Jul 26, 2008, 08:03 PM
#61
Personal Sales Rating: ( 82)
Drives: 2006 Evo IX MR SE
Quote:
Originally Posted by CPA5
^^^^^Bump for an answer^^^^^^^^^
bump
__________________
For Sale: 2006 Evo MR SE - low miles, 17x8.5 SSR GT7 rims and tires, Cobb Accessport
Offline
Jul 28, 2008, 08:58 AM
#62
Personal Sales Rating: ( 1)
Drives: 2006 GG Evolution IX GSR
I have been absent from the boards lately....and I don't see an update to the firmware....so I want to find out....Has there been a final fix to the AP Firmware that addresses the LTFT/STFT & the Performance Section Readings (0-60 / 1/4 mile time)???
Thanks COBB
BUMP AGAIN
Offline
Jul 28, 2008, 02:15 PM
#63
Personal Sales Rating: ( 0)
Drives: '99 E36 M3
I'm not sure what version is currently running on your AP.
1. Power up your AP.
2. Go to the about screen and look at the "Firmware" version.
3. Compare the current firmware version of the AP to what is listed on the website here: http://www.cobbtuning.com/info/?ID=3874. The current version of Mitsubishi AP firmware is 1.2.7.1.
Thanks,
Offline
Jul 29, 2008, 09:28 AM
#64
Thanks,
Rob---
Thanks...i can definitely check it out...But...does the version 1.2.7.1 have all the bugs worked out? i.e. the fuel trims and the 0-60 & 1/4 mile performance stuff?
Thanks
Offline
Jul 29, 2008, 09:35 AM
#65
Drives: '99 E36 M3
Rob---
Thanks
Yes, it should.
Offline
Jun 30, 2009, 11:45 PM
#66
Personal Sales Rating: ( 3)
Drives: 06 silver evo mr, 98 red kouki 240sx ka24det sold, 03 acura cls 6 speed SOLD, G20 WRECKED
cool will install latert tonight....
Offline
Aug 20, 2009, 10:58 AM
#67
Drives: Evo VIII MR
back to the knock sensor......
my buddy has AP as well on stage 2 his car was counting 7-15 counts of knock on 91, we then tried it with 110 race gas it still was knocking the same.
I have a completely stock evo 8, we logged my car with an ecu flash program it was knocking 4-6 count under normal driving.
Offline
Aug 25, 2009, 05:39 PM
#68
Silver Sponsor
When are you seeing these knock counts? Is this under high-load WOT or at low load partial throttle cruising? There isn't enough cylinder pressure at partial throttle low load to cause engine damage, when we get concerned is at higher-RPM high-load situations. See if you can discern when this is happening and under what conditions.
Offline
Aug 27, 2009, 09:44 AM
#69
Drives: Evo VIII MR
This is happening around 5,000 rpm full throttle and 2500 rpm no boost.
I almost wonder if this is just engine noise.
what are your thoughts?
Offline
Aug 27, 2009, 10:51 AM
#70
Silver Sponsor
Low load, high knock is not anything to really worry about. We have noted this behavior in just about every vehicle we support. However, knock at 5000 rpm under WOT is something to take note of and should be diagnosed by a tuner. How much knock are you seeing?
Travis
COBB Tuning
Offline
Aug 27, 2009, 12:40 PM
#71
Drives: Evo VIII MR
He is seeing around 7 counts knock at that RPM.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
