Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Alternative Fuel
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 19, 2008, 11:53 PM   #31
Personal Sales Rating: (9)
PeteyTurbo's Avatar
Drives: RX7 GSL-SE turbo, 05 MR Graphite Gray,02 GSXR-750, 88 supra turbo
Send a message via AIM to PeteyTurbo Send a message via Yahoo to PeteyTurbo
I run the same type of timing..With a good afr it refuses to knock above 5000rpms..But before that I keep it minimal just because my car spikes a bit.
Quote:
Originally Posted by JohnBradley View Post
you can run between 16 and 17:1 cruise on E85 without misfire and run 40* of timing at cruise.
Timing maps will generally look the same at peak boost as a pumpgas map (with more boost to makeup for it), run lower timing numbers to about 5500, ramp harder to 6k and then about 10 more degrees to 8k on a stock turbo...samples would look something like this:
This was for an ETS 57 trim on E85 with stock MAF, Stock cams, 3.5" FMIC, pipes, and 28psi. It made 440whp and like 351 torque on a dynojet that always seems to read low torque (maybe rpm sync?)
Offline
Old Aug 20, 2008, 10:57 AM   #32
Personal Sales Rating: (4)
andrewzaragoza's Avatar
Drives: 2006 Mitsubishi Evolution IX MR
with a closed loop afr of 16-17 that should help a lot with fuel economy. e85 is really amazing. time to save and switch.
__________________
-buschur tbe with test pipe
-buschur SS O2 housing
-buschur ported exhaust manifold
-nisei competion fmic plus piping kit
-nisei mini battery
-Walbro 255 Fuel Pump
-FIC Bluemax
-GM 3-Port
-aem air filter
-self tuned with EcuFlash & Zeitronix
Offline
Old Aug 20, 2008, 11:08 AM   #33
Silver Sponsor
Personal Sales Rating: (17)
JohnBradley's Avatar
Drives: 06 Rally Red MR
I forgot to add on the timing, thats without adding in for the EGR dynamic advance tables that we messed with earlier in the year. Stock timing those can add up to 5-6* all on their own in most cruise ranges.
Yeah like rick james said...its a helluva drug
__________________
SparkTech The ignition of EnglishRacing
Extreme Turbo Systems Parts to go fast with
EnglishRacing contact us-sales@englishracing.net
Home of the 522whp stock turbo/no nitrous and 1117whp 2.0L turbo record.
Old numbers- 574whp@29psi stock block, 92 octane, ETS/FP3586...New Build.
Retailer of AMR Engineering Coilovers
MAGNUS Motorsport Cast Manifolds, $1000 with ETS Magnus pipe, dual rail available also.
We choose GSC cams
FIC Master Distributor
OmniPower Dealer
Offline
Old Aug 20, 2008, 11:11 AM   #34
Personal Sales Rating: (11)
Tek3Evo's Avatar
Drives: X MR
Send a message via AIM to Tek3Evo Send a message via MSN to Tek3Evo Send a message via Yahoo to Tek3Evo
wow 16-17:1. is that really that safe, that's awesome. what type of EGTs will we see running that lean.
Offline
Old Aug 20, 2008, 11:43 AM   #35
Personal Sales Rating: (33)
mrfred's Avatar
Drives: Evo IX MR
Quote:
E85 burns much cooler than straight gasoline, and on the lean side of stoich, EGTs will drop (stoich is the point of maximum EGT during cruise).
__________________
Works drop-in :: AMS LICP :: English Racing ported EM and HS :: Titek v2 O2 :: Helix v2 DP :: MIL.SPEC 100 cps cat :: RRE Stealth Stainless :: Walbro :: FIC 1050s :: E85 :: self-tuned :: 26.5 psi :: 340wtq/375whp VDR 5.71 EvoM mode, 77°F
Offline
Old Aug 20, 2008, 11:45 AM   #36
Tek3Evo's Avatar
Drives: X MR
So we are really only concerned with knock and misfire from the lean condition during cruise. Great info.
Offline
Old Aug 20, 2008, 12:22 PM   #37
Personal Sales Rating: (28)
Drives: 2005 Electric Blue Evo 8
Anyone figure out the EGR Advance tables on the 96530006?
__________________
BR parts (4WS Tuned) + E85
12.24 @ 112.0 (1.70 60') - 5/9/2008 (w/alky)
Midwest Evos
http://www.midwestevos.com
AMSOIL
http://www.amsoil.com
Offline
Old Aug 22, 2008, 12:52 PM   #38
whats the advantage of modifying the egr advance tables?
__________________
-nisei mini battery
-FIC Bluemax
-GM 3-Port
-aem air filter
Offline
Old Aug 25, 2008, 01:00 PM   #39
mrfred's Avatar
Drives: Evo IX MR
Quote:
So far, I haven't seen any changes in performance when tinkering with it.
__________________
Offline
Old Aug 25, 2008, 08:17 PM   #40
Silver Sponsor
No there isnt any performance gain, its only working in closed loop when the EGR is functioning from what we learned I thought? Maybe I misunderstood that point back when it first came to light. The advantage is that it adds timing during cruise automatically to help keep the ethanol firing off.
__________________
We choose GSC cams
OmniPower Dealer
Offline
Old Aug 25, 2008, 11:04 PM   #41
mrfred's Avatar
Drives: Evo IX MR
A few notes:
Fuel economy on my second tank of E85 was 15 mpg which is only a 25% reduction in mileage compared to the 33% higher fuel requirement to hold stoich with E85 compared to gasoline. My third tank is looking to be 15+ mpg. Strange but good.
I've been doing power tuning for the last week now. AFRs are now ~11.8:1 across the rpm range. I'm still in the early stages of tuning, so I'm just working on optimizing timing with my gasoline boost curve. I started by ramping up the timing starting from 5500 rpm. I've been able to add 4 deg of timing at 7000 rpm and still no knock at all. I've picked up an average of about 15 whp at 7000 rpm, but it seems that my last change of +1 deg more timing from 6000-7000 rpm made little or no effect on power in this rpm range. The more I mess with E85, the more I get the feeling that its possible to hit MBT with no knock. I'll post up some logs and timing maps tomorrow.
__________________
Offline
Old Aug 26, 2008, 04:17 PM   #42
Personal Sales Rating: (1)
PATRICK B.'s Avatar
Drives: 2006 EVO RS & 2003 F150 SCREW
I'm soaking this all up like a sponge......nice thread thanks guys
We are getting an e85 station real close to home so i'm thinking of making the switch when it opens in th enext few months
__________________
Sponsored by :
FULL FUNCTION TECHNOLOGY
www.FFTEC.com
SPARKTECH IGNITION SYSTEMS
www.SparkTechIgnitions.net
* 10.14 @ 141.8mph 1.52 60ft 7/18/09
* 1st place CMI Summer Nationals 09 (T4 class)
http://www.youtube.com/watch?v=gngE9rruXoQ
http://www.youtube.com/watch?v=cEVSA...eature=related
Quickest ET = 10.08
Fastest MPH = 142.93
http://www.youtube.com/watch?v=n_--AejWmzQ
Offline
Old Aug 26, 2008, 07:28 PM   #43
2003 Mitsubishi Lancer Evolution
denver's Avatar
Drives: 2003 EVO 8, '09 JETTA TDI 2009 GREEN CAR OF THE YEAR , '08 Outlander, '91 talon TSi, '03 Lancer OZ RIP!
Just so Im clear mrfred, you are referring to a/f with e85 on the gas scale? Or have you rescaled your WB for e85?
Offline
Old Aug 26, 2008, 08:00 PM   #44
razorlab's Avatar
Drives: a laptop connected to your ECU.
Quote:
I would imagine you gained more than 15whp from 4* more timing or you have already passed MBT.
I've found, depending on the setup, you can indeed find and pass MBT without knock.
This isn't our fathers pump gas.
__________________
Bryan - 05 MR - E85 and FPgreen powered
E85 Army
Offline
Old Aug 27, 2008, 04:20 PM   #45
mrfred's Avatar
Drives: Evo IX MR
I'm beginning to question the value of pushing the AFR up to 12:1 because of this. My guess is that leaner AFRs will promote a faster burn, and it seems that the stuff already burns fast, perhaps making it too fast to make good use of the combustion event. I need to do some reading, but my feel right now is that a little richer might slow the burn and perhaps distribute the combustion event over a wider range of crank angle. This may have to be balanced against the apparent possibility of a rich misfire.
BTW, I got 15.7 mpg on my last tank with standard closed loop 14.7:1. I'm really interested in reenabling my closed loop adjustable AFR patch to see if I can get 16.5 mpg or better.
__________________
Offline
Tags
afr, boost, detonation, e85, engine, evo, lean, power, rx7, supra, target, tuining, tune, tuning, tunng
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
