May 26, 2009, 08:28 AM
Personal Sales Rating: ( 8)
Drives: Electron Blue EVO IX SSL GSR and 01 IS300, previously 98 ITR, B18C5 93 Hatchback, 04 BO SRT-4,
Question about those of you that switch between pump and E85
I ordered the map switch from one of our EVOM members and I plan on being able to switch back and forth between pump and E85 fuel maps but I have a question. I would assume that going from E85 to regular pump gas would be fine but going the other way concerns me.
Like say I use regular pump all week and on the weekend I want to use E85. I run the tank until its almost bone dry but still have some pump gas in....when I fill up on E85 do irun the risk of having bad knock count since the octane would be lowere once E85 is mixed with the pump gas left over?
A friend of mine that use to be into EVO's when he had his started making me a little worried about being able to do that. He is advocating meth but I seriously like the idea of being able to pull up to a E85 gas station and getting almost race fuel for less then what my wife pays at the pump.
__________________
Greddy Ti-C TBE
BC Racing Inverted Coilovers
60 mm Defi BF Boost, Water Temp, Oil Pressure
Gruppe-S Gauge Panel
AEM UEGO
Perrin Air Filter
1200cc PTE
Walbro 255
3000/6000k HID f-lights/h-beams
Ebay 02 Housing
Kelford 272's
Supertech Dual valve springs/retainers
HKS EVC VI
APS BOV
Shep Stage 2 TCase/Tranny
ATS Triple Carbon Clutch/Flywheel
Rota Grid 18X9.5 +20
JDM Rear tail lights/Bumper
Offline
May 26, 2009, 08:52 AM
Personal Sales Rating: ( 1)
Drives: 2003 Evo VIII
Doing that would be 'OK', but if you have your car tuned 'to a T and set to Kill' (meaning very tight timing and fuel trims), you will end up seeing knock and loosing the advantage of the tight tune. The easiest way is to get a couple cans filled with E85, go home, drain the fuel, then refill with the E85. It's really not that much more work especially if you are only doing this for track/weekends.
__________________
Works TBE (no cat), FP Green, FP O2 Housing, AEM EMS, RC 1200s, K&N Filter, AMS FMIC, Mini-batt, 255 Fuel Pump, HKS 272s, ARP Head Studs, Works Alum Flywheel, Works Clutch Kit 1, Halman MBC, Works Brake Package 2...plus little stuff.
Offline
May 26, 2009, 09:38 AM
Drives: '04 BBY Evo VIII (Gone), '06 GG Evo IX
When I switch from pump gas to E85, i usually wait till my fuel light comes on, then drive 10-15 more miles. Then i put in E85 and i set my boost at slightly less than i was initially tuned at. I.E. I was tuned at 28PSI on pure E85. So, when i switch i set my boost around 26-27psi. On my next tank of E85, i turn it back up to 28psi
Offline
May 26, 2009, 09:49 AM
Thats cool. I plan on running E85 as often as i can actually if I drive up to Toronto or run errands around town there is really no point inhaving it...unless I just want to drive like Grandma and save a few pennies.
__________________
Greddy Ti-C TBE
AEM UEGO
Perrin Air Filter
1200cc PTE
Walbro 255
Ebay 02 Housing
Kelford 272's
HKS EVC VI
APS BOV
Offline
May 26, 2009, 09:55 AM
Drives: Tarmack Black 2006 EVO IX MR "Black Beast", Gunmetal Grey 2007 Outlander, Octane Blue 2008 EVO GSR
that's alot of work LOL
__________________
2006 Tarmack Black EVO IX MR Highly Modded 711WHP 603 TQ "Black Beast"
2007 Gun metal Grey Outlander XLS stock
2008 Octane Blue EVO X GSR Stock for now....
"Get Boosted"
Check out my website:
http://mitsubishievoix.ning.com/
Offline
May 26, 2009, 10:06 AM
Personal Sales Rating: ( 9)
Drives: 05 VIII Tarmac Black
I definitely do no plan on switching that often, but when I switch I will basically just do the same as skiracer. I will baby her through the first tank, and let it rip on the 2nd full tank.
__________________
05 TB EVO8
|Helix 272's|Helix Cam Gears|Helix Exhaust|PPI Intake Tube|PPI UICP|EPM LICP|APEXi Air Filter|APEXi AVC-R|Megan V2 DP and Testpipe|APS BOV|Works Short Shifter|Zaklee Bushings and clear cam gear cover|Walbro FP|EPM O2 Dump|PPI Ported/Swain Coated Exhaust Manifold|PPI ported Hotside|FP Ported and Polished Green|FIC 1050s|LC-1 Wideband|CA670 Remote Start|Exedy Twin HD|4WS Tuned
Tuned 93 at 25psi, now tuning E85 at 30!! ;)
Offline
May 26, 2009, 10:29 AM
I want to switch whenever I can, fill up!! There are not enough E-85 spots, So I want to get it whenever I'm around one and can fill up.
__________________
"Get Boosted"
Offline
May 26, 2009, 10:58 AM
Personal Sales Rating: ( 2)
Drives: 88590715
I don't have any issues switching one way or the other. I just take it easy for the first 30-50 miles of a new tank. I switch twice a month, if not more. No issues- as long as your tune and latencies are correct.
__________________
E85 duel tephra V7 map/ J O T switch/ Fast Freddie UEGO harness adapter/ GM 3 port and some other stuff
Attempting SD in a couple of weeks
Quote:
Originally Posted by leethaxor
My motors always were more tolerant to detonation when I ran with blown headgaskets. They were always faster.
Offline
May 26, 2009, 09:35 PM
Personal Sales Rating: ( 3)
Drives: '03 EVO VIII, '04 Prius
I think once you are used to the extra 75HP and 100 ft lbs, you will want to make the extra effort to run E85 100% of the time. It is by far the most cost effective mod. Period.
__________________
\\ IX Turbo \\ Walbro FP \\ HKS 264/264 \\ RC 1,000cc injectors \\
\\ Helix DP \\ Helix TP \\ Greddy EVO2 (modified to 3") \\ APS BOV/DV \\
\\ ETS 3" FMIC \\ Nisei LICP \\ PPI ported exhaust manifold \\ SS eBay O2 \\
\\ BR cone filter \\ BR MAF pipe \\ Hallman MBC \\ E85 \\ 394whp/418trq \\
E85 Hints and Tips
Offline
May 26, 2009, 10:32 PM
75 over stock? How does that feel? Must feel good!!
__________________
"Get Boosted"
Offline
May 26, 2009, 10:36 PM
Drives: 2006 IX Apex Silver
Quote:
+1
__________________
E85
TUNED BY Diiirk
SPONSORED BY:AWD MOTORSPORTS
(954) 753-6006
Offline
May 27, 2009, 10:06 AM
One of the reasons i want to run it.
__________________
Greddy Ti-C TBE
AEM UEGO
Perrin Air Filter
1200cc PTE
Walbro 255
Ebay 02 Housing
Kelford 272's
HKS EVC VI
APS BOV
Offline
May 27, 2009, 12:27 PM
I'm hoping to get 730 on E-85 that's about an extra 470whp yea!
__________________
"Get Boosted"
Offline
May 27, 2009, 05:09 PM
Drives: 2004 Evo VIII, 2009 Civic SI Coupe
i switched back once but i find it almost as easy to just find the corn than mess with draining the tank... the car feels like a dog on the 93, i'm not going back, haha.
__________________
2004 SSL Apex Silver Evo VIII
AMS CAI, Megan 3" TBE, Ebay O2 Housing, Walbro 255lph, PTE 1000's, Ported IX turbo and Manifold, Hallman Evolution RX BC, HKS SSQV BOV, AEM UEGO Wideband, AMS tuned on E85
347whp/ 371 ft-lbs
12.19@113 , 1.70 60'
Offline
May 27, 2009, 07:47 PM
Quote:
Approx. 50-75 whp and 75-100 ft lbs over whatever you had before switching to E85, assuming an EVO with most of the typical bolt-ons.
Not so much on a bone stock EVO, but I've not seen a bone stock EVO running E85. I would like to however.
__________________
E85 Hints and Tips
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
