Walbro :: FIC 1050s :: E85 :: self-tuned :: 26.5 psi :: 340wtq/375whp VDR 5.71 EvoM mode, 77°F
Offline
Old Oct 1, 2009, 08:27 PM   #4
goofygrin's Avatar
Drives: RR EvoX
Ya, my only real concern is when I go to tracks that are a drive away where there's no E85 available. It seems like I either just do the track day on 91/93/105 ($8+/gal!) or I get a lot of jugs
__________________
mmmm corn
Offline
Old Oct 1, 2009, 11:36 PM   #5
Personal Sales Rating: (9)
2003 Mitsubishi Lancer Evolution
denver's Avatar
Drives: 2003 EVO 8, '09 JETTA TDI 2009 GREEN CAR OF THE YEAR , '08 Outlander, '91 talon TSi, '03 Lancer OZ RIP!
Quote:
I generally switch back to 93 for track days.... I got a barrel and pump for the last one, but was to tired after the build failure to even take my car out let alone deal with switching everything.. we( evolution dynamics) will be bringing e85 with us, so if you get some jugs or a barrel you could likely throw it in the truck or something.... We need to keep the pressure on the local tracks to start carrying E85.... I bet once it gets more popular in the domestic car world they will start getting it..
I have found the same results MrFred describes.... you just have to be a little smart about the transitions... just take it easy for a tank or so... you have a wide band watch that..... but I have gone back and forth several time with out much issues at all... mostly with cruising and idle....
__________________
Are you in the North Texas area? http://forums.evolutionm.net/north-t...club-ntec-303/
SAVING THE PLANET GAINING 50HP AT A TIME....... CORN FED!!!!!!!!!!
Offline
Old Oct 5, 2009, 08:13 AM   #6
Tractionlimit's Avatar
Drives: 2008 Evolution X GSR 2004 Evo VIII RS (sold)
Quote:
mrfred: Are you saying you probably don't need to retune between E85 and E70?
OP: you will definitely want to get some 5gal. jugs for track days. I carry 30 additional gallons of E85 with me to the track. That gives me over a full tank there and a full tank for the ride home. I guess there are some safety concerns with having all that in the trunk, so I just try to be extra cautious. It's really no different than carrying gas for a lawnmover/whatever. You really don't want to switch back and forth a lot if you can help it (at least I don't). And trust me, once you run E85 at the track you'll never want to switch back
__________________
E85EvoXRed
481whp 443ftlbs
Offline
Old Oct 5, 2009, 09:11 AM   #7
mrfred's Avatar
Drives: Evo IX MR
Quote:
My car is tuned for 74% ethanol fuel (according to my ethanol content gauge). After my first fillup on E85 coming back from a road trip on gasoline, ethanol content was reading around 62%. At WOT 62% eth, AFR had richened to about 11.3-11.5 (vs 12:1 at 74% eth), there was no knock, and power was great. Power might have even been a little better than at 74% eth.
__________________
Offline
Old Oct 5, 2009, 09:22 AM   #8
Silver Sponsor
Personal Sales Rating: (40)
My Garage
KevinD's Avatar
Drives: '04 evo8 daily driver, '03 evo8 time attack car, 08 outlander
Send a message via AIM to KevinD
in general, when goofygrin reffers to the track, its a road course. in which case, 30 gals isn't going to be enough E85. 4 20 minute sessions will down about 10 gals a session. unless he just fills up with 93 for the ride home. regardless carrying 30 gallons of e85 in your car isn't a wise thing to do.
__________________
EVOLUTION DYNAMICS LLC
Tuning, Custom Fabrication, and installs in the DFW area.
www.evodynamics.com
email: evokevin@gmail.com
Phone + Text messages: 817-776-2170
Kelford, mil.spec, ACT, Aquamist, FIC, ShepTrans, Zeitronix, + many others
Evo Dynamics Unlimited Time Attack Build
3-Port PnP Boost controllers for Evo 8/9/X and RA
Join us on FaceBook!
Offline
Old Oct 5, 2009, 09:45 AM   #9
Quote:
I was referring to a road course as well . I went through ~20 gallons in an hour of drive time, then filled it up again and drove home. I dumped in one 5gal jug for each of 4 sessions which was 15 minutes. I'm not saying carrying fuel is a good idea, but it worked for me.
__________________
E85EvoXRed
481whp 443ftlbs
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
