Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Alternative Fuel
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jan 29, 2009, 11:51 AM   #16
Personal Sales Rating: (33)
ROGERV's Avatar
Drives: 05 GSR
Quote:
Originally Posted by Jim in Tucson View Post
Are you saying when boost is set at 30 it tapers to 24.5psi and when set at 27 it tapers to 23psi? Sorry, but I'm easy confused.
no it tapers to 24.5 at 7k and 23 at 8k on both boost settings. I now only run the 30psi boost setting.
__________________
E85, FP Red = 514whp 455wtq 30psi
WingzPerformance tuned
Offline
Old Jan 29, 2009, 02:03 PM   #17
Personal Sales Rating: (4)
andrewzaragoza's Avatar
Drives: 2006 Mitsubishi Evolution IX MR
Quote:
Originally Posted by mrfred View Post
I think you are too used to thinking in terms of MBCs and the cheaper EBCs. The better (more expensive) EBCs allow setting target boost settings at several points across the rpm range. The stock ECU boost control algorithm has the same feature. With this feature, "peak" boost is nearly irrelevant to the boost acheivable at high rpm. With my ECU-based boost control, whether I set the boost to 15 or 27 psi at 4000 rpm, I can still hit 22 psi at 7000 rpm (My boost level at 7000 rpm is relatively anemic because I'm still using the stock BCS and an HFC).
yes i plan to try out the ecu based boost control using gm 3 port to achieve higher boost at high rpm. what do you recommend the usual load based or is it worth it to get a map sensor and do the psi based?
__________________
-buschur tbe with test pipe
-buschur SS O2 housing
-buschur ported exhaust manifold
-nisei competion fmic plus piping kit
-nisei mini battery
-Walbro 255 Fuel Pump
-FIC Bluemax
-GM 3-Port
-aem air filter
-self tuned with EcuFlash & Zeitronix
Offline
Old Jan 29, 2009, 02:20 PM   #18
mrfred's Avatar
Drives: Evo IX MR
Quote:
I think its more personal preference as to what makes sense. I used to think that strict control over boost was needed to keep from blowing a HG or doing something worse, but its my current philosophy is that what really matters is keeping knock under control and keeping AFR is in a safe range. With that said, I like psi-based control.
__________________
Works drop-in :: AMS LICP :: English Racing ported EM and HS :: Titek v2 O2 :: Helix v2 DP :: MIL.SPEC 100 cps cat :: RRE Stealth Stainless :: Walbro :: FIC 1050s :: E85 :: self-tuned :: 26.5 psi :: 340wtq/375whp VDR 5.71 EvoM mode, 77°F
Offline
Old Jan 29, 2009, 02:46 PM   #19
Personal Sales Rating: (2)
wreckleford's Avatar
Drives: Evo I with an 8 ECU
Are all of you using stock actuators? I have tuned a car with a Green using a Forge 20psi actuator and it will hold 30psi all the way to Redlien using a Profec Type S boost controller.
Offline
Old Jan 29, 2009, 03:43 PM   #20
yes still on IX actuator. green should be able to hold more boost up top.
__________________
-nisei mini battery
-FIC Bluemax
-GM 3-Port
-aem air filter
Offline
Old Jan 29, 2009, 05:58 PM   #21
Personal Sales Rating: (3)
Knock, knock, knock, did I mention knock? Knock will lift heads and push headgaskets. Its all about cylinder pressure. Sure boost increases it, a little. Sure altering timing can increase torque and raise cylinder pressures, but only a little bit. However detonation pulses really stress those head bolts. I've lifted more heads than I care to mention. In every case the knock sum was over 20, sometimes in the 30's. One time I even had the KS maxed out and that took all but 2 seconds (without timing pull) to lift a seriously cool set of headbolts. I've had many lean spells over the years and that never lifted a head. The same is true of overboosting (without big knock on race gas), never lifted a head.
Offline
Old Jan 29, 2009, 06:07 PM   #22
Personal Sales Rating: (21)
Drives: 05 element, 03 evo (mutating)
If you are still looking for a ebc that will hold psi and get there in a hurry, I was very pleased in that regard with a turboboost 2. I need the function of boost not coming on strong at low throttle, so I am going to go "McFred/ Tephra" stock.
So I have a very well priced ebc&s fs.
Offline
Old Jan 30, 2009, 10:27 AM   #23
Personal Sales Rating: (9)
PeteyTurbo's Avatar
Drives: RX7 GSL-SE turbo, 05 MR Graphite Gray,02 GSXR-750, 88 supra turbo
Send a message via AIM to PeteyTurbo Send a message via Yahoo to PeteyTurbo
I hated the profec spec b..It was like the stock turbo was too quick for it and it always had a hard time, the mbc gives me a much better puch on spoolup.. The spec B would also make the car surge if I turned it up to high because of BOV leaking..
Offline
Tags
based, boost, controller, evo, evolution, hold, ix, location, manual, mbc, me, perrin, rpm, stock, taper, top, turbo
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
