Oct 8, 2007, 01:23 PM
Personal Sales Rating: ( 0)
Drives: 2003 EVO 8, 2002 CELICA GTS, 2006 YAMAHA R6
thanks worked fantastic...
__________________
P.S.A ********* To all Builders and Tuners***********
Insanity: doing the same thing over and over again and expecting different results.
Albert Einstein
Offline
Nov 23, 2007, 12:30 PM
Personal Sales Rating: ( 4)
Drives: 2006 EVO IX MR
Quote:
Originally Posted by 32 psi daily
cold start fix:
+ more fuel at warm up enrichment
+ Optima red top battery
that seem to work fairely well.
Too much enrichment will hurt idle. It will not allow the car to idle right. You have to play with crank injector time tables and start extra decay.
__________________
Mike
AEM EMS Tuner
All Tuned by me.
-Evo IX GT30R Powered!! (10.9 @ 122) Full weight and Stock motor at 30psi
-98GSX 42R Powered!! (10.1 @ 146)
Offline
Dec 30, 2007, 12:35 PM
Personal Sales Rating: ( 5)
Drives: SLVR EVO IX
is there any fix for evo 9's yet?
Offline
Jan 16, 2008, 04:23 PM
Drives: 98 GSX, 91 colt 4g63swapped, 90 talon fwd, 95 talon,98 Cobra SVT
Another solution is out to fix the root of the slow sync problem. Ever heard an S2000 start with an EMS? It fires almost instantly. Reason being, it has a 12 crank tooth trigger and a much more aem friendly sync strategy.
Search around, the parts are available for a 12tooth trigger on the evo. Going from a 4tooth crank trigger to a 12 tooth trigger will improve the sync time(start time), reduce spark scatter, and improve overall resolution.
__________________
1016whp 2.0l 95 AWD talon
91 Dodge Colt
98 Eclipse GSX AWD
98 Cobra SVT
Offline
May 28, 2008, 07:31 PM
BRooks.. Have you ever played with opening the Idle air control motor to help starting?
__________________
Mike
AEM EMS Tuner
All Tuned by me.
Offline
Jun 3, 2008, 06:00 PM
Yes, I use the rpm vs start tables all the time. Opening the idle valve(similar to pushing the throttle slightly) helps start up time. Using the Crank initial pulse table will also solve a lot of the cold start issues i see people post about.
What I was referring to is the amount of time the AEM ECU takes to sync the 8tooth count(2 physical teeth counting each edge, twice per cycle) and turning ON the parameter "Stat Sync". No amount of ECU tuning will make this a faster process. What you'll notice if you monitor the Stat Sync Parameter during cranking is the ecu takes about 3 seconds of cranking time before the Stat Sync will turn to ON, giving the slow AEM EVO start. (The lower the battery voltage the more noticable this is) By increasing the tooth count to 24 (12tooth wheel) which the GEMS/AEM15 ecus are designed around, this delay isn't there.
__________________
91 Dodge Colt
98 Eclipse GSX AWD
98 Cobra SVT
Offline
Jul 16, 2008, 12:23 AM
Personal Sales Rating: ( 11)
Drives: 1955 VDub Turbo <best 9.97@132, 1956 VDub <0-60MPH eventually, 03 EVO OCHO
Do you know where to find tis wheels. I know mega squirt and electromotive has them. does anyone make a kit and can you use the same oem crank sensor? thanks
Offline
Jul 17, 2008, 12:26 PM
Something like this...
Try www.triggerdisc.com
__________________
91 Dodge Colt
98 Eclipse GSX AWD
98 Cobra SVT
Offline
Jul 17, 2008, 07:02 PM
Offline
Jul 21, 2008, 02:26 PM
Personal Sales Rating: ( 9)
Drives: 2008 Volvo XC90 2003 EVO 8 2008 A4 Quattro 2.0T
BBrooks what changes are needed to the AEM after installing this gear?
Thanks
Duncan
__________________
ROBISPEC///
Offline
Nov 23, 2008, 08:07 PM
Personal Sales Rating: ( 1)
Quote:
Originally Posted by crewdawg130
How does that react with the evo 9 and their mivec system?
Offline
Dec 25, 2008, 05:22 PM
Quote:
same thing no diferene between 8 & 9
Offline
Dec 31, 2008, 05:08 PM
Drives: 2003 TB evo 8
I've got mine firing up almost like stock on E85 in cold weather without the trigger plate mentioned above. Takes allot of time and adjusting over a course of a few weeks with different temps and what not, but I think I got it down pretty good now.
Video of my car in 30 degree garage on E85 cold start.
http://www.youtube.com/watch?v=qe3vnMSTEMI
and a thread I posted with some tables already adjusted for people to try out. Should work fairly well for anyone with an AEM. Might have to tweak a bit on it but it's well worth the effort!
Cold start and E85 calibration!
__________________
Jake Montgomery
JMtuning
1992 eagle talon **retired**
gt4202 @ 44lbs
8.66 @165mph
Video of 8.66 pass
http://www.youtube.com/watch?v=1CGEpRTA104
2003 TB evo 8 10.95 @130mph on stock block/head/ JMfabrications tial v-band 3082r turbo kit./ E85/ ect.
Offline
Apr 24, 2009, 06:49 AM
Drives: EVO7, EVO9
I used to use triggerdisk in all EVOs 7 and 8. When I tried in EVO9 I got big problems with Mivec. It does not work. There is no synchro between intake cam and crank...
The start of engine is perfect, but if you want to use it in EVO9, you have to know what way you will fix the trouble with mivec...((((
Offline
May 14, 2009, 06:57 PM
Drives: '91 Eclipse GSX
__________________
-Victor
triggerdisc.com
'91 GS X - AEM car that "starts like a bandit!"
Offline
Tags
12, aem, cold, crank, ems, evo, initial, install, map, start, starting, sync, teeth, tooth, trigger, wont  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
