May 8, 2009, 07:27 AM
Personal Sales Rating: ( 54)
Drives: 3000GT VR4 and EVO VIII
AEM EMS and turbo timer
Hey, since we installed the AEM EMS, the turbo timer is acting kind of funny. Every time after I start the car, the turbo timer resets and starts the the countdown.
BTW, it is a Greddy Turbo Timer ...
Another thing is that after a couple of minutes of the engine been on, I hear a click and then the turbo timer resets again..
Have someone else experience this behavior...?
Does it has to do with the wiring..? or the signals from the EMS..?
Any comments will be appreciated..
Thanks,
Offline
May 8, 2009, 03:09 PM
Personal Sales Rating: ( 4)
Drives: 2006 EVO IX MR
I would personal ditch the Turbo timer.. They are a waste of gas and do nothing for the car. You can also set up the AEM to act as a turbo timer
__________________
Mike
AEM EMS Tuner
All Tuned by me.
-Evo IX GT30R Powered!! (10.9 @ 122) Full weight and Stock motor at 30psi
-98GSX 42R Powered!! (10.1 @ 146)
Offline
May 9, 2009, 04:04 PM
Quote:
How you do that..??
Offline
May 9, 2009, 07:25 PM
Personal Sales Rating: ( 7)
Drives: 05 evo MR
i would like to know that to
Offline
May 11, 2009, 02:47 PM
When I get home I'll look at the software and give you the menu..
__________________
Mike
AEM EMS Tuner
All Tuned by me.
Offline
May 11, 2009, 02:51 PM
That would be great...
Thanks,
Offline
May 11, 2009, 08:44 PM
I was told the wrong thing a few years back Like 3 years ago... Never tried it until now. Its under: setup/advance set up/ main relay control/ option - main relay/ Then main relay stop eng.
Sorry.. It doesn't work.
__________________
Mike
AEM EMS Tuner
All Tuned by me.
Offline
May 12, 2009, 06:06 AM
oohh... thanks...!!
Well still looking to see what's wrong with the interaction between the turbo timer and the AEM EMS...!!
Offline
May 12, 2009, 11:24 AM
Quote:
Originally Posted by El Boricua
oohh... thanks...!!
I think that the Turbo Timer work with the key. I don't think the EMS has anything to do with it. Try plug up the stock ecu and seeing if it does the same thing.
__________________
Mike
AEM EMS Tuner
All Tuned by me.
Offline
May 12, 2009, 04:17 PM
Personal Sales Rating: ( 14)
2003 Mitsubishi Lancer Evolution
Drives: 03 EVO8, 05 R6
Sounds like its not wired right or something in your ignition system is messed up.
But its definitely not an AEM caused issue.
__________________
03 Apex silver EVO VIII 12.25@113 1.83 60' @ 4800 ft
stock 9 turbo, stock ecu, stock block e-85
www.rcm-awd.com Colorado car club
Offline
May 12, 2009, 05:10 PM
Everything started when we installed the EMS.. it is not happening with the stock ECU...!!
Offline
May 22, 2009, 03:35 PM
Try and extent the time the main relay stays on. See if that helps.
__________________
Mike
AEM EMS Tuner
All Tuned by me.
Offline
May 22, 2009, 05:26 PM
Then again... how you do that..?
Thanks,
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
