May 20, 2009, 02:56 PM
Personal Sales Rating: ( 6)
Drives: 03 EVO VIII some mods, 91 AWD Talon built motor sc61 turbo etc, 2006 GSXR1000 low long and modified
AEM timing #s Vs ECU Flash timing #s?
How do these compare?? As in 12 degrees advance in ECU flash = what in AEM??
Offline
May 20, 2009, 07:44 PM
Personal Sales Rating: ( 10)
Drives: On the mustang dyno
They should be the same.
__________________
---Will have new numbers soon----
08 Evo X FPRED
03 Evo VIII FPgreen (street), GT42r(Drag), soon to try 6262 to both street and drag.
Times
12.0 2005
11.4 2008
10.8 2009
Offline
May 20, 2009, 07:48 PM
Personal Sales Rating: ( 7)
Drives: 2003 Evo 8
Aem timing is the exact value ecu is estimated.
So aem is exactly what u set it to and will fire at whatever value you put in.
__________________
03 TB EVO MODS:
Megan DP, Ultimate Racing 3" Hi-flow cat, Tsudo Cat-Back, MBC, HKS 264/272 cams, Walbro 255
Tuned by KevinD
Offline
May 21, 2009, 03:01 AM
This is not what I have been told by a few other shops..... But I have yet have my real question answered by them as well.....
Offline
May 22, 2009, 08:27 AM
Personal Sales Rating: ( 5)
2005 Mitsubishi Lancer Evolution
Drives: 2005 Electric Blue EVO 8, 2005 Mitsubishi Outlander
Quote:
What have you been told?
__________________
PT6262 equipped Electric Blue EvoVIII
OEM Yokohama's 10.84@135
M/T Motorcycle Slicks 10.24@136
VR4 Tuning Videos
Quote:
Originally Posted by EVOgasmIX
Maybe the 4G63 was over built by accident and not on purpose. Seriously, why would anyone design a 2.0 L block that could handle 900+ hp 25 years ago?
Offline
May 22, 2009, 03:23 PM
Personal Sales Rating: ( 4)
Drives: 2006 EVO IX MR
I think the timing can vary between stock ECU vs. AEM EMS. I would start with much lower number timing numbers, start to add timing until you see knock, and then back off. That’s what I would do. But I don't think the value will be the same.
__________________
Mike
AEM EMS Tuner
All Tuned by me.
-Evo IX GT30R Powered!! (10.9 @ 122) Full weight and Stock motor at 30psi
-98GSX 42R Powered!! (10.1 @ 146)
Offline
May 22, 2009, 03:36 PM
Silver Sponsor
Personal Sales Rating: ( 17)
Drives: 06 Rally Red MR
The value doesnt vary that much from ECUflash to AEM. Even if it does a little its only a few tenths. We have put lights on both and verified the timing via AEM and EvoScan. The main thing is having to think in terms other than load (ECUflash) and in either KPa or Psi with the AEM. With the advent of SD on the stock ECU it makes it even easier to compare what the timing numbers need to be versus an actual pressure value.
For instance, Lucas' car on the stock computer and the AEM are very very similar in the timing map at a given boost value. Our Head fabricator TJ's 61mm stock ECU/speed density map is very close to what I see in AEM cars.
Offline
May 22, 2009, 03:38 PM
Silver Sponsor
We have also compared DSMlink and AEM and you really can compare numbers with that and see that they dont vary much.
Offline
May 23, 2009, 10:44 AM
How much lower on the timing in AEM over my ECU Flash timing map do u think is safe to run on the AEM?? You think i can go 1 degrees less everywhere and be safe?? Thanks for some clarity BTW!
Offline
Tags
20, 91, aem, ecu, evo, fic, flashing, map, mustangs, talon, timing, tuning, turbo  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
