Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Access Port
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 30, 2009, 08:24 PM   #1
Personal Sales Rating: (6)
Drives: EVO VIII MR
How do these numbers look?
I recently installed a Cobb Acessport with the stage 2 map. Other mods are in my signature.
With the AP I can monitor engine knock sum, timing, etc. But, what numbers should I be looking for with knock sum and timing? I want to make sure I'm running good, but I have heard different range of numbers. And what would happen if the knock sum is greater than the normal values?
Also, if someone could give me a better definition of knock and timing I would appreciate it. I'm somewhat new to tuning.
Thanks in advance!!
__________________
GG VIII MR
Apexi TBE // O2 Housing // IX BPV // Hallman Pro MBC // Cobb AP Stage 2 @ 22lbs // Injen UICP & Intake // ETS LICP
DBA // Project Mu
Offline
Old Aug 30, 2009, 09:03 PM   #2
Personal Sales Rating: (7)
2003 Mitsubishi Lancer Evolution
KenMasters's Avatar
Drives: 03 VIII, 04 Grand Cherokee, 72 Cheyenne
Knock is detonation, Timing is when energy is sent to the spark aka ignition. Detonation is premature ignition or ignition from source other than the plug.
This is how I understand it. I am no engineer. It is worth a wiki.
__________________
e85 FPgreen S1 405/396 www.macautosport.com
Offline
Old Aug 30, 2009, 09:13 PM   #3
Personal Sales Rating: (0)
Drives: Lancer Evolution VIII
For Evo 8s <= 3 counts of knock is ok, ideally you want as much timing as possible without knock, but that's theory. In practice, with your logs, determine where the knock is happenening (what rpm range and timing and AFR values etc) and either decrease timing, encrease fuel mix (lower AFR) or both.
Knock can be attributed to many factors (ones listed above) and grade of fuel ... you can try keeping your current timing and AFR values and run higher octane fuel to reduce knock.
Offline
Old Aug 30, 2009, 09:31 PM   #4
Drives: EVO VIII MR
ok thanks. I was told <=3 but also heard 7-8 is ok. I have hit up to 10 sometimes, but i will have to take notice of where those spikes occur.
__________________
GG VIII MR
DBA // Project Mu
Offline
Old Sep 8, 2009, 04:21 PM   #5
Personal Sales Rating: (1)
801bmx's Avatar
Drives: Evo VIII MR
3 is normal anything over three with WOT is not good....
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
