Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > AEM EMS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old May 28, 2009, 02:51 PM   #1
Personal Sales Rating: (54)
El Boricua's Avatar
Drives: 3000GT VR4 and EVO VIII
Send a message via AIM to El Boricua
Question Lean at cold, rich at hot..!!!??
Hey,
Can someone please tell me why my car is lean when it start in the morning, and then until I drove it around it gets richer and richer...?
Did I have something set the wrong way..? I don't know..!! maybe the idle invert or something..?
Please help..!!
Thanks,
Offline
Old May 30, 2009, 03:17 PM   #2
Personal Sales Rating: (0)
- Fuel
--> <<Advanced Fuel>>
----> Fuel Trims
------> Air Temp Fuel Corr Table
You whole map is more than likely set at 0. So what you are going to need to do is modify that table, and add fuel when it is cold, and remove fuel when it gets hot.
So as you are driving around in cold weather try to adjust that table and get your AFR's to match where you were tuned at.
Here is a SAMPLE of what I am using, which for me is still off on pump gas and race gas, I have not fully tweaked it.
34.375 28.90625 23.828125 19.140625 14.453125 10.546875 6.640625 3.125 0 -3.125 -5.859375 -8.59375 -11.328125 -13.671875 -16.015625 -18.359375 -20.3125
-40 Degrees --------------------------[104 degrees]---------------------------> 248 degrees
Use at your own risk.
I took this from the Boost Comp Excel sheet on aempower forums.
Offline
Old May 30, 2009, 03:44 PM   #3
Personal Sales Rating: (5)
2005 Mitsubishi Lancer Evolution
EVO8_PR's Avatar
Drives: 2005 Electric Blue EVO 8, 2005 Mitsubishi Outlander
Quote:
Originally Posted by TheBoz View Post
- Fuel
----> Fuel Trims
while this is true in many places, here in Puerto Rico your starting air temps could be in the high 80's when initially starting your car, and rise to about 95-100 when driving. What you should check is what cell of the fuel map is highlighted when cold(coolant temp) and compare it's value with the one highlighted when @ normal operating tempertaure.
BTW, let me know when you get your fuel assembly.
__________________
PT6262 equipped Electric Blue EvoVIII
OEM Yokohama's 10.84@135
M/T Motorcycle Slicks 10.24@136
VR4 Tuning Videos
Quote:
Originally Posted by EVOgasmIX View Post
Maybe the 4G63 was over built by accident and not on purpose. Seriously, why would anyone design a 2.0 L block that could handle 900+ hp 25 years ago?
Offline
Old May 31, 2009, 03:10 PM   #4
El Boricua's Avatar
Thanks for the tip....!!!
Quote:
YES I will...!!
Thanks,
Offline
Old May 31, 2009, 07:14 PM   #5
El Boricua's Avatar
WOW... great... did that, plus did little adjustments at the Warm Up Enrich table, the Start Decay, and the Start Extra table, and after two days of not using the car, it started the first try... and it went very smooth while warming up..!!
Once again thanks..!!
Offline
Tags
cold, ems, hot, lean, rich
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
