Aug 15, 2009, 11:25 PM
Personal Sales Rating: ( 3)
Drives: 03 EVOLUTION
e85 ON STOCKER
If an evo is completely stock could it run e85 with just tune???
Offline
Aug 16, 2009, 06:11 AM
Personal Sales Rating: ( 2)
2005 Mitsubishi Lancer Evolution My Garage
Drives: 96530006
The stock VIII pump is pressure-limited (it has a bypass valve that prevents you from running more than around 67psi of fuel pressure, or around 24-25psi of boost), but as long as you can keep boost down around 20psi, it can flow around 170lph, or around 700 cc/min per injector. (The IX pump will do the same up to around 70psi of fuel pressure, or roughly 27psi of boost; up at about 80psi FP/37psi boost, it's flowing around 600 cc/min.)
The stock injectors are rated by ND at 560cc/min. That's pretty well-matched to the injectors, as I've mentioned here before; assuming the injectors are sufficient, the pump will keep up.
The question, then, are the injectors large enough. I'm having a hard time locating what airflow rate a stock, untuned Evo VIII will produce, but let's assume for a moment that the stock VIII did as well as today's X, which pushes about 33lbs/min in stock form (it's a high estimate, obviously). That makes those 560cc/min injectors just about perfect for pump gas.
And about 33% too small for E-85; you want to assume, all other things being equal, that you'll need about 1/3 more fuel for E-85 (that percentage actually moves around a bit, and has a lot to do with your target AFR, but it's a safe number).
Summary: get larger injectors and a higher capacity fuel pump. The sizing of those upgrades is left as an exercise to the reader.
(I could have just said "no, you need injectors and pump", but hopefully some folks will read this and understand how to work this kind of thing out themselves. The fuel system is one of those few areas of the car where an average person with a calculator and Google can figure out a reasonable configuration ahead of time.)
Offline
Aug 16, 2009, 03:01 PM
Drives: '03 EVO VIII, '04 Prius
I'm not disagreeing with logic's conclusions, but I think the simple answer to your question is: YES.
Plus, there are other reasons for running E85 than simply making maximum power.
Politics - perhaps an EVO owner may simply wish to send less of their hard earned money overseas for mid-east crude oil.
Environment - perhaps an owner might want to consume less crude oil and use significant amounts of renewable energy in their car.
I am still convinced that even with all of the caveats mentioned by logic, a bone stock EVO would still make more power on E85 than on gasoline. Even if the boost had to be turned down to accommodate the 30% fuel flow issue.
So far, to my knowledge - and I have searched, no one has tuned a bone stock EVO on E85. All it would take is a tune and maybe an MBC. I'd love to see a shop do this. Probably not a good idea for a EVO owner with absolutely no tuning experience, however.
__________________
\\ IX Turbo \\ Walbro FP \\ HKS 264/264 \\ RC 1,000cc injectors \\
\\ Helix DP \\ Helix TP \\ Greddy EVO2 (modified to 3") \\ APS BOV/DV \\
\\ ETS 3" FMIC \\ Nisei LICP \\ PPI ported exhaust manifold \\ SS eBay O2 \\
\\ BR cone filter \\ BR MAF pipe \\ Hallman MBC \\ E85 \\ 394whp/418trq \\
E85 Hints and Tips
Offline
Aug 16, 2009, 08:57 PM
Personal Sales Rating: ( 1)
Drives: '04 BBY Evo VIII (Gone), '06 GG Evo IX
I ran my Evo on Denso 660 injectors and a walbro for 6 months. The injectors were max'd at 120% duty cycle according to EvoScan. Yes it can be done, but you'll just be limited on how much boost you can safely run. Typically, injector duty cycles at 80% or below is a safe zone. So, me running at 100+% is something i don't recommend....
Offline
Aug 16, 2009, 10:04 PM
Simon, how much boost were you running at 100%+ duty cycle? Were you hitting the 120% at peak torque, or at peak RPM? I assume that was only briefly?
Jim
Quote:
__________________
E85 Hints and Tips
Offline
Aug 16, 2009, 10:06 PM
Does anyone know the answer to this: if 100% IDC means the injector is fully open, then does 120% mean that the ECU is capable of increasing the fuel pressure?
If not, how can the injectors flow 120% of normal max?
Or is this simply a calculated number in EVOscan, as opposed to a direct reading of injector voltage? Or is the ECU capable of increasing the voltage to 120%, but in reality the injectors are not flowing any more than they are at 100%?
Just curious.
__________________
E85 Hints and Tips
Offline
Aug 16, 2009, 10:07 PM
Drives: 96530006
It's just a calculation, based on IPW. Don't take it too seriously.
Offline
Aug 17, 2009, 09:48 AM
Quote:
Jim
I don't recall what RPM this was occuring at since my tuner had all the logs and this was done a long time ago...
Offline
Aug 20, 2009, 01:07 AM
Personal Sales Rating: ( 18)
Drives: A Black Mamba in kill mode all day 'eh day as when I hit the gas she goes fast!
Very interesting thread indeed. I have a 255lph fuel pump along with a MBC, APS twin vent BOV, GSC 264s, and Injen CAI, UICP, LICP. I've already been tuned for pump already and I, too, believe that running E85 would result in more power even with a lower boost level than what I'm making on pump.
__________________
--- Black Mamba tuned by the NTEC mad scientist with a bunch of "go fast" parts while diggin' in some V8 ass spittin' E85 venom! ---
Offline
Sep 2, 2009, 07:27 AM
I am planning to run E85 with my stock VIII turbo. I would like to only purchase injectors once regardless of the power levels I achieve. I am looking at the FIC 1250cc injectors both for my present as well as my future goals. Would they work fine with the stock VIII turbo? Thanks.
__________________
Offline
Sep 2, 2009, 10:46 AM
Personal Sales Rating: ( 7)
Drives: gg mr
Quote:
yes they will be just fine and you have asked this question twice.
__________________
Quote:
Originally Posted by dan l
Pretty soon its going to be like the engine room in star trek with ****ing lights, horns, and steam valves going off when **** hits the fan.
IX turbo
ETS FMIC, hard pipes and maf pipe
IX bov
FIC 1050s
TephraMOD 96530706
Machine work by Watt Bigham and built by ME.
Big THANKS to the guys at Evolution Dynamics
Offline
Sep 2, 2009, 01:01 PM
Sweet. I'm just on rapid fire here in Iraq trying to get things straight for when I get home.
__________________
Offline
Sep 2, 2009, 08:44 PM
You deserve a salute!
Now get your azz home.
__________________
E85 Hints and Tips
Offline
Sep 3, 2009, 03:05 AM
I'm working on it my friend. This is my fourth deployment since 2004 and I need a break.
__________________
Offline
Sep 3, 2009, 05:40 AM
Personal Sales Rating: ( 8)
Drives: Electron Blue EVO IX SSL GSR and 01 IS300, previously 98 ITR, B18C5 93 Hatchback, 04 BO SRT-4,
Man Thank you for your service. I can't believe you've been 4 times. Be safe and make it home in one piece. I don't want to say you're lucky but you are def. blessed with the craziness going on over there.
__________________
Greddy Ti-C TBE
BC Racing Inverted Coilovers
60 mm Defi BF Boost, Water Temp, Oil Pressure
Gruppe-S Gauge Panel
AEM UEGO
Perrin Air Filter
1200cc PTE
Walbro 255
3000/6000k HID f-lights/h-beams
Ebay 02 Housing
Kelford 272's
Supertech Dual valve springs/retainers
HKS EVC VI
APS BOV
Shep Stage 2 TCase/Tranny
ATS Triple Carbon Clutch/Flywheel
Rota Grid 18X9.5 +20
JDM Rear tail lights/Bumper
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
