Aug 5, 2009, 09:15 PM
Personal Sales Rating: ( 86)
E85 big injectors low idle Q
Whats the largest injector I can run but still have nice 850-900 rpm idle?
__________________
early evo nut rockin
evo1 and evo 4
Offline
Aug 5, 2009, 09:25 PM
Personal Sales Rating: ( 2)
Drives: some 4door car with a cool spoiler and 2 radiators
im running 1000s with the green turbo my idle is right around 900 rpm feels good. only when i run the ac, every so often i get like a hiccup lol at idle but never been an issue.
__________________
"Im not a wetback, i used a raft to cross over"
--me
Offline
Aug 5, 2009, 10:26 PM
Personal Sales Rating: ( 3)
Drives: '03 EVO VIII, '04 Prius
Stock idle - 852 rpm - on RC 1,000cc injectors.
I have tweaked the idle up to 1,133 rpm when the A/C is on.
__________________
\\ IX Turbo \\ Walbro FP \\ HKS 264/264 \\ RC 1,000cc injectors \\
\\ Helix DP \\ Helix TP \\ Greddy EVO2 (modified to 3") \\ APS BOV/DV \\
\\ ETS 3" FMIC \\ Nisei LICP \\ PPI ported exhaust manifold \\ SS eBay O2 \\
\\ BR cone filter \\ BR MAF pipe \\ Hallman MBC \\ E85 \\ 394whp/418trq \\
E85 Hints and Tips
Offline
Aug 5, 2009, 10:44 PM
Personal Sales Rating: ( 1)
Drives: '04 BBY Evo VIII (Gone), '06 GG Evo IX
RC 1000's here and idles just like stock...
Offline
Aug 6, 2009, 01:09 AM
Silver Sponsor
Personal Sales Rating: ( 4)
Drives: EVO, STI
Quote:
So far 1450 BlueMax
I'm thinking of trying out a set of 1600's on my personal car just to conquer them on 91 oct (I know they work on E85) to say I did.
Offline
Aug 6, 2009, 01:11 AM
Personal Sales Rating: ( 7)
Drives: a 4088r powered banana.
I have FIC 950's now and am planning on BlueMax 1650's so I can run serious boost.
My 950's idle amazing though.
__________________
2.3L stroker, comp 280's, gt4088r, ethanol, OEM ECU with speed density, and a whole bunch of other goodies.
Offline
Aug 6, 2009, 02:27 AM
Personal Sales Rating: ( 9)
I'm running PTE 1200's and mine is at 900. With A/C on it's around 1200
Offline
Aug 6, 2009, 06:41 AM
Hmm. wonder why you guys need to bump idle with a/c? my injector dynamic 1000 idle like stock at 850 with and without a/c. but I want to go bigger to 1200s. and my second car will need even more like 14--1600. GST how do the 1450 idle with a/c? do you think you can get bosch 1600s to idle low?
__________________
evo1 and evo 4
Offline
Aug 6, 2009, 08:58 AM
Personal Sales Rating: ( 22)
Drives: eboIX
Curious why not add a FPR and second fuel pump and crank your base pressure? the ID's are designed to work better at higher base pressures. At 100 psi they will work like a set of 1600's and you will still have outstanding idle quality and all the other benefits the ID's have over other injectors.
__________________
06 Evolution IX
- Its a $15k dollar car with a $15k dollar powertrain
Offline
Aug 6, 2009, 10:21 AM
Personal Sales Rating: ( 0)
Drives: 06 IX MR
I have the target idle set at 850, but it rarely get there. Most of the time it is @1000, and if it is hot it will hang at 1100-1200. I have RC 1000cc's. It does this on 91 pump as well. I have a mini battery, not sure is that is related...
__________________
tbe/cone filter/rec. BOV/3 port solenoid/ ECU, e85 + 91 tune by MAC/1000cc injectors/fuel rail/255 pump/GTWorks springs/ds 2500 pads/custom bicycle hitch/kid seat/377hp 396tq on e; 334hp 356tq on 91 using DJ.
Offline
Aug 6, 2009, 10:46 AM
Personal Sales Rating: ( 48)
2003 Mitsubishi Lancer Evolution
Drives: 03 EVO VIII White
My Bluemax 1450's idle fine on pump gas, it just took some swearing to get them scaled. I think my intake wasn't helping the issue as I did MAF scaling to get things working correctly.
Bryan try the 1600's I've always wondered if they would work on pump gas.
__________________
jid2 Built: Now featuring E85 super fuel
2.3L - GT3076R .63A/R, ETS equal length, Kelford 272's, BC valve springs, 1mm O/S valves, FIC BM 1450's, Full-Blown dual Walbros, Buschur IC, jid2 intake, airbox, IC pipes, APS BOV, TBE, ACT HDSS, Stock ECU, 28 psi 466hp/420 ft-lb...
Build Thread
Binary Lowered Recaro Seats, Girodisc 2-Piece, brake ducting, ST43's, SS lines and ATE Superblue, KW V3's 8K/10K, jid2 flat-bottom, adjustable splitter and aero, 18x9.5 +40 NT03's 265/18/35 BFG R1's
Offline
Aug 6, 2009, 11:01 AM
Quote:
the problem with that is fuel pump wont keep up at high boost. if I crank base to 50psi the fuel pump has to do that 50psi plus the boost psi 50+35=85psi. add in pressure loss through lines and filter and pump would need to be strong at 95psi.
__________________
evo1 and evo 4
Offline
Aug 6, 2009, 11:12 AM
Drives: eboIX
Yeah I know - just add an external pump (bosch) or a twin in-tank setup?
__________________
06 Evolution IX
Offline
Aug 6, 2009, 11:28 AM
Silver Sponsor
Drives: EVO, STI
Seemed fine when it rolled out of the shop (I always test A/C idle with aftermarket injectors.)
I've tuned a couple ID 1000's on the Evo 10's and so far I really like them.
Not sure on 1600's as I haven't touched them yet.
Offline
Aug 11, 2009, 09:53 PM
Personal Sales Rating: ( 33)
Drives: Evo IX MR
My FIC 1050s idled just slightly choppy on pump gas. They flow 20-25% more than pretty much any other 1000 cc/min injector though.
__________________
Works drop-in :: AMS LICP :: English Racing ported EM and HS :: Titek v2 O2 :: Helix v2 DP :: MIL.SPEC 100 cps cat :: RRE Stealth Stainless :: Walbro :: FIC 1050s :: E85 :: self-tuned :: 26.5 psi :: 340wtq/375whp VDR 5.71 EvoM mode, 77°F
Offline
Tags
1000, ac, big, bosch, e85, evo, id, idle, injector, injectors, lancer, low, rc1000, rpm, target, tune  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
