Jan 10, 2008, 02:01 PM
Personal Sales Rating: ( 12)
Drives: 05 evomr
acd lights with AEM
I had my new clutch instal and my acd was bled. Now when i start the vehicle within 1min all three acd lights turn on. being the idiot i am i took the car to the dealership, but they could not do anything due to the AEM. their laptop was not communicating with the AEM. i was wondering if there is a way to fix the light with the AEM or some people has had the similar problem.
__________________
invidia dp, invidia tp, invidia cb, TurboXS I/C, Turbotrix i/c pipes and intake, 2.3 stroker kit by (Jack's Transmission), Exedy twin HD, hks 272's, arp head studs, walboro 255 fuel pump, ur cam gears, amber defi bf gauges with controll box, apexi tt, apexi grounding kit, AEM EMS and boost solenoid, AEM wideband, ETS PT 6162 Turbo kit, Aoromotive FPR and Fuel rail, 1600cc inj, full blown twin pump setup
* 348 awhp
* 352 awtq
Offline
Jan 12, 2008, 05:21 AM
Personal Sales Rating: ( 9)
Drives: 05 graphite EVO MR
sounds like you still have air in the line for the acd. if it was fine before and after the clutch swap you had the problem, i would start there
Offline
Jan 12, 2008, 09:09 AM
Personal Sales Rating: ( 0)
Drives: EVO IX GSR
hmmmm that is not good... because the dealerschip uses MUT for power-up the pump to bleed all the air from ACD,AYC system. I dont know how to do it without MUT. AEM EMS will not comunicate with the MUT.
Good question, ill ask my friend, Mitsu Dealer.
Offline
Jan 12, 2008, 09:53 PM
Drives: 03 evo
turn the key on, and hold the gas pedal all the way down(5-10sec). It will prime the acd. Bleed it. Turn key off, repeat.
__________________
03 Rally Red
600whp sold and gone :(
03 Apex Silver
370ish whp sold and gone :(
Offline
Jan 13, 2008, 09:44 PM
Drives: 05 evomr
thanks for all the help. i will try it tomorrow.
__________________
* 348 awhp
* 352 awtq
Offline
Jan 13, 2008, 09:47 PM
Personal Sales Rating: ( 133)
Drives: MR
Are these lights only on every once in a while when you first start up the car? And if so, do they just all three blink?
Offline
Jan 13, 2008, 10:20 PM
Personal Sales Rating: ( 5)
Drives: an evo duh?
I did read the manual once, if all three are blinking, I believe you have a real problem. All 3 on, means get it checked out.
Offline
Jan 13, 2008, 10:24 PM
Drives: MR
Quote:
I have had all three on at once.. blinking.. and all it was .. was my tactrix cable was plugged in.. took it out.. problem solved..
Offline
Jan 14, 2008, 08:41 PM
Drives: 05 evomr
all 3 lights stays on. once i start the car only one light is on. once i start driving than all three lights turns on. when i take the key out and the turbo timer is counting down onlyl one light is on. mitsu laptop wont communicate with the aem ems. thanks...
__________________
* 348 awhp
* 352 awtq
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
