Apr 13, 2009, 11:44 PM
Personal Sales Rating: ( 7)
2003 Mitsubishi Lancer Evolution
Drives: Black popcorn machine with a laptop
This is with 9.8 VIII turbo. ECU boost control with GM 3-port. (Dynoed about a month ago at 362tq/342hp on a mustang. I switched to a metal intake since then, which looks to provide ~0.5-1 psi higher than the rubber one from ~5000rpm and up, therefore increasing top-end power a bit...)
Edit: Timing is scaled as timing plus 10. (To move the graph higher, so that its easier to read for me, i did it back when i had neg timing at spool-up, DLL does not show neg values)):
Offline
Apr 14, 2009, 12:01 AM
Silver Sponsor
Personal Sales Rating: ( 4)
Drives: EVO, STI
mplspilot,
your log doesn't match the timing map you posted.
15* at 4k and 32*+ at 7k?
EDIT: nevermind I looked at the Value on the left and saw the scaling was different on timing.
Offline
Apr 14, 2009, 12:34 AM
Yeah, sorry, scaling is actual timing plus 10. Just easier to read it on the graph that way
Offline
Apr 15, 2009, 12:10 PM
Personal Sales Rating: ( 2)
Drives: 88590715
Stock turbo 28psi tapering to 24-25.
__________________
E85 duel tephra V7 map/ J O T switch/ Fast Freddie UEGO harness adapter/ GM 3 port and some other stuff
Attempting SD in a couple of weeks
Quote:
Originally Posted by leethaxor
My motors always were more tolerant to detonation when I ran with blown headgaskets. They were always faster.
Offline
Apr 15, 2009, 12:33 PM
Drives: 88590715
here ya go. I think I may be able to run a little more up top.
__________________
Offline
Apr 15, 2009, 01:35 PM
2005 Mitsubishi Lancer Evolution
Drives: 05' Burnt Orange Evo 8
hey jake!
heres mine for now. gonna fine tune soon
__________________
ARC is Rice ツ
Offline
Apr 15, 2009, 04:10 PM
Drives: 88590715
Mpls- How much boost is that turbo running that you have the map and graph shown for?
__________________
Offline
Apr 15, 2009, 05:40 PM
Quote:
It's in the middle picture, marked JDMMAP. I hit 30 psi on spool-up and it starts going down after 4500 rpm even though my WG duty is at 100% from there till redline. And by the redline it falls to ~21. I can crank boost even higher, i just wouldn't know what to do with all this tq  it's freaking massive with this tiny turbo
Offline
Apr 22, 2009, 03:51 PM
Drives: 88590715
Here is my latest with no knock what so ever. She rips. This is with a peak of 27psi and tapering to 25psi.
__________________
Offline
Jun 19, 2009, 10:56 PM
Drives: 2006 Evo SE
bump for more maps... i need a little more to soak in before i attempt my tune.
__________________
2006 Tarmac Black EVO IX SE
Power: GM 3port, JDM MAP Sensor, AEM intake, invidia O2 housing, invidia DP, invidia test pipe, Greddy Ti Racing Cat-back, RC Racing 750CC Injectors, walbro 255, Cyber Speed Hyper Ground, Cyber Speed Ignition Blade. SELF TUNED 91 oct @ 24psi SELF TUNEDE85 @27PSI
Suspension:Robi-Spec Springs
Look Good: Rexpeed VG, Rexpeed Gurney Flap, JDM Side-markers, polarized side mirrors, Cf antenna, Engine hood dampers
Offline
Jun 27, 2009, 09:35 AM
Personal Sales Rating: ( 0)
Drives: R33
After switching to ethanol, I found that I needed to add in about 3-4 degrees to my timing map just to keep from misfiring. The extra fuel volume was too much at the miniscule timing I was having to run on pump gas. After I added the timing in, the car pulled clean and I was able to add an additional 5-6 degrees in most areas.
Marshall
Offline
Jun 28, 2009, 10:37 PM
Silver Sponsor
Drives: EVO, STI
Quote:
Marshall
At what AFR?
Offline
Jun 29, 2009, 05:10 AM
Drives: R33
^high 10's/low 11's
Offline
Jun 29, 2009, 11:10 AM
Personal Sales Rating: ( 48)
Drives: 03 EVO VIII White
You should try high 11's, like 11.8
__________________
jid2 Built: Now featuring E85 super fuel
2.3L - GT3076R .63A/R, ETS equal length, Kelford 272's, BC valve springs, 1mm O/S valves, FIC BM 1450's, Full-Blown dual Walbros, Buschur IC, jid2 intake, airbox, IC pipes, APS BOV, TBE, ACT HDSS, Stock ECU, 28 psi 466hp/420 ft-lb...
Build Thread
Binary Lowered Recaro Seats, Girodisc 2-Piece, brake ducting, ST43's, SS lines and ATE Superblue, KW V3's 8K/10K, jid2 flat-bottom, adjustable splitter and aero, 18x9.5 +40 NT03's 265/18/35 BFG R1's
Offline
Jun 29, 2009, 11:57 AM
Silver Sponsor
Drives: EVO, STI
^high 10's/low 11's
On a gasoline wideband? Way too rich.
- Bryan
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
