Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > AEM EMS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Apr 21, 2009, 05:15 PM   #1
Personal Sales Rating: (0)
Drives: JDM evo VIII GT35
help with UEGO
hi
I would like to know how can I read AFR on a aem wideband gauge without using o2sensor but via AEM ems 1313U
at this stage I use AEM ems uego that include o2sensor
and AEM wideband gauge using o2sensor too but
both do not read same AFR
cheers
Offline
Old May 3, 2009, 05:07 PM   #2
Personal Sales Rating: (9)
blackevolution8's Avatar
Drives: 03 Evolution 8
There should be no difference between the two. The sensor reads oxygen content in the exhaust and it should not matter which sensor or setup youre using. As long as the calibration is setup right and the sensors are functioning properly it should be the same reading or very close to eachother.
__________________
- Brad Russell
Stock Turbo
Built 2.0 block
AEM EMS w/ wideband
1000cc injectors
HKS 280 cams
3" turboback
294awhp 301awtq @ 26psi tuned by myself
Speed Industrys Mustang Dyno
ASE Master Certified
Offline
Old May 4, 2009, 05:46 PM   #3
Personal Sales Rating: (4)
YellowEvilEvo's Avatar
Drives: 03' Evo
I have the same quetion. I tried tapping the white wire from the gauge controller to pin 76, but i beleive pin 76 on the 1313u is not active because of the AEM internal UEGO unit. I am sure there has to be a way t send the signal from the 1313u to the guage controller. can someone who has any experience with this please help us? thanks!
__________________
Built by the DTM Crew
Tuned by Nick@DTM
DTM Built Head
DTM 2.3L Block
DTM Twin Scroll Big Turbo
499awhp/422awt on pump gas@25lbs
Offline
Old May 4, 2009, 06:02 PM   #4
Personal Sales Rating: (13)
holiday63's Avatar
Drives: 04 evo viii
i bought my box (1313u) used, and it didnt include the front O2 sensor that is supposed to come with it.
I use an aem wideband gauge, and I did however use the bosch O2 sensor that comes with it and screwed it in my test pipe. I spliced the white wire to pin 75 or 76 (cant remember). and only look at rear O2 afrs. they are dead on when logging and on my gauge
go to aem's site and look up the wiring chart for the 1313u, their are two pins for 02: one for O2 #1 and one for O2 #2. you're gonna want O2#2 if you're not using the ems sensor but the wideband sensor.
i hope this info is somewhat helpful, id be willing to clarify if need be. just pm me or ill check this post later
Offline
Old May 4, 2009, 07:08 PM   #5
Drives: 03' Evo
That's exactly what I was going to do. Just didn't know if anyone had done it yet. Thanks!!!
__________________
Tuned by Nick@DTM
DTM Built Head
DTM 2.3L Block
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
