Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Alternative Fuel
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jun 29, 2009, 02:47 PM   #31
Personal Sales Rating: (1)
EvoIX2240's Avatar
Drives: Evo IX
I will stop lurking and share what I have.
06 Evo IX / 1450cc Fic / 30R
Let me know if you think something is off the grid. I'm ok with feedback. I have not been dyno'd. Generally keep this around 27psi, but have increased to 30psi a few times. No knock
Offline
Old Jul 6, 2009, 09:09 AM   #32
Personal Sales Rating: (48)
2003 Mitsubishi Lancer Evolution
jid2's Avatar
Drives: 03 EVO VIII White
What I'm running for now. I'm getting tired of road tuning because I don't have a good place to do it and run lots of back to back pulls. So I'll wait until I can dyno the car to dial in the timing.
Timing and Fuel on E85 28 psi.
Datalog of a pull with the above tune. Spooling around 12.2 ish, powerband 11.8-11.7 AFR.
__________________
jid2 Built: Now featuring E85 super fuel
2.3L - GT3076R .63A/R, ETS equal length, Kelford 272's, BC valve springs, 1mm O/S valves, FIC BM 1450's, Full-Blown dual Walbros, Buschur IC, jid2 intake, airbox, IC pipes, APS BOV, TBE, ACT HDSS, Stock ECU, 28 psi 466hp/420 ft-lb...
Build Thread
Binary Lowered Recaro Seats, Girodisc 2-Piece, brake ducting, ST43's, SS lines and ATE Superblue, KW V3's 8K/10K, jid2 flat-bottom, adjustable splitter and aero, 18x9.5 +40 NT03's 265/18/35 BFG R1's
Offline
Old Aug 29, 2009, 09:50 PM   #33
cmj
Personal Sales Rating: (0)
Here is my work in progress.
Mods include: 80mm Red, FP-4r cams, RC 1200cc, Nesei Comp intercooler, catless tbe (stock o2 housing)
The virtual dyno run was taken today in 110 degrees ambient!
Load peaks at 414.
Offline
Old Aug 31, 2009, 07:59 PM   #34
Personal Sales Rating: (2)
Drives: 2005 EVO VIII
I just switched to E85, so hopefully I will get some time this week or weekend to tune my timing and AFR.
Quick question for you guys, though. Are you using a tool like the Virtual Dyno to plot the hp/tq changes for successive pulls while you slowly ramp the timing up? From what I understand, it's pretty easy to get to MBT and past without any knock on E-85 and if you are going past MBT, then you are losing power and giving your bearings a beating, which can eventually lead to an engine failure.
Just curious about the methods that everyone is using. When I tune this week/weekend, I am going to go up about 1-2* at a time and plot each pull on the virtual dyno to see where MBT is, then back it down a bit.
For those who have found MBT or use this method, can you mention a few load/rpm/timing values for MBT for your setup?
Eric
Offline
Old Aug 31, 2009, 08:39 PM   #35
Personal Sales Rating: (3)
Jim in Tucson's Avatar
Drives: '03 EVO VIII, '04 Prius
That is exactly the way its done!
Some use a dyno, some use DLL, some use the HP and TRQ calc in EVOscan, but most have switched to JackOfTrades Virtual Dyno.
Eric
__________________
\\ IX Turbo \\ Walbro FP \\ HKS 264/264 \\ RC 1,000cc injectors \\
\\ Helix DP \\ Helix TP \\ Greddy EVO2 (modified to 3") \\ APS BOV/DV \\
\\ ETS 3" FMIC \\ Nisei LICP \\ PPI ported exhaust manifold \\ SS eBay O2 \\
\\ BR cone filter \\ BR MAF pipe \\ Hallman MBC \\ E85 \\ 394whp/418trq \\
E85 Hints and Tips
Offline
Old Sep 1, 2009, 11:31 AM   #36
cmj
Eric
Also, it would be best to use the same road each time for your virtual dyno pulls. If you are adding 1-2 degrees and only getting a delta of 5hp it's probably time to stop.
Offline
Old Sep 6, 2009, 11:00 PM   #37
Personal Sales Rating: (14)
project_skyline's Avatar
Drives: 03 EVO8, 05 R6
Send a message via MSN to project_skyline
Here is mine.
Stock 9 turbo, 28 psi
__________________
03 Apex silver EVO VIII 12.25@113 1.83 60' @ 4800 ft
stock 9 turbo, stock ecu, stock block e-85
Offline
Old Sep 7, 2009, 01:45 PM   #38
lan_evo_mr9's Avatar
Drives: 88590715
^ Are you hitting 380 load with a stock 9 turbo?
__________________
E85 duel tephra V7 map/ J O T switch/ Fast Freddie UEGO harness adapter/ GM 3 port and some other stuff
Attempting SD in a couple of weeks
Quote:
Originally Posted by leethaxor
My motors always were more tolerant to detonation when I ran with blown headgaskets. They were always faster.
Offline
Old Sep 7, 2009, 04:55 PM   #39
According to my logs I still do for some reason. prior i was running a 36 psi spike on the street but I just run 28-30 psi. I need to check for boost leaks to find out why im still hitting 379 load @ 30 psi.
Edit: I found two leaks. One on my LICP, i guess i didn't put the clamp on right when I put it back on and my EGR blockoff is leaking. I need a better gasket lol.
__________________
Offline
Old Sep 7, 2009, 04:57 PM   #40
Silver Sponsor
Personal Sales Rating: (4)
GST Motorsports's Avatar
Drives: EVO, STI
Also if you are running a intake or induction pipe that tweaks maf readings and haven't rescaled your MAF then the load will be skewed.
__________________
GST Motorsports
2439 Industrial Pkwy. West Suite A
Hayward, CA 94545
510-264-9049
The original E85 Army
http://www.gstmotorsports.com
Offline
Old Sep 7, 2009, 06:04 PM   #41
I've scaled my ETS intake. At least I think so lol.
__________________
Offline
Old Sep 11, 2009, 08:43 AM   #42
97TSiAWD's Avatar
Drives: '06 MR
Send a message via AIM to 97TSiAWD
Here's my work in progress. Evo IX, FP Red, FP4R cams, 1250cc injectors, single Walbro, and running 31psi. I'm starting to run out of fuel near the top end, so it's time to put in the dual pump setup.
I'm also consistently seeing a peak of 310-315 load and then dropping off to 270 by redline, so I will have to rescale the maps soon. Before the cams, I was just touching 300 load with the Red.
__________________
-Jon
'06 Lancer Evolution IX MR
'97 Eagle Talon TSi AWD
Offline
Old Sep 11, 2009, 09:48 AM   #43
tnt1106's Avatar
Drives: 06 Evo IX SE
Send a message via AIM to tnt1106
Are you having any spool up, or random mid range knock issues with your setup?
Not under WOT but more like random tip in always between 3-4k rpm? (say around 2psi-15psi boost)
__________________
Thanks to all the local Evo guys:
EVOLUTION DYNAMICS LLC (Parts, Installation, Tuning. Professional, affordable, flawless work!)
ForcedPerformance (Turbo, cams that don't break! Great guys!)
Kantuning (Steve@kantuning super guy great tuner and dyno operator! Thanks Steve!)
Thedriversedge (Why own it if you don't know how to drive it? Rick@thedriversedge can teach you the skills you need.)
Colorsonparade (Superb paint repair.)
Offline
Old Sep 11, 2009, 10:59 AM   #44
97TSiAWD's Avatar
Drives: '06 MR
tnt1106: Nope, haven't seen any tip in knock or any significant partial throttle knock in my logs. I have only had the cams for a week, so I am still fine tuning and monitoring things. I have seen some sporadic 1-2 counts of knock at WOT, but I also haven't altered my knock tables at all.
__________________
-Jon
Offline
Old Sep 11, 2009, 11:10 AM   #45
Silver Sponsor
Drives: EVO, STI
How much boost are you running 6500-7500 and what MAF Hz?
__________________
GST Motorsports
Hayward, CA 94545
510-264-9049
Offline
Tags
e85, fuel, lancer, maps, quoting, ratios, register, timing, tuning
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
