Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > AEM EMS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jun 25, 2009, 05:19 AM   #1
EvoM Moderator
Personal Sales Rating: (3)
2005 Mitsubishi Lancer Evolution
althemean's Avatar
Drives: 2005 EVO8, 2004 CTS-V
External switch for internal logging
I searched for hours last night and couldnt find what I needed.
From what I understand in the EMS software, I must configure on output (such as switch 7) to activate the log feature and to assign it all the params.
My question is,
How do I physically wire it into the ecu? What pin/input is switch 7. I have a copy of the ecu pin layout. Just not which one needs to be tapped.
I want to log on demand and not use the set params in the internal log for activation.
Thanks for any help.
__________________
In an effort to make this site easier to navigate for everyone, please refrain from posting off topic comments or posting threads in the wrong forums.
Forum rules:
http://forums.evolutionm.net/evom-newbie-faqs-forum/announcements.html
AMS 2.0L // Cosworth Head // JUN 264 // AEM EMS //
Stock Turbo // Built/Tuned by me
Best time 12.84 @ 105.3 60ft 1.737
Offline
Old Jun 25, 2009, 05:03 PM   #2
Personal Sales Rating: (2)
Drives: Evo VIII
Hi
Switch # 7 doesnt seem to be available on Evo computers but you could use Switch # 5 which is for 1313 pin37
I havent done it but it shouldnt be so hard
regards
Gudmundur
Offline
Old Jun 25, 2009, 07:59 PM   #3
EvoM Moderator
althemean's Avatar
thanks for the response. Ive been reading through the manuals and it is pretty vague.
__________________
Forum rules:
http://forums.evolutionm.net/announcement.php?f=61
Offline
Old Jun 26, 2009, 03:19 AM   #4
Drives: Evo VIII
That is true.
Only input I have used is the clutch switch input and for that I used Switch #4.
But in theory using switch #5 should be just the same and then configure it under logging setup.
I would think that you should chech "log switch2
regards
Gudmundur
Offline
Old Jun 27, 2009, 08:48 AM   #5
EvoM Moderator
althemean's Avatar
so how does the wiring go.
Ecu pin 37---->switch-------GND?
__________________
Forum rules:
Offline
Old Jun 30, 2009, 09:07 PM   #6
Personal Sales Rating: (4)
kjewer1's Avatar
Drives: 2005 EVO RS
I don't have the software in front of me, but you would typically pick an available switch, wire it to the switch and then ground as you said, and then set the switch parameter to "Switch [insert number you wired to] Ground = on" or whatever suits your implementation.
__________________
Kevin Jewer
92 Talon RWD, compound turbos - 8.98 @ 156
Offline
Old Jul 1, 2009, 02:05 PM   #7
awdboosted's Avatar
Drives: 2006 EVO IX MR
Send a message via AIM to awdboosted
You can use any pin as long as it's on of the switches but to activate it you will need a gnd to trigger it. Not a power source.
__________________
Mike
AEM EMS Tuner
All Tuned by me.
-Evo IX GT30R Powered!! (10.9 @ 122) Full weight and Stock motor at 30psi
-98GSX 42R Powered!! (10.1 @ 146)
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
