Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > AEM EMS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 21, 2009, 05:41 PM   #1
Personal Sales Rating: (0)
EVIL-EVO-8's Avatar
Drives: 2003 Evolution 8
AEM UEGO sensor get hot w/o engine running
Just got my car all put together and was under it with the aem program running connected to the EMS getting ready to start it for the first time w/ new motor. I touched my arm on the sensor and its hot as hell. Is this normal?
Offline
Old Oct 21, 2009, 05:43 PM   #2
Personal Sales Rating: (2)
Drives: 2006 evo ix mr
Quote:
nope not normal at all , make sure u have it wired in correctly
Offline
Old Oct 21, 2009, 06:02 PM   #3
EVIL-EVO-8's Avatar
it plugs into the aem so not sure where the problem could be
Offline
Old Oct 21, 2009, 06:07 PM   #4
EVIL-EVO-8's Avatar
its going to 4.75 volts when i plug it in. the gain isnt changing it at all
Offline
Old Oct 21, 2009, 07:25 PM   #5
Personal Sales Rating: (4)
awdboosted's Avatar
Drives: 2006 EVO IX MR
Send a message via AIM to awdboosted
If the key is on it should be hot. The sensor has a heater element on it.
__________________
Mike
AEM EMS Tuner
All Tuned by me.
-Evo IX GT30R Powered!! (10.9 @ 122) Full weight and Stock motor at 30psi
-98GSX 42R Powered!! (10.1 @ 146)
Offline
Old Oct 21, 2009, 09:40 PM   #6
EVIL-EVO-8's Avatar
ok cool. but why are the volts not changing?
Offline
Old Oct 21, 2009, 11:44 PM   #7
Personal Sales Rating: (49)
MasterNater's Avatar
Drives: '04 Evo VIII
Send a message via AIM to MasterNater
Yes, the sensor should get hot when you turn the ignition on and the engine is not running. It's simply the preheat. It's to help protect the cold sensor from suddenly getting "shocked" by the hot exhaust gases.
You said the sensor plugs into the EMS, so I'm guessing you are using the 1313U with built in wideband controller. You are supposed to calibrate the lambda sensor channel with the sensor unplugged. Then you can adjust the O2 Sensor Gain up and down until the "O2 Sensor #1 Volts" parameter reads the correct voltage of 3.94 (+/- .02 volts). I believe my gain is set at 1.26.
__________________
BR Forward Facing HTA86
BR BFIC
BR 3" V-Band TBE
BR UICP
Tial Q
AEM EMS
Kelford 272's
PTE 1000 Injectors
Walbro 255
Forge UNOS MBC
PPI Ported Stock Intake Manifold
PPI 65mm Throttle Body
Offline
Old Oct 22, 2009, 12:13 PM   #8
EVIL-EVO-8's Avatar
Ok ya I wasnt sure if it was getting hot due to the volts shooting up. I tried to set it up like the manual says with no luck. Do you control the volts with the gain? whats happening Is I changed it with the sensor unpluged then when i plug it in the volts start going up and then shoot to 5.75ish and stay there. Im not sure how to get it to stop this? Thanks, MIke
Offline
Old Oct 22, 2009, 12:13 PM   #9
awdboosted's Avatar
Because the car isn't running. Nothing to sample but just air.
__________________
Mike
AEM EMS Tuner
All Tuned by me.
Offline
Old Oct 22, 2009, 01:13 PM   #10
Quote:
Correct. When you plug the o2 sensor in and the engine is not running, it's reading 100% oxygen, causing the voltage to max out. That's completely normal. Once you start the car, and the AFR's change, the voltage will change as well.
__________________
BR BFIC
BR 3" V-Band TBE
BR UICP
Tial Q
AEM EMS
Kelford 272's
PTE 1000 Injectors
Walbro 255
Forge UNOS MBC
Offline
Old Oct 22, 2009, 04:41 PM   #11
awdboosted's Avatar
This is used to calibrate the Wideband to the EMS..
-Make sure the wizard is set up right for the 02 wizard
-Unplug the wideband from the connector next to the sensor.
-adjust gain until the AFR reads 14.7 or what MasterNater said 3.94 (+/- .02) volts in the EMS.
-Plug it in and you’re done.
Sorry to repeat, I'm just trying to give step by step instructions.
__________________
Mike
AEM EMS Tuner
All Tuned by me.
Offline
Old Oct 26, 2009, 12:55 PM   #12
EVIL-EVO-8's Avatar
ok thanks to you all! Got it figured out. Delayed another week til ignition though, Filled up the radiator and was going to start the car and now I have a coolant leak from who knows where. AARRRRGGGG complete builds suck!! issue, issue, problem, delay, delay!!! Hate this crap.
Offline
Tags
aem, air, evo, evom, hot, sensor, sucking, uego
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
