Aug 28, 2009, 01:52 AM
Personal Sales Rating: ( 0)
Drives: 30R Evo 8
E-85 a/f
where should it be around?tuned
__________________
465 Whp / 385 Wtg @ 28.5 Lbs Of Boost
E-85 Fed GT3076R
Road Race Engineering
*Stock Block
*Stock ECU
*Map Switching E-85/91
Offline
Aug 28, 2009, 08:54 AM
Personal Sales Rating: ( 86)
12 on wideband tuned for gas seems to be the majic number.
__________________
early evo nut rockin
evo1 and evo 4
Offline
Aug 30, 2009, 08:44 PM
Personal Sales Rating: ( 9)
Drives: 2008 Evolution X GSR 2004 Evo VIII RS (sold)
So what would be getting too lean? I see 12.4-12.5 when it's cooler out with E85, is that a problem?
Offline
Aug 30, 2009, 08:52 PM
Silver Sponsor +1
Personal Sales Rating: ( 445)
Drives: 2008 Evolution GSR SSS, 2005 Evolution MR, 2003 Evo GSR, 1995 TsiAWD, 1995 GST, 1995 Tsi 2wd, 1991 GVR4 WW, 1991 GVR4 NBM, 1993 TsiAWD, 1991 Tsi, 1995 RS N20
Quote:
When you lose power or melt valves.
__________________
2005 Evolution VIII MR
763whp/595tq HTA86
10.19 & 143.3mph stock ECU
Factory ECU Expert
12.0@113mph Full Wt+
In House Mustang Dyno AWD-500!
www.ttp-engineering.com
(407) 475-0010
AIM=TTPEngineering
MODIFYING THE 4G63 SINCE 1995, YES 14 YEARS!
TUNING EVO V - EVO X & 2009 RALLIART!
TTP's Myspace page!
Offline
Aug 31, 2009, 12:04 AM
Personal Sales Rating: ( 2)
Drives: 2006 Evo Mr/ 04 Srt-4/02 Is300
when your wot??
Offline
Aug 31, 2009, 07:03 AM
Quote:
you would have to try pretty hard to melt valves using e-85.
I have seen EGT around 680C at WOT at 12/1 A/F
I have seen EGT around 720C at WOT at 12.9 A/F
I am truly amazed at low EGT from E85. I read EGT drops about 200C from gas. I wouldnt have believed it with out seeing it myself. I would say it runs 100-150C cooler than gas.
low EGT = happy engine
__________________
evo1 and evo 4
Offline
Aug 31, 2009, 08:58 AM
Silver Sponsor +1
Your probe is likely a high mass, slow reacting probe.
Try another probe because I do not believe yours is accurate or you have it in an area downstream that is cooler than an inch or so from the exhaust port.
We have tons of datalogs of EGT and know that exceeding 900*C is not very difficult and it does not take an extremely lean mixture to achieve it.
__________________
763whp/595tq HTA86
Factory ECU Expert
(407) 475-0010
AIM=TTPEngineering
TTP's Myspace page!
Offline
Aug 31, 2009, 10:11 AM
Its TRE fast acting probe (zeitronics) . its in the middle of longest runner of evo 10 mani. reads about 75 lower than typical install ( 2 inch from head). direct back to back switch from 93 to e85 yielded ~125 cooler EGT. if you are getting same EGT as gas one of us is doing something wrong. if its me than I have higher power to look forward to.
also just some part throttle observations. tune lean for gas mileage. same car same setup.
93 octane cruised at 750c. 16.5 A/F
E85 cruises at 640C. 18 A/F
I am have always tuned with EGT. very helpful in my experience.
__________________
evo1 and evo 4
Offline
Aug 31, 2009, 10:32 AM
Silver Sponsor +1
This is a current model probe from zeitronix. I do not believe what you are using is the same probe.
We can easily see 850-900*c with this probe on E85
[IMG]  [/IMG]
__________________
763whp/595tq HTA86
Factory ECU Expert
(407) 475-0010
AIM=TTPEngineering
TTP's Myspace page!
Offline
Aug 31, 2009, 04:50 PM
Drives: 30R Evo 8
so in the 12's lol kinda went off topic
__________________
E-85 Fed GT3076R
*Stock Block
*Stock ECU
Offline
Aug 31, 2009, 08:01 PM
Personal Sales Rating: ( 6)
Drives: 03 EVO VIII some mods, 91 AWD Talon built motor sc61 turbo etc, 2006 GSXR1000 low long and modified
It depends on Ethanol content as to how lean u can get away with... More Ethanol content the leaner you can run it. I try to shoot for around 12.0 to mid 12s with the E85 we get around here. Some have to run it 12.0 to higher 11s... But if I try and run the E85 we get in this area in the mid 11s then I cant get away from false knock as it will knock like mad on a stock ECU until i lean it out some "12.0-12.5" and then it picks up quite a bit of power and will accept timing advance! I have tuned MANY MANY EVOs from AEM to stock ECU setups. I have been tuning with E85 for id say the better part of a year day in and day out on my car and others.... and you basically just have to go off what the car is telling you as theres really no set in stone answer here. But 12.0 i would say is the middle of the road. I hope this helps some...
Offline
Sep 1, 2009, 11:08 AM
Silver Sponsor
Personal Sales Rating: ( 4)
Drives: EVO, STI
I've seen the same type of spread from gas on multiple cars and Mike has seen the same on our Time Attack Subaru. Which also has 4 EGT's, one per runner now so we should be getting even better data.
E85 produces lower EGT's, I've seen it for over a year with E85 in multiple uses (track, street, drag)
I can imagine if I just had data from one shop car that just recently switched to E85, it might be biased one way or the other.
- Bryan
Offline
Sep 1, 2009, 11:59 AM
Silver Sponsor +1
Unlike some others, we actually have datalogs proving our information to back up our fingers at the keyboard.
We have data from multiple Evo's supporting our information, as always.
We are also aware that 94AWDCoupe runs 10's AFR which is why his EGT is so cold.
__________________
763whp/595tq HTA86
Factory ECU Expert
(407) 475-0010
AIM=TTPEngineering
TTP's Myspace page!
Offline
Sep 1, 2009, 12:09 PM
Personal Sales Rating: ( 5)
Drives: evo 8
I'm on a gt35r stock block on 1000cc injectors on 26psi on e85, it leans out to 12.6 sometimes and it seems pretty happy with no knock at all.... its all in your tuner man...
__________________
mods: Agency power turbo kit, GARRET dbb gt35r, Ap intake, custom licp , FORGE mbc, JGT catback, PERRIN test pipe, , AEM wideband, EXEDY stage 2 PP with ACT 6 puck, ACT streetlite FW , WALBRO fuel pump, FORGE bov, huge ebay front mount, HKS 280s, 1000cc injectors, ARP headstuds, AMS mini battery with ams battery tray, omni power coilovers, WingzPerformance tune
http://i188.photobucket.com/albums/z...e/e85ftw-1.jpg
best 1/4 mile time on e85 (8 turbo)
12.2 @ 116mph
Offline
Sep 1, 2009, 12:19 PM
Personal Sales Rating: ( 33)
Drives: Evo IX MR
Quote:
That's my limited experience as well. When I was briefly on about 60% ethanol (read from my eth content gauge), I ran the same fuel and timing maps as my 74% ethanol tune, and the car was quite happy with the mid 11's AFR that the greater amount of gasoline caused. No knock, great power.
94AWDCoupe's post indicatesthe EGTs were obtained with AFRs of either 12.0:1 or 12.9:1.
__________________
Works drop-in :: AMS LICP :: English Racing ported EM and HS :: Titek v2 O2 :: Helix v2 DP :: MIL.SPEC 100 cps cat :: RRE Stealth Stainless :: Walbro :: FIC 1050s :: E85 :: self-tuned :: 26.5 psi :: 340wtq/375whp VDR 5.71 EvoM mode, 77°F
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
