Mar 15, 2009, 04:58 PM
Personal Sales Rating: ( 48)
2003 Mitsubishi Lancer Evolution
Drives: 03 EVO VIII White
E85 Timing Maps
Post your E85 timing maps and list your observations and setup.
From what I've read peak torque needs a little less timing, and then you can add timing and boost from there on up...
I'm getting ready to make the switch on my 2.3L GT30R setup.
__________________
jid2 Built: Now featuring E85 super fuel
2.3L - GT3076R .63A/R, ETS equal length, Kelford 272's, BC valve springs, 1mm O/S valves, FIC BM 1450's, Full-Blown dual Walbros, Buschur IC, jid2 intake, airbox, IC pipes, APS BOV, TBE, ACT HDSS, Stock ECU, 28 psi 466hp/420 ft-lb...
Build Thread
Binary Lowered Recaro Seats, Girodisc 2-Piece, brake ducting, ST43's, SS lines and ATE Superblue, KW V3's 8K/10K, jid2 flat-bottom, adjustable splitter and aero, 18x9.5 +40 NT03's 265/18/35 BFG R1's
Offline
Apr 6, 2009, 09:52 PM
You guys suck.
I'm working on my E85 timing now. I'll post when I'm done.
Did I mention you guys suck for zero postage.
__________________
Build Thread
Offline
Apr 6, 2009, 09:54 PM
Personal Sales Rating: ( 9)
Drives: RX7 GSL-SE turbo, 05 MR Graphite Gray,02 GSXR-750, 88 supra turbo
It's classified information
Offline
Apr 6, 2009, 09:55 PM
lol j/k but you have a 2.3 so I would assume it would be a bit different then most people on here
Offline
Apr 7, 2009, 08:40 AM
We will never know if people don't post their stuff!
__________________
Build Thread
Offline
Apr 7, 2009, 08:56 AM
Drives: 07 civic, 06 evo
You are right about peak tq timing, on most cars I have tuned they don't seem to like any more than 4* degrees. After peak tq you can ramp pretty hard to whatever peak timing you want. I won't post my map, but it's peak timing is up there , lol. E85 loves timing.
__________________
Stock ECU Tuner
Tel. 954-753-6006
www.AwdMotorsports.com
* - 2003 Black Evo GSR ( T3 67mm / E85 ) - 8.75@163mph
- World's Quickest Evo 8 Street Car - 8.98@156mph
- World's Quickest / Fastest Stock Turbo Evo - 10.21@133mph ( Most-Wanted )
- World's Quickest Mivec Evo 9.05@157mph( Most-Wanted )
- Florida's Quickest Evo IX Street Car - 9.75@143mph ( Shaun's )
Offline
Apr 7, 2009, 10:06 AM
Personal Sales Rating: ( 33)
Drives: Evo IX MR
Bryan posted some timing maps in another thread very recently. I've got some stock turbo timing maps in my E85 tuning notes thread.
How much timing the car will take without knock depends a bit on AFR and a lot on RPM. Going a bit to the lean side (12:1 gasoline calibrated AFR) will make the engine more knock resistant in the peak torque range. At high rpm, E85 doesn't knock at all, and timing has to be tuned based on power rather than knock. So dyno tuning or well planned street tuning with a datalogger and a good HP/TQ calculator are needed to keep from going beyond MBT.
__________________
Works drop-in :: AMS LICP :: English Racing ported EM and HS :: Titek v2 O2 :: Helix v2 DP :: MIL.SPEC 100 cps cat :: RRE Stealth Stainless :: Walbro :: FIC 1050s :: E85 :: self-tuned :: 26.5 psi :: 340wtq/375whp VDR 5.71 EvoM mode, 77°F
Online
Apr 7, 2009, 10:36 AM
stock turbo cars or larger turbos, and at what boost?
My car is at 27psi on a GT3076R, 2.3L
Most of what I've learned about E85 has been from your detailed posts mrfred - they have been very good, I just noticed you are a WA guy - sweet. Come over and visit the west side, come to a track day or something! Bryan has been giving me some pointers as well via some PM's.
I'm using DLL power graphing to set timing. I use one specific on ramp for all of the pulls. So far it is working really well. I'm focusing on timing out the top right now as the peak torque is a little dicey with the false knock I get. I have peak torque timing around 0 to 1 degree right now. Out the top I'm at 16 degrees at 7500 RPM. I made 30 whp jump up top from 14 to 16 degrees. I'll be going up to 17 degrees and seeing what happens.
Once I'm done with the high RPM timing I'll then focus on peak torque. I plan on finding MBT, and then dropping 2 degrees as my tune needs to be a road racing approved with some margin for heat soak etc.
My AFR's are between 11.8-12.0 right now.
__________________
Build Thread
Offline
Apr 7, 2009, 11:36 AM
Drives: Evo IX MR
Here's the post with Bryan's recent info on E85 timing values:
E85 hints and tips…
My guess is that you've seen it already.
__________________
Online
Apr 7, 2009, 12:49 PM
Yeah that post is great, that's what I'm basing my values on now. I'm at 16 degrees and will be moving up to 17 and logging, and so forth.
Peak torque is harder for me with the engine noise from the built motor. I have to really raise the knock thresholds high to eliminate it. So I'm running about what the other built motors do: 19, 20, 20 and get a few counts randomly at peak torque. I'll try raising and lowering timing at peak torque and see if it has an effect on the random knock counts.
__________________
Build Thread
Offline
Apr 9, 2009, 09:06 PM
Personal Sales Rating: ( 29)
Drives: '03 CT9A / '06 MDX / '07 CBR600RR
50-Trim w/ 32psi
Observations: Power everywhere, tons of torque and great topend. Zero knock. I was considering adding more timing up top as the power continued to climb, but I was getting worried about the stock internals holding up. I'm going bigger on the turbo and built motor so I will see how much more timing it can take.
__________________
Shearer HTA3582 / Magnus V5 / GSC S2 Cams / PPI 65mm TB / Dejon 4" Intake / AMSoil 4090 Filter
FIC 1450cc Injectors / Perrin Fuel Rail / BR Dual Pumps / TiAL Q BOV / APS Catback
ETS UICP / Nisei FMIC / HKS DLI2 / Hallman MBC / E85
Speed Density via EcuFlash
Next: Wiseco 1400HD Pistons / Howards Rods / MAP Stage 4 Head / A1 L19 Studs / ACT 6-Puck
Offline
Apr 10, 2009, 09:50 AM
What Load and RPM do you hit peak torque? What load are you at by redline?
I'll have some maps ready when I get the car back together next week. My manifold cracked and was leaking pre-turbo.
__________________
Build Thread
Offline
Apr 10, 2009, 10:27 AM
Personal Sales Rating: ( 1)
Drives: 2004 Evo RS
I can post my map when i get back home late this night jid2 Its based purely off of MrFred's timing map for the most part. I had to drop some of the timing here and there on my own car to prevent knock especially in the low load area's where the EGR seems to kick in and cause all kinds of fun
__________________
Car: 2004 Evo RS on E85 with Speed Density ECU mod
Buschur Parts:
Cone filter , IC pipes, Race Intercooler
Other parts:
Zeitronix WB,Tial Sport Q, Walbro 255lph, ACT 6 Puck with prolite flywheel ,GSC S1 cams, 1200cc injectors, Cobb catbac, Helix downpipe & O2 Outlet, 100 cell cat, 3 Port , FP Red, Stock ECU, Stock block/head/intake/tb
Offline
Apr 10, 2009, 12:53 PM
Peak torque hits around 4.9-5k RPM; 2-byte load is between 320-330 at peak torque. I reach 29psi around 4.4k. At redline ~7400 rpm my load is around 280's w/ 27psi or 17* of advance. I'm able to run a good bit of timing at peak torque w/o any knock, my pumpgas maps were able to take about 1/2 as much timing as the corny gas maps.
Sorry to hear about the manifold, I used to have a RNR turbokit that I recently sold. All my power figures above are on that kit; now its Shearer/HTA35R time
__________________
Offline
Apr 11, 2009, 06:22 PM
Drives: 2004 Evo RS
Working with MrFred Timing maps which have been great so far just had to decrease timing just a little bit where the EGR kicks in and a touch down in the 250 load area around 5500rpm
__________________
Buschur Parts:
Other parts:
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
