Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Alternative Fuel
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 28, 2009, 05:40 PM   #1
Personal Sales Rating: (0)
LANCEREvo9MR's Avatar
Drives: 30R Evo 8
Lean Or Rich On E-85 Maybe A Boost Spike
On my zietronix W/B And Boost Gauge i looked at my peaks and i peaked on my A/F @ 9.8 And Lambda At 0.66, And my boost spiked to 30.7 when im tuned for 28.5 i havent touch my MBC why would it spike like that? And are my a/f's Safe?
__________________
465 Whp / 385 Wtg @ 28.5 Lbs Of Boost
E-85 Fed GT3076R
Road Race Engineering
*Stock Block
*Stock ECU
*Map Switching E-85/91
Offline
Old Sep 28, 2009, 07:57 PM   #2
Personal Sales Rating: (4)
97TSiAWD's Avatar
Drives: '06 MR
Send a message via AIM to 97TSiAWD
Have the outside temperatures cooled down lately? Cooler temps generally cause a slight increase in boost when using an MBC.
And 9.8 A/F ratio is really rich and your sig says you're running dual maps; are you sure you're not mistakenly running your E85 map with 91 octane? Or that you don't have large amount of 91 octane mixed with the E-85 while running the E85 map?
__________________
-Jon
'06 Lancer Evolution IX MR
'97 Eagle Talon TSi AWD
Offline
Old Sep 28, 2009, 11:52 PM   #3
Drives: 30R Evo 8
i dont think so because if i was running my pump gas map i would only be boosting 24 lbs of boost so i shouldnt be worried of a 9.8 on e85? what is like dangerous a/f that i should look out for because i havent been knocking
__________________
E-85 Fed GT3076R
*Stock Block
*Stock ECU
Offline
Old Sep 28, 2009, 11:55 PM   #4
Drives: 30R Evo 8
__________________
E-85 Fed GT3076R
*Stock Block
*Stock ECU
Offline
Old Sep 29, 2009, 08:04 AM   #5
Personal Sales Rating: (3)
Jim in Tucson's Avatar
Drives: '03 EVO VIII, '04 Prius
I'm not sure what is going on, but this simply does not seem possible to me.
Do you know anyone with a portable W/B you could use to compare?
Might be worth a trip to a dyno.
__________________
\\ IX Turbo \\ Walbro FP \\ HKS 264/264 \\ RC 1,000cc injectors \\
\\ Helix DP \\ Helix TP \\ Greddy EVO2 (modified to 3") \\ APS BOV/DV \\
\\ ETS 3" FMIC \\ Nisei LICP \\ PPI ported exhaust manifold \\ SS eBay O2 \\
\\ BR cone filter \\ BR MAF pipe \\ Hallman MBC \\ E85 \\ 394whp/418trq \\
E85 Hints and Tips
Offline
Old Sep 29, 2009, 08:18 AM   #6
97TSiAWD's Avatar
Drives: '06 MR
Quote:
Since you mentioned that you are using an MBC, your boost is controlled by your MBC and not by the map you are running. And, since you say you're running E-85 currently, the running 91 octane with the E-85 map idea seems unlikely.
What A/F ratio were you seeing after the original tune?
__________________
-Jon
Offline
Old Sep 29, 2009, 11:42 AM   #7
Silver Sponsor
GST Motorsports's Avatar
Drives: EVO, STI
Perhaps the tuner set up the fuel map to run much richer when it overboosts, like richening up the last load column a ton. 2 psi could jump a load column or two.
OP, have you asked RRE yet?
__________________
GST Motorsports
2439 Industrial Pkwy. West Suite A
Hayward, CA 94545
510-264-9049
The original E85 Army
http://www.gstmotorsports.com
Offline
Old Sep 29, 2009, 05:16 PM   #8
Drives: 30R Evo 8
im using two dejon tool mbc so when i flip the switch they switch boost controllers
__________________
E-85 Fed GT3076R
*Stock Block
*Stock ECU
Offline
Old Sep 29, 2009, 05:19 PM   #9
Drives: 30R Evo 8
wanted to ask u guys first before i go and look for my tuner hes only there tuesdays and thursdays want some opinion before i go? is it the alchohol content in the e-?? + the overboosting is whats making me rich?
__________________
E-85 Fed GT3076R
*Stock Block
*Stock ECU
Offline
Old Sep 29, 2009, 05:27 PM   #10
Drives: 30R Evo 8
i was in the high 11's low 12's boosting a/f's before any overboosting
__________________
E-85 Fed GT3076R
*Stock Block
*Stock ECU
Offline
Old Sep 30, 2009, 08:57 AM   #11
Personal Sales Rating: (6)
JJsEvo8's Avatar
Drives: Evo8.8, and a DD
I just got a similar tune last weekend. For E85, my guy has the boost A/F set to right at 12.0, and i have no knock at all. A 9.8 is definitely way way too rich, your spark plugs are going to foul out.
__________________
_______________________________________________
Interior: Leather Recaro Seats / MR Gauge Pod / Evo IX Pedals
Power: IX Turbo / HBC / Walbro / K&N / Forge RS BOV / JunB.L TBE / Precision 880cc / E85 / ARP Headstuds / Fuel Rail
Misc: Vortex Gen / Rear Wing Lip / BeatRush UnderTray / IX SE BBS / ACT HD
Quote:
Originally Posted by eldiablo79 View Post
In my experience we don't leave our girlfriends for the fat ugly girl, we go for the sexier hot one that does everything you like. I think it should be the same for choice of cars.
Offline
Old Sep 30, 2009, 08:35 PM   #12
Lance,
Are you seeing the 9.8:1 AFR all across the rev range when in boost? Or is it simply richening up right at the peak? Your screen shot does not show RPMs.
If AFR's are simply 'spiking' to 9.8 right at peak RPM, that is most likely the way your tuner intended. Seems too rich to me, but your tuner may have their reasons. This would not be a problem.
However, if your AFR's are 9.8 all across the boosted rev range, that is way too much fuel. You are washing the oil off your pistons. OUCH!
What are your AFR's at 4,000, 5,000, 6,000, 7,000, and 8,000 RPMs? Approx.
__________________
E85 Hints and Tips
Offline
Tags
af, boost, e85, lean, rich, spike, sti
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
