Aug 1, 2009, 09:19 AM
Personal Sales Rating: ( 0)
Drives: 03 evo8.
AEM Boost solenoid vs Standalone EBC?
I have a question. How does the AEM boost solenoid under the control of the EMS compare to using a standalone EBC such as Apexi's popular unit? Any benefit to using a standalone over letting AEM handle it?
Offline
Aug 7, 2009, 08:46 PM
Drives: 03 evo8.
bumpity bump.
Offline
Aug 10, 2009, 02:42 AM
Drives: EVO IX GSR
Everything can be done perfectly with AEM EMS, why to use something else ?
Only if you need to switch more than 2 boost levels without PC, you will need something else
Offline
Aug 10, 2009, 10:10 AM
Drives: 03 EVO/ 99GSX
Using the AEM to control the boost is the most precise way to do it. The problem is that most people do not understand how it works or have the patience to set it up correctly. It really isn't as complicated as some make it out to be however.
__________________
-Mike
DQ 1g: 9.39 at 157mph
DQ 2g: 10.46 at 143mph
DQ EVO 11.98 at 117mph
Offline
Aug 10, 2009, 10:37 AM
Drives: EVO VII
how would you compare the 2 unites together in terms of boost controle I bought mine 3 years ago hoping to stroke my car but that never happened. still have it nd will be installing it soon but my tuner told me for some odd reason that a manual boost controller is better than the electronic boost control that comes with Power FC D-jetro
Offline
Aug 12, 2009, 12:35 PM
Drives: EVO IX GSR
PowerFC has nearly no function to control boost. You can just set the duty of the solenoid and thats all.
But AEM EMS can do closed loop, PID, Speed dependant, duty + correction factor, and much more.
Just everything you can imagine and tune
Offline
Aug 12, 2009, 01:23 PM
Drives: 03' EVO 8 / Black
i went back to a manual controller. i had the aem running a gm solonoid. at lower boost levels 20-25psi it worked great. but after turning the boost up to 35psi it would overboost sometimes for no reason. 1 pull it would be fine and the next it would hit boost cut. so i gave up on it.
Offline
Aug 13, 2009, 07:31 AM
Drives: EVO IX GSR
Some solenoids can block if too much boost is reached, and they stay open or closed.
I had problem on APEXi solenoid, it stayed open when boost was over 1,1BAR, installing new piece has solved the problem.
Offline
Aug 13, 2009, 12:55 PM
aahhh. i just gave up... i like my old trusty turbo xs duel stage.
Offline
Sep 2, 2009, 08:45 AM
Silver Sponsor
Personal Sales Rating: ( 84)
Drives: 04Evo-white/05FSTi
Quote:
I had issues with the gm solenoid at anything over 29 psi. I have since switched to the AEM solenoid and it works fantastic.
__________________
Wayne ~ PRESIDENT@
Paradigm Performance Innovation
http://www.paradigmperformance.net
THE BEST DEALS ON 65mm T/B's & PORTING!
Kelford cams available!
FIC Injectors - SUPER DEALS!
Ported and Swain/silver coating!
JUN B.L exhaust!
Designing parts the right way!
PPI's Youtube http://www.youtube.com/user/ParadigmPerformance
11.10 / 124.89 / 1.60 60ft. FPGreen + E85 + PPI (Now rocking the Red & Kelfords)
Offline
Sep 10, 2009, 02:22 PM
Personal Sales Rating: ( 4)
Drives: 2006 EVO IX MR
GM boost controller has 85% duty cycle. The AEM one has 95% duty cycle.
So Yes AEM Boost controller is better. Setting up the boost controller is a PIA. But if set up right it works very well.
It holds a flat 30psi. Instead of it hitting the target 30 psi and then fall off in higher rpms with MBC.
I can't speak for the other E-controller becaue I've never used one.
__________________
Mike
AEM EMS Tuner
All Tuned by me.
-Evo IX GT30R Powered!! (10.9 @ 122) Full weight and Stock motor at 30psi
-98GSX 42R Powered!! (10.1 @ 146)
Offline
Oct 12, 2009, 06:46 PM
Personal Sales Rating: ( 2)
Drives: 04' GSR
Aem ftw
__________________
04' GSR intake, 3" TBE, BOV, 9 turbo, MBC, ECUflash&EVOscan (most fun to drive)
91' Eclipse GSX 4G64 MasterPower T64
00' Turbo stang 10.xx's (scariest to drive)
92' Suzuki Swift GTi NX direct port kit on slicks!!!! 12.70's
93' VR4 stock turbos exteme weight reduction 11.xx's
00' Camaro SS Heads/cam 12bolt on Boggarts 10.xx's
82' Firebird back half race car 400ci turbo God in the works!!! I can't wait!!
Offline
Nov 3, 2009, 11:31 AM
Personal Sales Rating: ( 12)
Drives: 03 evo ,02 ws6 trans am
im having the aem boost solenoid installed as we speak at turbotrix... anyone have any tips on how to tune it using my aem ems??? im sure turbotrix will set it up but what if i plan on changing boost levels and decide to start playing around with my map to c what works and what doesnt??? i eventually i want to be able to tune my own car instead of paying someone everytime i need something changed.
__________________
03 evo 8
turbo trix 50 trim turbo kit
1mm oversized valves
hks 272/272
aem ems
aem wideband
b&m short throw
soon to be kelford 280's with the new pte 5857..
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
