Jul 12, 2009, 06:00 PM
Personal Sales Rating: ( 37)
Drives: a ~500 AWHP 05 LY EVO 8 like a grandma
Here's how I pass inspection with my AEM EMS ~500 AWHP EVO 8
Hello all,
I have a 05 EVO which I have had AEM EMS on it since I got the car. Each year, I've gone thru the hassle and trouble of converting back to the stock ECU in order to pass OBD2 inspection, and each year I have learned new things, as well as becoming faster and more efficient at converting back and forth.
In this post I just wanted to share my notes with everyone so that it may help others make the switch confidently.
So what have I learned in the past 4 years?
To convert back from your AEM EMS to the stock ECU:
1) reinstall the stock MAP sensor. You can leave your 5-Bar AEM MAP sensor in place, just remove the AEM Map sensor connector so that you can reinstall the stock one. There are 3 wires that I unsolder and resolder here. the wires are for the stock MAP sensor socket/plug. The 3 wires involved are grey, black and yellow.
2) If you are running speed density as I am, you need to resolder 2 wires back onto the original position it came from on the MAF harness/plug. The two wires are black, and blue/green I think. Reinstall your OEM MAF along with a hi-flow filter.
3) I am running 1000CC precision injectors.... here I have to put the stock injectors back in. To make life easier, I broke the tabs that secure the fuel injector clips onto the injector in order to slide the clips in and out faster. Remember when installing injectors pull them out carefully or else you will damage the rubber o-rings which make the seal between the injector and the fuel rail. Additionally, when you swap in new injectors dont forget to coat the rubber o-ring with a coat of clean motor oil.
4) Plug in the stock ECU anytime. Additionally, I am running the SMC V2 Meth injection kit. There is a power wire from the Meth injection kits harness which splices into a red wire on the ECU harness....In the past, I disconnected this and resoldered the stock wiring together, but I learned from experience that doing this is not necessary. All you need to do is remove the AEM box and put your stock ECU in....
5) Camshafts? In the past I would remove my HKS 280's since it caused me to throw a P0172 code. This was due to the fact that I had the cams set at 0,0.
Today I've experimented, left the cams in place and left it at my +2 intake, 0 exhaust setting, started the car and threw no code. Here I am really pleased that I can save time by not having to touch my cams at all....
6) Walboro 255LPH fuel pump....In the past I would put the stock fuel pump in, but this also is not necessary...again more time saved by skipping this step.
7) I am running Buschur Racings EGR valve aluminum blockoff plate, in this step you have to reinstall the stock EGR valve and reconnect the vacuum lines.
All in all my car is ready to go for inspection, minus the fact that I need to go around the block a few times to complete a drive cycle or two to get all the monitors that I need to be in the "ready" state. In the state I live in they allow 2005+ OBD2 cars to have one monitor in the "not ready" state in order to pass.
Comments and questions are welcome. Later on I might put up some pictures to illustrate the steps I've gone thru. All in all, with a few breaks, lunch etc in between, and with no set-backs, I can convert my EVO to be emissions testing ready in a matter of 3-4 hours.
Offline
Jul 14, 2009, 06:00 AM
Personal Sales Rating: ( 3)
2005 Mitsubishi Lancer Evolution
Drives: 2005 EVO8, 2004 CTS-V
sounds like a normal re-conversion. Good info though. Do you have lots of mods and what about a retune on the stocker ecu?
Mine is set up just as easy to reconvert...but I dont know what will happen with the JUN 264's. They idle like so..so on the aem. But that prob is due to the summer heat. I havent retuned for that yet...I know DB runs his project white with the stock ecu and jun 272...or that was what the thread said months ago.
On another note I believe DB also runs speed density on that car with the stock ecu.
__________________
In an effort to make this site easier to navigate for everyone, please refrain from posting off topic comments or posting threads in the wrong forums.
Forum rules:
http://forums.evolutionm.net/evom-newbie-faqs-forum/announcements.html
AMS 2.0L // Cosworth Head // JUN 264 // AEM EMS //
Stock Turbo // Built/Tuned by me
Best time 12.84 @ 105.3 60ft 1.737
Offline
Jul 14, 2009, 07:16 AM
Personal Sales Rating: ( 0)
2003 Mitsubishi Lancer Evolution
Drives: A Slow Evo VIII
If you're having to swap it that often, I would consider not cutting off the stock connectors for your map and maf. when I bought my car, it already had the AEM installed. The stock maf connector was still attached, the IAT was simply spliced into the stock wires, so if I wanted to run a maf, all I would have to do is disconnect the IAC, and plug in the MAF, as either one being unplugged will leave it in an "open" state and will be inconsequential to the readings. same goes with your AEM vs stock MAP sensor.
by doing this, it takes the soldering completely out of the equation, and it would bring it one step closer to being a simple plug n play swap.
Offline
Jul 14, 2009, 07:20 AM
Drives: 2003 BBY Evo VIII
It should be fine running the JUN 264's on a stock ecu. I was running HKS 264's on my stock ecu and was fine.
__________________
Boost is the best drug in the world and I am never turning it down!!!
HKS 264 Cams/Apexi 3" Downpipe/HKS Hi-Power Exhaust/HKS Intake/Greddy FMIC/Tein S-Tech Springs
Offline
Jul 14, 2009, 06:39 PM
yeah, it is the normal reconversion, but I have managed to elimate a lot of time consuming steps thru trial and error in the past few years. What I am going to do now to make life even easier is have my stock evo 8 ECU flashed to handle my 1000cc injectors, so that i can totally eliminate that whole process of swapping injectors.
Yes i do have a lot of mods....HKS 280's, Meth injection, AEM EMS, AMS 50 trim turbo kit, full 3" exhaust, ARP Headstuds, Buschur Race FMIC...pretty much all the supporting mods to max out my 50 trims output.
Offline
Jul 14, 2009, 06:41 PM
I know what you are saying here, but for me its already too late. When my tuner installed my AEM he did what he did, so now, I'll have to spend a few minutes here and there to resolder 5 wires when inspection time comes. Its not bad, and I dont mind doing the soldering on a boring weekend afternoon.
Offline
Jul 14, 2009, 06:49 PM
Personal Sales Rating: ( 52)
Drives: 03 Evolution 8
blue evo 8
why dont you just ditch the AEM all together with how far the ecuflash forum as come AEM is not needed for 500/550hp. i pass nj state inspection just fine with big cams, 1200cc injectors, no cat or rear o2 sensor, no evap or egr stuff and other stuff. no cel light. if your going through all this swapping trouble with aem to stock ecu you really need to read up on the new age stock ecu stuff. and you can run SD now too. so its even better. just a thought.
__________________
JESTR TUNING - FULL-RACE - SPARK TECH - NISEI ENGINEERING - DRIVEN INNOVATIONS - DOG BOX RACING
NEW JERSEY EVO OWNERS *THREAD*
My F/S thread STOCK & AFTERMARKET *CLICK HERE*
WTBWTBWTBWTB : Evo RS door handles
Offline
Jul 16, 2009, 06:02 PM
Quote:
No offense man...but Jun and HKS are very different.
Although after reading DB's thread on his white car. He makes the stock ecu run Jun 272's and speed density. Unless I misunderstood something. I would switch back to the stock ecu and may still do that. I just wish these good tuners were on the west coast.
__________________
Forum rules:
http://forums.evolutionm.net/announcement.php?f=61
Offline
Jul 16, 2009, 06:10 PM
Personal Sales Rating: ( 24)
Drives: El ocho
Another way is having on of your boys plug their car with the stock ECU. I'm not saying I did it that way
__________________
"Failure Is Not An Option"
Online
Jul 17, 2009, 03:13 AM
Personal Sales Rating: ( 14)
Drives: 03 EVO8, 05 R6
lol sounds like a big pain in the ass.
__________________
03 Apex silver EVO VIII 12.25@113 1.83 60' @ 4800 ft
stock 9 turbo, stock ecu, stock block e-85
www.rcm-awd.com Colorado car club
Online
Jul 21, 2009, 03:29 PM
Drives: LANCER
Sounds good man beats switching whole thing back to stock
Offline
Jul 22, 2009, 07:25 AM
Personal Sales Rating: ( 23)
Drives: like a old lady
and thats why i like the loophole i found
__________________
Just another stock block STM tuned evo
Offline
Jul 30, 2009, 06:42 PM
Drives: '06 GG Evo IX
hope to run AEM ems but am NOT looking forward to this process.
nice thread though, gives a good explanation. well done
Offline
Jul 30, 2009, 09:21 PM
but you get used to it. I have it down pat now, and could convert back to "pass" in a matter of a couple hours... no biggie...
Offline
Aug 13, 2009, 03:07 PM
Drives: Subaru WRX Wagon/Red EVO 9
Damn you need to come down to the bronx. Seems like a big thing to go thru every year.
Offline
Tags
aem, application, car, cats, emissions, ems, evo, iac, inspecion, inspection, make, nj, pass, state, turbo  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
