Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Alternative Fuel
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old May 20, 2009, 02:40 PM   #16
Personal Sales Rating: (33)
mrfred's Avatar
Drives: Evo IX MR
I now have control over the ISCV step setting specifically when the starter is cranking. I've upped the values by about 12 (and have confirmed the increase in ISCV step with EvoScan), but so far, no obvious improvement in warm start. I will try higher values today.
__________________
Works drop-in :: AMS LICP :: English Racing ported EM and HS :: Titek v2 O2 :: Helix v2 DP :: MIL.SPEC 100 cps cat :: RRE Stealth Stainless :: Walbro :: FIC 1050s :: E85 :: self-tuned :: 26.5 psi :: 340wtq/375whp VDR 5.71 EvoM mode, 77°F
Offline
Old May 20, 2009, 06:21 PM   #17
Personal Sales Rating: (4)
RAbishi's Avatar
Drives: EVO IX MR
Quote:
I upped my values (10-20steps) and it did not seem to effect the warm start issue. It seems to me that it would be a fuel issue, because if you start the car when it is warm and it cranks for a few extra seconds than normal and then you shut off the car and try to start it again right away, it will start up just fine. The Coolant temp doesn't change, and neither does the idle step value. But the first time it takes longer to start.
__________________
Ryan
E85 Powered
2006 Evo IX MR
1991 Toyota MR2 Turbo
Youtube Channel
Offline
Old May 20, 2009, 06:38 PM   #18
mrfred's Avatar
Drives: Evo IX MR
Quote:
Yep, I tend to agree, but wanted to explore whether opening up the ISCV more could help. Its a pretty confounding situation.
__________________
Offline
Old Jul 29, 2009, 11:20 AM   #19
97TSiAWD's Avatar
Drives: '06 MR
Send a message via AIM to 97TSiAWD
I'm bringing this topic back to see if anyone has any updated information on the warm start issues. I have tried playing around with the Idle Stepper Lookup table with no discernable change in my warm starting (E85, 1250cc injectors). I have since changed the settings back to stock since the updated table values wreaked havoc on my overall idle without helping at all with warm starts.
__________________
-Jon
'06 Lancer Evolution IX MR
'97 Eagle Talon TSi AWD
Offline
Old Jul 29, 2009, 11:40 AM   #20
Personal Sales Rating: (22)
travman's Avatar
Drives: eboIX
Send a message via AIM to travman
Quote:
Originally Posted by 97TSiAWD View Post
I'm bringing this topic back to see if anyone has any updated information on the warm start issues. I have tried playing around with the Idle Stepper Lookup table with no discernable change in my warm starting (E85, 1250cc injectors). I have since change the settings back to stock since the changes wreaked havoc on my overall idle without helping at all with warm starts.
Your not the only one......no solutions as of yet.
__________________
06 Evolution IX
- Its a $15k dollar car with a $15k dollar powertrain
Offline
Old Aug 2, 2009, 08:28 PM   #21
Personal Sales Rating: (14)
2003 Mitsubishi Lancer Evolution
project_skyline's Avatar
Drives: 03 EVO8, 05 R6
Send a message via MSN to project_skyline
Ya warm start is horrible. I gotta hold the gas down for it to start.
__________________
03 Apex silver EVO VIII 12.25@113 1.83 60' @ 4800 ft
stock 9 turbo, stock ecu, stock block e-85
Offline
Old Aug 3, 2009, 02:43 AM   #22
Personal Sales Rating: (9)
Yamahar1's Avatar
having the same issues...takes me like 1-2 minutes to start the darn thing.
Offline
Old Aug 4, 2009, 02:28 AM   #23
Yamahar1's Avatar
Any new findings??? This hot start crap really sucks!
Offline
Old Aug 5, 2009, 12:16 PM   #24
I changed IPW starting by %10 i believe, no longer have to press the gas but the car still doesn't instantly fire up. Im going to try higher values.
__________________
Offline
Old Aug 5, 2009, 02:18 PM   #25
Silver Sponsor
GST Motorsports's Avatar
Drives: EVO, STI
Yea it sounds like you guys need to tweak the startup IPWxCoolant Temp more.
Log what your coolant temp is when you get the hard starting and tweak the corresponding cell.
__________________
GST Motorsports
2439 Industrial Pkwy. West Suite A
Hayward, CA 94545
510-264-9049
The original E85 Army
http://www.gstmotorsports.com
Offline
Old Aug 5, 2009, 02:57 PM   #26
travman's Avatar
Drives: eboIX
I have tweaked it constantly to both ends of the spectrum...i even zero'd it out and it made little to no difference in the ipw values at start up I was logging.
Its really bad in the 50c range for me (usually when the car sits for about 30 min)...After about 15 min is when the startup gets sketchy...i have noticed that if i start cranking and then go wot it will fire on the first set of cranks but still has longer than normal cranking (i actually hear the cranking speed increase). Sometimes i smell fuel and sometimes I dont - so its hard to diagnose if its getting to much fuel or not enough.
I have put in a new walbro, new oem FPR, i added a fuel pressure gauge and I am getting factory spec fuel pressure - I am getting FP during cranking as well. I had the company send me a different set of injectors (made no diff.). I seafoamed the motor last oil change through the IM thinking maybe valve deposits, etc...Didn't make even a slight difference but the smoke show was cool. I am getting no abnormal FP leak downs after the car sits, seems to be all in spec regarding fueling.
best part is I put the stock injectors back in all is well though......its not the injectors because the first set before being returned was tested in a car that starts fine in all conditions and the injectors fired no problem in this car. I even run the same settings as this other car, plus flashed the entire rom onto my ecu with just an immob. change and made no difference.
My trims are as perfect as you could ask for....its baffling to say the least
__________________
06 Evolution IX
Offline
Old Aug 5, 2009, 05:22 PM   #27
Thats really weird. Because i just tuned my friends 9 for e85, on 1200 PTE's this thing starts like its on pump gas when the thing is dead hot.
Im absolutely baffled.
__________________
Offline
Old Aug 5, 2009, 06:40 PM   #28
travman's Avatar
Drives: eboIX
It actually warm starts better on e85......on 93 its much worse, but I have nothing to do but keep tweaking and see if someday I have a eureka! moment.
__________________
06 Evolution IX
Offline
Old Aug 5, 2009, 08:54 PM   #29
Silver Sponsor
Drives: EVO, STI
That means too much fuel on cranking with 93.
__________________
GST Motorsports
Hayward, CA 94545
510-264-9049
Offline
Old Aug 6, 2009, 09:02 AM   #30
travman's Avatar
Drives: eboIX
I have taken fuel out in increments down to zero and it doesn't change anything.....
__________________
06 Evolution IX
Offline
Tags
cold, e85, tune
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
