Jul 12, 2009, 03:45 AM
Personal Sales Rating: ( 2)
Drives: GG EVO IX MR
Any way to troubleshoot AEM without sending it out?
Hey guys,
About a month ago my car stopped working, it cranks over but won't start...and I haven't been able to find what the problem is. My friend is a mechanic and has been looking at it for me when he has a little spare time, he's looked at it now about 2-3 times for around 20mins-1hr each time, and has tested multiple things.
He's thinking that my AEM could be bad. I tried hooking it up to the laptop and it's not being detected anymore...my question is, is there any way I can try to troubleshoot the AEM system or do any tests to it before I have to send it out to AEM for them to take a look at it?
I already sent my system out earlier this year and it came back with no problems, I don't want to send it out again and be without a running car for 2 weeks unless I'm close to 100% sure somethings wrong with the system itself.
Is there anything I can do to find out if the problem is definitely the AEM?
Thanks in advance for your help!
__________________
GG Evo IX MR AMS Built
...Sick at AMS =[
Offline
Jul 17, 2009, 03:30 AM
Personal Sales Rating: ( 14)
2003 Mitsubishi Lancer Evolution
Drives: 03 EVO8, 05 R6
Does it not even detect or do you get any errors?
__________________
03 Apex silver EVO VIII 12.25@113 1.83 60' @ 4800 ft
stock 9 turbo, stock ecu, stock block e-85
www.rcm-awd.com Colorado car club
Offline
Jul 19, 2009, 05:13 AM
Personal Sales Rating: ( 0)
Drives: 1G AWD DSM
I have a same problem 2 months ago on one of my costumer car (2JZ engine) after a stupid mechanic played with his car ... He came to me and I plugged my lab top and tried to connect to the EMS but no used, so I called AEM Support and asked me to remove the EMS from the car and connect to 12v power and ground and try to connect it to the lap tob. I did that and it does connect to the lab top  . Then after that I asked the car owner to replace the crank and cam sensors ... then problem was solved  .
Offline
Jul 19, 2009, 11:48 AM
Personal Sales Rating: ( 3)
Drives: 2006 TB Evo 9 SE
i would check to see if your crank angle sensor is bad when you crank the car are the coils sparking i had this same problem last week and it was my crank angle sensor 100 fix
__________________
2.3L
JAM 3mm big bore lifters
Wiseco pistons
Eagle H beam rods
BR ported intake manifold
BR ported 65mm tb
BR Race fmic
Supertech valvetrain
Cosworth 272 cams
1000cc injectors
Garrett gt4088r turbo
Dual 38mm tial wastegates
Custom twin scroll manifold
Blitz Dual SBC
Aem meth kit
Aem 1320
RSR Exhaust
Walbro 255 pump
537hp 404tq @ 26psi
Offline
Jul 19, 2009, 12:39 PM
Drives: 99' Galant ES
If you can get it to connect just to view the sensor signals and look for the "Stat Sync" column, when you crank the car the stat synch should go from "OFF" to "ON" if it doesnt the EMS isnt getting a signal from the cam and/or crank sensor.
__________________
Its all fun and games til the cops show up!
Offline
Jul 19, 2009, 05:37 PM
Quote:
i used to be able to connect fine, now when I try to connect I get this...
Offline
Parity Error
Framing Error
Break Error
__________________
...Sick at AMS =[
Offline
Jul 20, 2009, 08:46 AM
Drives: EVO IX GSR
If your unit is offline:
1) Check voltage on ecu
2) Check all fuses, realays etc...
3) Check serial cable
4) Try another PC
if everything ok, just the ecu does not communicate or work with engine.... put it out
Offline
Jul 21, 2009, 03:25 PM
Drives: LANCER
this is a helpful thread helped me out a lot
Offline
Jul 21, 2009, 10:22 PM
I also forgot to mention...you know when you turn the key and all the lights on the dash go on for a couple seconds, including the service engine light? All my lights turn on except for the service engine light, it used to before, any ideas what could be causing that?
__________________
...Sick at AMS =[
Offline
Jul 25, 2009, 02:42 AM
Quote:
Offline
Parity Error
Framing Error
Break Error
If your getting this is probably a bad eprom.
I sent mine to AEM to get fixed. It was $50 which was a sweet deal cause its $50 to get it looked at it and they gave me a new eprom and everything for free.
They will take care of you.
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
