Jul 23, 2009, 05:40 PM
Personal Sales Rating: ( 0)
Drives: 03 evo 8 gsr
getting rid of AEM
because of PA state laws the car i bought had the AEM EMS and will not pass inspection.. do i just need a stock ecu or more?
Offline
Jul 23, 2009, 05:41 PM
Personal Sales Rating: ( 1)
Drives: 03 evo8
Just go back to the stock ecu it will provide anything you need
Online
Jul 23, 2009, 05:42 PM
Personal Sales Rating: ( 4)
Drives: 9 and 3
hopefully the car has all the sensors, like EGR
you will need the factory computer and a reflash if it's modded
__________________
95 integra gsr
Full-Race topmount w/ 30r @15psi
438 whp
278 wtq
11.1 @ 130mph
Offline
Jul 23, 2009, 08:12 PM
how do i know if it has all the sensors?
Offline
Jul 23, 2009, 08:15 PM
also wil i need anything and if i throw a stock ecu in the car will be fine and will start and all that?
Offline
Jul 23, 2009, 09:08 PM
like the wire harness or should my car already have that?
Offline
Jul 24, 2009, 08:16 AM
Personal Sales Rating: ( 23)
Drives: like a old lady
the AEM is plug and play for all facotry sensors, was it set in speed density or maf, there is a thread about putting the stock ECU back in for emissions testing and inspection that should be able to help you out. mostly you just want to either find a loop hole, most states have one, or once a year switch back to stock ecu for the check
__________________
Just another stock block STM tuned evo
Offline
Jul 24, 2009, 08:21 AM
Silver Sponsor
Personal Sales Rating: ( 5)
Drives: 2003 Evo
I have done it before if you want to bring it to a shop. We can look at it and see what you need. Do you have the mass air flow sensor?
Offline
Jul 24, 2009, 08:26 AM
Drives: 2003 evo8,91 CRX DX,91 CRXSi
if you need a ecu ill trade ya mine for your EMS...
__________________
Garrett GT30R,Tial Waste-gate,Forge BOV,HKS Cams,Vishnu Cam gears,680 Precision inj,Walbro 255 pump,Vishnu full 3" Signature exhaust with Test pipe,Vishnu SMART with wide-band,Xede ,AMS Water / Methanol injection,Poly Engine mount,ARP Head Studs/Rod Bolts,
Fadanza 4.3 clutch / Fadanza Flywheel,Kartboy Short shifter,Hotchicks rear adjustable sway bar,Mitsu Brake air guides,Omori Gauge Package- Oil Temp, Oil Pressure, Boost.
Offline
Jul 24, 2009, 10:58 AM
if i get a stock ecu off here and put it in my car will my car not start?
Offline
Jul 24, 2009, 11:04 AM
Personal Sales Rating: ( 15)
Drives: Evolution 8
not unless you flash out the immobilizer code
Offline
Jul 24, 2009, 12:26 PM
how do i do that?
Offline
Jul 24, 2009, 12:54 PM
Drives: 06 Evo MR
Quote:
Originally Posted by cec12789
how do i do that?
Search the ecuflash section, no need to make a new thread there though. You can find out everything you need by searching.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
