Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > AEM EMS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 5, 2009, 05:43 PM   #1
Personal Sales Rating: (0)
Drives: 05 GG Evo VIII MR
ECU Possibly going bad?
Had the AEM in the car for over a year now, no problems. Car sat in the garage with the battery disconnected for 6 months while I was over in Iraq. When I got back I put the map back on it and it ran just fine for a couple of weeks. Suddenly it started dumping a ton of fuel (to the point where it will flood itself out) and I would have to upload the tune again. It's happened several times now in the past 2.5 - 3 months. Last time it wigged out on me the fuel gauge started reading wrong. It reads almost half a tank low. I checked everything out today and nothing appears to be mechanically or electrically wrong with the car. I plugged the stock ECU in and the fuel gauge reads right and it threw no codes despite all the mods (did NOT try to start the car). I'm thinking something has gone wrong with the AEM.
Any thoughts?
Oh, and I downloaded the map from the ECU before uploading it again and did a compare. Nothing is different. However, uploading the map cleared up all the problems (with the exception of the fuel gauge) for now.
__________________
-=MI-4 EVO=-
Graphite Grey 2005 Evo VIII MR
Offline
Old Oct 6, 2009, 10:10 PM   #2
Are you sure that you are not running into corruption issues with the map? Perhaps take a fresh basemap, and then copy all of your settings over to it, load that, and see how it runs?
Offline
Old Oct 8, 2009, 11:25 PM   #3
Personal Sales Rating: (1)
Drives: 06 EVO IX SE
Send a message via AIM to dhammans
The AEM ECU's die quite often. Sad, but it's the reality. Best to call AEM for warranty work if you're still within the warranty period.
__________________
Dan Hammans
We Need More Power - www.wnmp.net
1999 Eclipse GSX - 10.66 @ 131 in 2004.
2006 Evolution IX SE - FP BlackŪ Powered.
BNIB Magnus V5 intake for sale, PM for info.
Offline
Old Oct 9, 2009, 08:00 PM   #4
I have heard of the AEM EMS going out before. I called AEM tech support. They were not helpful and quick to blame an electrical problem with the car, which I've reasonably ruled out.
I've already loaded two seperate cals to the ECU as suggested before.
__________________
-=MI-4 EVO=-
Offline
Old Oct 20, 2009, 07:40 AM   #5
Personal Sales Rating: (20)
Drives: AMS Equipped EVO VIII
Send a message via AIM to GTVEVO
The only thing I could say here is re-flashing or changing the actual firmware on the ECU incase there is any internal software corruption. Sadly AEM support seems to act this way quite often.
I agree you do have an issue and I would recommend not driving the car very far or hard without doing some more testing. To bad you don't know someone else around with the AEM to do some additional testing.
__________________
EVO VIII
Offline
Old Oct 20, 2009, 07:09 PM   #6
I tinkerd around a bit with it this weekend, built a completly new cal, updated the firmware, no change. but, the car hasn't gone loopy on me in a few weeks either.
I was looking to see if there was a way I could turn each output off individually to see the effect on the guage cluster. Looked around a bit but didn't see any options. anyone know if this is possible?
__________________
-=MI-4 EVO=-
Offline
Old Oct 25, 2009, 10:12 AM   #7
Personal Sales Rating: (4)
awdboosted's Avatar
Drives: 2006 EVO IX MR
Send a message via AIM to awdboosted
Can u post a log when the issue is happening.
__________________
Mike
AEM EMS Tuner
All Tuned by me.
-Evo IX GT30R Powered!! (10.9 @ 122) Full weight and Stock motor at 30psi
-98GSX 42R Powered!! (10.1 @ 146)
Offline
Old Oct 25, 2009, 08:55 PM   #8
Quote:
If it happens again I will.
Ever known the AEM EMS to throw off the fuel gauge?
__________________
-=MI-4 EVO=-
Offline
Old Oct 30, 2009, 08:52 AM   #9
itzwolf's Avatar
Drives: Yellow Evo VIII
Yes, there is a pin that you can pull from the plug harness to correct this issue. It's a commonly known quirk and makes the fuel gauge read about an 1/8 of a tank lower than it really is. I've dealt with it for the 3.5 years I've had AEM in my car.
I think it's been noted on these forums which pin to pull but it really doesnt have any other side effects so I wouldnt worry about it. Worst case you fill up a little sonner than normally and have less chance of running out of gas accidentally.
Offline
Old Oct 30, 2009, 08:58 AM   #10
(A)lmost (E)ngine (M)anagement (!)
__________________
Dan Hammans
Offline
Old Nov 2, 2009, 09:09 PM   #11
Personal Sales Rating: (12)
badhabit90's Avatar
Drives: '04 'mac black EVO8, '04 black onyx IS300, 1998 eclipse gst(R.I.P.), 1993 Honda Accord A.E., 1990 Ford Mustang-built 302(sold), 1971 Chevy Elco built 307
Talking
Quote:
THIS!!!!!!!!!!!!!
HAHAHAHHA: lol:
throw it away Herb. ECUflash and git er dunnnn......EVOscan to log ........1/10th the cost and you tune the same way. geez...you dont have a huge turbo, VTA, and your runnning your MAF still plenty of cars hitting 500hp with stock ecu and such...
OH and get the cable also........
so, you have
99 bucks for the cable
20 dollars for the EVOscan when you get the cable at the same time
ECUflash-FREE!!!!!
AEM ECU -1200bones.......and its dying....no support from AEM...boo that noise.
soo, you have 119 bucks invested with the same tuning capability just about with factory knock safety.....logged my tune for 45 minutes..various driving....0 knock under boost. at 22psi. WORKS tune
__________________
Helix intercooler pipes,Helix 3" DP,Helix 3" exhaust,Invidia o2,Helix DNA coilovers, WORKS filter,3" WORKS HFC,Greddy Type S,FPWR Turbo w/Ti internals,10.5 Hotside,Works p2 flash w/boost control, Works 269 cams,Revolver valvesprings/retainers,ARP headstuds,Walbro 255,6000k HID upgrade,DoLuck CF lip,Omori multicolor electronic 60mm gauges,B&M short shifter,Pocketlogger,HKS type 1 TT,custom grounding kit,voltage stabilizer,Axas shift indicator light
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
