Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Alternative Fuel
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 30, 2009, 03:22 PM   #1
Silver Sponsor +1
Personal Sales Rating: (445)
TTP Engineering's Avatar
Drives: 2008 Evolution GSR SSS, 2005 Evolution MR, 2003 Evo GSR, 1995 TsiAWD, 1995 GST, 1995 Tsi 2wd, 1991 GVR4 WW, 1991 GVR4 NBM, 1993 TsiAWD, 1991 Tsi, 1995 RS N20
Send a message via AIM to TTP Engineering
Zeitronix Ethanol Content Analyzer Installed and Reviewed by TTP!
Zeitronix had released an ethanol content analyzer gauge sometime last year and has displayed it at SEMA 2008 as well as Performance Racing Industry convention here in Orlando.
They were sure to have me check out their new ECA gauge they have produced in both blue and red LED displays. Currently only available in the rectangular gauge, their digital electronic display is designed to show the viewer the precise percentage of ethanol contained in their fuel mix.
Not only does this gauge work on standard gasoline which contains ethanol contect of up to 10% in today's fuel, but it also will also work with standard E85 stations, E98 mixes, home brewed mixes of 100% and anything in between.
It is a standard practice for Ethanol stations to periodically change the exact mix of the fuel being brought from the supply tankers available at the pump. On the Ethanol pumps you will notice a sticker indicating a minimum rating of 70% Ethanol content, much like the 10% content labels on standard gasoline pumps today.
Aside from slight variances in actual ethanol content, in many locations there is a "winter blend" major change in the content at E85 stations that take it down to the minimum 70%. They do this for improved cold start performance of the engine.
Problem is if you have been custom tuned to the edge of performance at 85% ethanol and all of a sudden got less ethanol and more gasoline, your car would no longer be tuned for the fuel content you had originally been set up to use.
On flex fuel N/A cars, these changes in content can be handled by the front O2 sensor which can adjust the fuel trims automatically. However on a high performance turbocharged engine like the 4g63 Evo at 35psi or so of boost pressure, a 15% change in alcohol content can have a serious impact on performance and octane level.
This is where the Zeitronix Ethanol Content Analyzer comes in handy.
The ECA in conjunction with the Siemens Ethanol sensor sending unit can display the exact % of ethanol contained in the fuel being provided to the engine "real time" so that you can be certain that the E85 you are pumping in your car actually contains the alcohol content your vehicle needs in order to perform safely and at it's best.
When the seasonal ethanol % changes to a winter mix, you will know it as soon as you pump it and can take the necessary steps to recalibrate your engine mapping for the lower content ethanol fuel. This will insure your car runs safely for the fuel and octane being used at the exact time of consumption.
We had the pleasure of installing this unit in our 2005 Evo VIII MR this week and its working great!
It was a pretty easy install of the sending unit.
With a self tapping screw, we were able to mount the sending unit on the firewall.
With the PNP harness available from us, we clicked it into place and ran the three wires back through the fender to the stock ECU for power, ground and sensor out to ECA display green wire.
Once wired up, we took the fuel return line off the rail and connected it to one port of the ethanol sensor. Using a short piece of fuel line we connected the other port of the sensor to the outlet of the fuel return line from the fuel rail. Once the display was mounted we were done and it was time to test it all out.
Here is a video:
There has always been ONE PROBLEM with the Siemens ethanol content sensor needed in order to connect to the Zeitronix ECA.
What is it? PRICE!
At over $700, the retail pricing on the GM ethanol sending unit makes it a bit out of reach for most, being that you also need the pigtail harness and ECA display as well to make it all work together.
Well we have some great news this week. We were able to get a custom run of Siemens GM sensors at an affordable price FINALLY! At about half the price of the dealer, a regular person can get them without breaking the bank.
If anyone is interested in putting together an Ethanol Content analyzer display, here are the parts you will need. All of which are available from us and in stock!
ZEITRONIX ETHANOL CONTENT ANALYZER GAUGE
ETHANOL SENSOR PNP HARNESS
SIEMANS GM ETHANOL CONTENT SENDING UNIT SENSOR
__________________
2005 Evolution VIII MR
763whp/595tq HTA86
10.19 & 143.3mph stock ECU
Factory ECU Expert
2008 Evolution X GSR
12.0@113mph Full Wt+
In House Mustang Dyno AWD-500!
www.ttp-engineering.com
(407) 475-0010
AIM=TTPEngineering
MODIFYING THE 4G63 SINCE 1995, YES 14 YEARS!
TUNING EVO V - EVO X & 2009 RALLIART!
TTP's Myspace page!
Offline
Old Jul 30, 2009, 05:40 PM   #2
Personal Sales Rating: (1)
There was a recent incident in N California where E85 was only E50. Such a difference can cause some serious engine damage on E85 tuned car. We also have seen E92 last summer when gas prices went through the roof. They added more E into E85.
E85 is a wonderful fuel, but you need to know what you get.
Offline
Old Jul 30, 2009, 05:44 PM   #3
skiracer's Avatar
Drives: '04 BBY Evo VIII (Gone), '06 GG Evo IX
This was last summer when gas prices were pushing $4/gallon for 87 octane...
__________________
I do not subscribe to threads, PM me for questions.
'06 Evo IX tuned by RRE Stage 1, 91 octane (320whp) and E85 (383whp)http://forums.evolutionm.net/alternative-fuel/348572-thanks-rre-stage-1e-e85-383whp-383-tq-v5-tephra-mod.html
Offline
Old Jul 30, 2009, 05:58 PM   #4
I rather get E92 than E50! But when you drive on E85 then on regular E10 gas and switch to E85 again it's not E85 unless you completely drain the tank. There is usually 2+ gallons E10 left. E85 is like a box of chocolates...
Offline
Old Jul 30, 2009, 06:11 PM   #5
skiracer's Avatar
TTP, have you tried connecting a toggle switch to get fuel temperature readings yet?
__________________
'06 Evo IX tuned by RRE Stage 1, 91 octane (320whp) and E85 (383whp)http://forums.evolutionm.net/showthread.php?t=348572
Offline
Old Aug 2, 2009, 08:00 PM   #6
Personal Sales Rating: (33)
mrfred's Avatar
Drives: Evo IX MR
Below is a pic of my flex fuel sensor install. I like the location because it ensures that the sensor is always filled with fuel.
I ended up putting the gauge in the glovebox. It just sits in there, and I used a long length of cable so I can open the glovebox and pull out the sensor to take a look at the ethanol content.
__________________
Works drop-in :: AMS LICP :: English Racing ported EM and HS :: Titek v2 O2 :: Helix v2 DP :: MIL.SPEC 100 cps cat :: RRE Stealth Stainless :: Walbro :: FIC 1050s :: E85 :: self-tuned :: 26.5 psi :: 340wtq/375whp VDR 5.71 EvoM mode, 77°F
Online
Old Aug 3, 2009, 08:39 PM   #7
Silver Sponsor +1
Once the fuel hits the sensor, there will always be fuel in the sensor.
There is no air in fuel lines after the install.
__________________
763whp/595tq HTA86
Factory ECU Expert
(407) 475-0010
AIM=TTPEngineering
TTP's Myspace page!
Offline
Old Aug 26, 2009, 04:33 PM   #8
Personal Sales Rating: (5)
2003 Mitsubishi Lancer Evolution
vigilante.zen's Avatar
Drives: Lancer Evo '03
Nice review! I want one!
Offline
Tags
air, analyzer, content, e85, eca, ethanol, evolutionm, fuel, installed, ratio, sensor, sensors, ttp, work, zeitronix
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
