Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Alternative Fuel
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 13, 2009, 08:20 PM   #1
Personal Sales Rating: (0)
sdfontanini's Avatar
low rpm knock with e85
weird phenomenon.
Evo VIII on e85 getting high knock counts, with evoscan in low rpms 2800-3200 rpms....
Above 3200 I can rip on the car without a count... below and gradually rises.
Tried changing the timing, both down then up. Nothing happened, same response, Leaned it out a bit, and nothing happened. back to timing and nothing.
I'm just stumped... Only other issue I hear is my power steering pump, which wines like a dying bird... thought that could be setting it off but I won't know till I replace it.
Got M2's, 16g, and fullrace header.
Offline
Old Aug 13, 2009, 08:22 PM   #2
Personal Sales Rating: (9)
str8kor's Avatar
Drives: Evolution
Send a message via MSN to str8kor
hermmmm
__________________
aem intake, hks ti catback, invidia test pipe, downpipe, ported mani, hks 272s, fidenza camgears, 1200cc injectors, motor mounts, torque dampener, fp green turbo, ams intercooler and piping, hks ss bov, aem ems, cosworth head studs, walbro 255 fuel pump, hks DLI ignition amplifier, apexi n1 coil, act 2700, ams mini battery, slotted rotors, defi boost, egt, oil temp, aem wideband, apexi tt,e85. 426whp @ 27psi
Offline
Old Aug 13, 2009, 09:43 PM   #3
Personal Sales Rating: (1)
RoadSpike's Avatar
Drives: 2004 Evo RS
Send a message via AIM to RoadSpike
Sounds like classic phantom knock to me.
__________________
Car: 2004 Evo RS on E85 with Speed Density ECU mod
Buschur Parts:
Cone filter , IC pipes, Race Intercooler
Other parts:
Zeitronix WB,Tial Sport Q, Walbro 255lph, ACT 6 Puck with prolite flywheel ,GSC S1 cams, 1200cc injectors, Cobb catbac, Helix downpipe & O2 Outlet, 100 cell cat, 3 Port , FP Red, Stock ECU, Stock block/head/intake/tb
Offline
Old Aug 13, 2009, 10:01 PM   #4
Well I've been reading threads for the last two hours and could be a number of issues.
Here's just a few mechanical issues that could be the problem:
- Cam not lined up properaly
- Jumped timing - valve train
- clutch, exhaust, header vibrating
Offline
Old Aug 13, 2009, 10:37 PM   #5
Personal Sales Rating: (8)
Drives: Electron Blue EVO IX SSL GSR and 01 IS300, previously 98 ITR, B18C5 93 Hatchback, 04 BO SRT-4,
Send a message via AIM to Green Meanie Send a message via MSN to Green Meanie Send a message via Yahoo to Green Meanie
If he jumped timing then he'd have bigger issues then low RPm knock....more then likely something is setting the knock count off and at lower RPM's your cams might cause it vibrate more then normal (You might be on to something with the power steering making noise). If your exhause is hitting something and making a metal on metal sound I've seen that give phantom knock as well.
What count? 2-3?
__________________
Greddy Ti-C TBE
BC Racing Inverted Coilovers
60 mm Defi BF Boost, Water Temp, Oil Pressure
Gruppe-S Gauge Panel
AEM UEGO
Perrin Air Filter
1200cc PTE
Walbro 255
3000/6000k HID f-lights/h-beams
Ebay 02 Housing
Kelford 272's
Supertech Dual valve springs/retainers
HKS EVC VI
APS BOV
Shep Stage 2 TCase/Tranny
ATS Triple Carbon Clutch/Flywheel
Rota Grid 18X9.5 +20
JDM Rear tail lights/Bumper
Offline
Old Aug 14, 2009, 08:12 AM   #6
count goes all over the place, sometimes hitting as high as 30 counts. This only happens between 2900 - and 3300 rpms. It's a very small narrow band.
I definitely might have rattling issues with my exhaust, I know it almost if not does vibrated against my cusco underbrace. I've also been told it could be from my fullrace headers. Clutch is getting old and there's more chatter than before.
Offline
Old Aug 16, 2009, 12:29 AM   #7
Personal Sales Rating: (3)
ViscoS2000's Avatar
Drives: Wicked White '05 EVO
Are you throwing a P0300 code at all?
__________________
2005 Wicked White Evolution VIII-E85
412/404whp tuned by Church Automotive
1993 Nissan Sentra SE-R (NASA TTE/PTE)
Offline
Old Aug 17, 2009, 11:46 AM   #8
I'm not throwing any codes at all.
So weird, it only shows knock at really low load... and only in the 3000 - 3500 rpm range.
today on my way to work I'm cruising in 5th gear and it still does it around 3400 rpms.
Replaced my spark plugs this wkend, and no signs on the plugs of detonation...
Thinking of turning down my knock sensor sensitivity in this region...
Offline
Old Aug 17, 2009, 01:46 PM   #9
RoadSpike's Avatar
Drives: 2004 Evo RS
Thats what i ended up doing I think the cams i installed were the final straw in the knock sensor at that range.
__________________
Buschur Parts:
Other parts:
Offline
Old Aug 17, 2009, 02:59 PM   #10
So I turned down the knock sensor sensitivity. Now only seeing maybe 1 count of knock in the lower rpms. Car pulls amazing, no more falling on it's face. Like you Roadspike, I'm thinking my M2 cams are what's setting it off.
Offline
Old Aug 17, 2009, 08:36 PM   #11
Personal Sales Rating: (2)
lan_evo_mr9's Avatar
Drives: 88590715
I had the same issue. It is phantom knock (assuming your mapping is correct). If you are able to adjust knock tables, then that would help.
__________________
E85 duel tephra V7 map/ J O T switch/ Fast Freddie UEGO harness adapter/ GM 3 port and some other stuff
Attempting SD in a couple of weeks
Quote:
Originally Posted by leethaxor
My motors always were more tolerant to detonation when I ran with blown headgaskets. They were always faster.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
